Home » Eclipse Projects » Eclipse Platform » catch Exception fails
catch Exception fails [message #303063] Mon, 08 May 2006 08:02 Go to next message
Hi!
I've written my own exception called "my.LoginException".
Now I've got a server (JBoss with EJB3) and a domain object called
"UserManager".
When I throw the "my.LoginException" in the server object "UserManager" like
this:
[common]
public class LoginException extends Exception {
@Remote
public interface IUserManager {
void isValid(LoginData);
[server jboss ejb3]
@Stateless
public class UserManager implements IUserManager {
public void isValid(LoginData) throws my.LoginException {
throw new my.LoginException();
and catch it like this:
[rcp client]
try {
UserManager usermgr = new UserManager();
usermgr.isValid(...);
} catch (my.LoginException e) {
print(e);
I can not catch the "my.LoginExcpetion" because the thrown exception is no
instance of a "my.LoginException".
I tried "e instanceof my.LoginException", this failed.
The debugger tells me that the thrown exception object "e" is a
my.LoginException!
When I call "e.getClass()" the system writes: "class my.LoginException".
So, the thrown exception object IS A "my.LoginException", but at runtime it
falls through the catch block.
Has anyone an idea? Is the eclipse classloading the error?
Thx, Christian
Re: catch Exception fails [message #303067 is a reply to message #303063] Mon, 08 May 2006 08:47 Go to previous messageGo to next message
Christian,
It sounds like you've got things set up so that more than one instance
of the same class is being loaded. Have you put this class in a jar
that's in a plugin which allows this jar to be shared with other plugins?
Christian Gesswagner wrote:
>Hi!
>"UserManager".
>this:
>[common]
>@Remote
>[server jboss ejb3]
>@Stateless
>[rcp client]
>try {
> print(e);
>my.LoginException!
>Thx, Christian
Re: catch Exception fails [message #303070 is a reply to message #303067] Mon, 08 May 2006 09:12 Go to previous messageGo to next message
You are right, this JAR is wrapped by a plugin which is shared with others.
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag
news:e3nekp$ti6$1@utils.eclipse.org...
> Christian,
> >Hi!
> >"UserManager".
like
> >this:
> >[common]
> >@Remote
> >[server jboss ejb3]
> >@Stateless
> >[rcp client]
> >try {
> > print(e);
no
> >my.LoginException!
it
> >Thx, Christian
Re: catch Exception fails [message #303100 is a reply to message #303070] Tue, 09 May 2006 01:36 Go to previous message
Got it!
The clue was, that I had two plugins which had the same jar wrapped (and
others of course). I removed the jar in plugin A and made a dependency to
plugin B. Thus the is not loaded twice.
"Christian Gesswagner" <christian.gesswagner@ams-engineering.com> schrieb im
Newsbeitrag news:e3ng3d$4ku$1@utils.eclipse.org...
others.
> > Christian,
plugins?
> > >Hi!
> > >"UserManager".
> like
> > >this:
> > >[common]
> > >@Remote
> > >[server jboss ejb3]
> > >@Stateless
> > >[rcp client]
> > >try {
> > > print(e);
> no
> > >my.LoginException!
my.LoginException".
runtime
> it
> > >Thx, Christian
Previous Topic:Eclipse Won't Start on Intel based Mac OsX
Next Topic:How to prevent Properties View listening to my View?
Current Time: Sat Oct 25 07:01:34 EDT 2025
Powered by FUDForum. Page generated in 0.05232 seconds
