| Exposing own extension in plugin fails in runtime [message #297595] |
Tue, 17 January 2006 10:31  |
Hi all,
I am experiecing a problem when I have a plugin exposing an extension
point. In debug mode (PDE) it all works very fine. When exported and
installed it seemingly doesn't work as well.. anyhow, the error I get
indicates that my plug exteding the extension point cannot load a class
within its own plugin (!), from the same package.
What am I doing wrong here? What is missing??
The classes are all .class files at the root of the JR-file (no JAR within
a JAR). The plugin also has a preference page, it has no problem
instantiating and creating it, it is visible in Window->Preferences
dialogue.
Thanks in advance,
Robert
| Re: Exposing own extension in plugin fails in runtime [message #297613 is a reply to message #297608] |
Tue, 17 January 2006 12:36   |
Originally posted by: robert.varttinen.sonyericsson.com
See my answers in-line:
Paul Webster wrote:
> So that was useful information, but we need a little more ... what's
> your usecase?
> ex: com.xxxxxx.bronzefish2 defines the extension point?
Yes, it defiens the extnsion point.
> and it's
> activator is the one walking through the config elements? it
> instantiates the executable extension and tries to do something with it
> (and that's when you get the ClassNotFound)? Does anything in your
> extension point try and use loadClass(*) or forName(*), or does it just
> work by instantiating the executable extension?
Yes, the activator walks (for-loop) through each extension it finds, one
in my test as of now. The ClassNotFound seems to come from the other,
extending plugin.
The activator, what I think it is, uses createExecutableExtension(...) on
the element it found. I basically followed an example on how to create
extension points.
No, there is no loadClass(..) or forName(..) in my code.
> And then com.xxxxxx.bronzefish.baseline actually implements the 2
> extensions (preference page and
> com.xxxxxx.bronzefish2.BronzeFishBaseLineUpdate). Or is this the plugin
> that you get the ClassNotFound in?
Yes, so it seems. I am currently trying to get the exceptiom stack trace
to the log ... but that seems a bit tricky.
> Later,
> PW
//Robert
FUDForum. Page generated in 0.05457 seconds
