| Software Update problem [message #300748] |
Thu, 16 March 2006 15:45   |
Eclipse User  |
Originally posted by: xes25ec02.sneakemail.com
Is this the newsgroup to post a software update problem?
I am having problems with 3.1.2 and 3.2M5a, but the same procedure works
with 3.1.0.
Procedure:
Software Updates->Find and Install->Search for new features to
install->Select "Eclipse.org update site"->Unselect "Ignore features not
applicable to this environment"->Finish
Result with 3.1.2 Build M20060118-1600 on Windows XP:
After Finish, Update Site Mirrors dialog appears.  Select Eclipse.org
update site.  After ok,  Updates dialog appears.  It is blank.  After
deselecting "Show the latest version of a feature only", you can see
Eclipse 3.1.1 and Eclipse 3.1.2.  Both have the following two items:
	Eclipse FTP and WebDAV Support 3.1.0
	Eclipse SDK Examples 3.1.1
Exactly the same if I choose ibiblio mirror.
This list does not seem complete.  I am trying to find GEF 3.1.1.
Result with 3.2.0M5a  Build I20060223-1656 on Windows XP:
A dialog pops up with message "No features found on the selected
site(s).  Choose a different site or site category."
This does not seem right.
Result with 3.1.0 Build I20050627-1435:
I get a full list of features.  Including GEF 3.1.1 that I am trying to get.
This is correct, so I'm not thinking it is a connection or setup problem.
Thanks for any help,
John
| Re: Software Update problem [message #300825 is a reply to message #300764] |
Fri, 17 March 2006 09:01   |
Eclipse User  |
This seems especially bad since the 3.1.2 version is the one you
download from the main download page:
http://www.eclipse.org/downloads/
At the moment, this likely a person's first exposure to eclipse.
John Lewis wrote:
> Thanks for responding.
> I do expect some quirkiness with 3.2M5a, but not with 3.1.2.  It is
> listed as a "Latest Release" here:
> http://download.eclipse.org/eclipse/downloads/index.php
> John
> Rich Kulp wrote:
>> This is probably because in development milestone builds are not put
>> on the Eclipse update site. Only released final builds are put on the
>> main eclipse update site.
>>> works with 3.1.0.
>>> Procedure:
>>> not applicable to this environment"->Finish
>>> to get.
>>> problem.
>>> John
FUDForum. Page generated in 0.07214 seconds
