Home » Eclipse Projects » Eclipse Platform » Get the active file, from the editor.
Get the active file, from the editor. [message #300299] Tue, 07 March 2006 05:08 Go to next message
Originally posted by: robbelibobban.gmail.com
How do i in code get the active file from the editor, from my plugin ?
I use the CDT editor.
I want to make a syntax check on the file.
/Robert
Re: Get the active file, from the editor. [message #300308 is a reply to message #300299] Tue, 07 March 2006 09:24 Go to previous messageGo to next message
Forgot to use the search function =/
This is the way to do it.
import org.eclipse.ui.IWorkbench;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.part.FileEditorInput;
import org.osgi.framework.Bundle;
IWorkbench wb = PlatformUI.getWorkbench();
IWorkbenchWindow window = wb.getActiveWorkbenchWindow();
IWorkbenchPage page = window.getActivePage();
IEditorPart editor = page.getActiveEditor();
IEditorInput input = editor.getEditorInput();
IPath path = ((FileEditorInput)input).getPath();
/Robert
Re: Get the active file, from the editor. [message #300353 is a reply to message #300308] Tue, 07 March 2006 17:08 Go to previous messageGo to next message
Originally posted by: varavamu.yahoo.com
you will have to perform null checks along the way :) since there is no
guarantee that 'window' or 'page' will return non-null values.
hth,
Vijay
> /Robert
Re: Get the active file, from the editor. [message #300483 is a reply to message #300353] Thu, 09 March 2006 12:26 Go to previous messageGo to next message
Originally posted by: nathalie.lepy.tiscali.fr
In fact, this solution only works if you are somewhere in the Workbench,
in other cases, it doesn't work (if you want to get the active editor
file, from a dialog box for example, it doesn't work).
I tried this piece of code, and for the time being it seems to work :
IWorkbench workb = LotosPlugin.getDefault().getWorkbench();
if (workb == null) return false;
IWorkbenchWindow[] wins = workb.getWorkbenchWindows();
if (wins.length <= 0) return false;
int i = 0;
while ( (i < wins.length)
&& (! (wins[i].getPartService().getActivePart() instanceof IEditorPart))
i++;
if (i >= wins.length) return false;
(IEditorPart) wins[i].getPartService().getActivePart();
if (input == null) return false;
if (path == null) return false;
Nath.
> hth,
> Vijay
>> /Robert
Re: Get the active file, from the editor. [message #716506 is a reply to message #300483] Wed, 17 August 2011 11:08 Go to previous message
How to get this (determining the full OS-filename) working for files outside the workbench ? (so files that were opened via menu "File" / "Open file ...").
Thx !
Previous Topic:Multiple applications mess up configuration
Next Topic:What r the tools Provided by Eclipse
Current Time: Thu Oct 23 00:29:12 EDT 2025
Powered by FUDForum. Page generated in 0.04159 seconds
