Home » Eclipse Projects » Eclipse Platform » Accessing plugin data
Accessing plugin data [message #302641] Wed, 26 April 2006 04:42 Go to next message
Originally posted by: address.starts.after.hyphen-martin.umgeher.joanneum.at
how can I access files that are stored relative to my plug-in's
directory? For images, this works with
AbstractUIPlugin.imageDescriptorFromPlugin. But for other files (in my
case, an XSL file), I could only find Plugin.getBundle.getResource,
which returns a URL with the protocoll "bundleresource://", and I don't
know what to do with that.
M
Re: Accessing plugin data [message #302650 is a reply to message #302641] Wed, 26 April 2006 09:51 Go to previous messageGo to next message
You would use url.openStream() to get the input stream for the file for
usages that can't take just a URL.
This is the best way to access it. However if you are using some other
code that will only take a local java.io.File or a fully-qualified local
file name and will not accept a URL or an InputStream, then you would
need to also do:
String filename = FileLocator.toFileURL(url).getFile();
However, be careful with this because if your plugin is within a jar or
not a local file then this will make a physical copy of the jar on your
local file system. Unless it is exactly what you want don't do this with
a directory. If it is within a jar'ed plugin the ENTIRE directory will
be pulled out of the jar and placed on the local file system.
martin wrote:
> Hello,
> M
Rich Kulp
Re: Accessing plugin data [message #302658 is a reply to message #302650] Wed, 26 April 2006 13:01 Go to previous message
> need to also do:
> martin wrote:
>> Hello,
>> don't know what to do with that.
>> Thanks,
>> M
Thanks a lot, that did it :)
M
Previous Topic:Set a editor to non-editable
Next Topic:LaunchConfiguration
Current Time: Tue Jul 22 02:54:12 EDT 2025
Powered by FUDForum. Page generated in 0.03251 seconds
