Home » Eclipse Projects » Eclipse Platform » My Java project disappeared!
My Java project disappeared! [message #299827] Fri, 24 February 2006 16:01 Go to next message
My computer lost power while Eclipse was running, and when I restarted, my
remembered file wasn't displaied, there was an exception instead: "File
/<Project>/<path to file> does not exist."
The Package Explorer and Navigator are both empty, although the Outline is
populated with the correct structure. My log is posted below, but after I
closed the editors, exited, and restarted Eclipse, I now do not get
anything in my .log file when I start Eclipse. Only the version.ini
timestamp gets modified now.
How do I get it to load my project? It is pointing to the correct
workspace. Trying to "Switch Workspace" to it makes no difference.
Here is my .log file:
!SESSION 2006-02-24 12:15:47.591
eclipse.buildId=M20050929-0840
java.version=1.4.2_05
Command-line arguments: -os win32 -ws win32 -arch x86 -data C:\Program
Files\eclipse\workspaces_31\workspace
!ENTRY org.eclipse.ui.workbench 4 2 2006-02-24 12:16:40.230
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:1328)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at
org.eclipse.ui.internal.EditorManager.saveEditorState(Editor Manager.java:1287)
at
org.eclipse.ui.internal.EditorManager.saveState(EditorManage r.java:1208)
at
org.eclipse.ui.internal.WorkbenchPage.saveState(WorkbenchPag e.java:2779)
at
org.eclipse.ui.internal.WorkbenchWindow.saveState(WorkbenchW indow.java:2288)
at org.eclipse.ui.internal.Workbench.saveState(Workbench.java:1 733)
at
org.eclipse.ui.internal.Workbench.recordWorkbenchState(Workb ench.java:1469)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:14 66)
at org.eclipse.ui.internal.Workbench$10.run(Workbench.java:559)
at
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:5 57)
at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:52 2)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:713)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:711)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:686)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:643)
at
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:627)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:728)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:726)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:727)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:67 4)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:159)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:257)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1649)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3040 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1582)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:410)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ui.workbench 4 2 2006-02-24 12:16:40.245
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.team.ui 4 1 2006-02-24 12:16:44.26
!MESSAGE Error initializing Synchronization
!STACK 1
org.eclipse.ui.WorkbenchException[0]: org.xml.sax.SAXParseException:
Document root element is missing.
at org.apache.crimson.parser.Parser2.fatal(Parser2.java:3376)
at org.apache.crimson.parser.Parser2.fatal(Parser2.java:3364)
at org.apache.crimson.parser.Parser2.parseInternal(Parser2.java :668)
at org.apache.crimson.parser.Parser2.parse(Parser2.java:337)
at org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl. java:448)
at
org.apache.crimson.jaxp.DocumentBuilderImpl.parse(DocumentBu ilderImpl.java:185)
at org.eclipse.ui.XMLMemento.createReadRoot(XMLMemento.java:93)
at org.eclipse.ui.XMLMemento.createReadRoot(XMLMemento.java:64)
at
org.eclipse.team.internal.ui.synchronize.SynchronizeManager. restoreSavedParticipants(SynchronizeManager.java:577)
at
org.eclipse.team.internal.ui.synchronize.SynchronizeManager. init(SynchronizeManager.java:541)
at
org.eclipse.team.internal.ui.synchronize.SynchronizeManager. <init>(SynchronizeManager.java:275)
at org.eclipse.team.ui.TeamUI.getSynchronizeManager(TeamUI.java :47)
at org.eclipse.team.internal.ui.TeamUIPlugin.stop(TeamUIPlugin. java:212)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleContextImpl.java:1035)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1031)
at
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:394)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.stop (AbstractBundle.java:408)
at
org.eclipse.core.runtime.internal.adaptor.BundleStopper.basi cStopBundles(BundleStopper.java:83)
at
org.eclipse.core.runtime.internal.adaptor.BundleStopper.stop Bundles(BundleStopper.java:73)
at
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSto pping(EclipseAdaptor.java:766)
at
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:528)
at
org.eclipse.osgi.framework.internal.core.SystemBundle$1.run( SystemBundle.java:171)
at java.lang.Thread.run(Thread.java:534)
!SUBENTRY 1 org.eclipse.ui 4 0 2006-02-24 12:16:44.26
!MESSAGE Document root element is missing.
!STACK 0
org.xml.sax.SAXParseException: Document root element is missing.
at
at
at
at
at
at
at
at
at
at
at
at
at
!SESSION 2006-02-24 12:16:45.526
!ENTRY org.eclipse.ui 4 0 2006-02-24 12:16:49.120
!MESSAGE Unable to create editor ID
org.eclipse.jdt.ui.CompilationUnitEditor: No input factory ID found for
editor id=org.eclipse.jdt.ui.CompilationUnitEditor name=WorkListQuery.java
!STACK 1
org.eclipse.ui.PartInitException: No input factory ID found for editor
at
org.eclipse.ui.internal.EditorReference.getRestoredInput(Edi torReference.java:309)
at
org.eclipse.ui.internal.EditorReference.getEditorInput(Edito rReference.java:288)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:546)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:384)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:258)
at
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1221)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:949)
at
at
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:944)
at
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2576)
at
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1819)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2566)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 515)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1514 )
at org.eclipse.ui.internal.Workbench$16.run(Workbench.java:1263 )
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:447)
at
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1258)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1512)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 491)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1374 )
at
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1318)
at
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:700)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.ui 4 0 2006-02-24 12:16:49.135
!MESSAGE No input factory ID found for editor
!ENTRY org.eclipse.ui 4 0 2006-02-24 12:17:05.603
editor id=org.eclipse.jdt.ui.CompilationUnitEditor name=Viewer.java
!STACK 1
at
at
at
at
at
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at
org.eclipse.ui.internal.PartStack.handleDeferredEvents(PartS tack.java:1066)
at org.eclipse.ui.internal.LayoutPart.deferUpdates(LayoutPart.j ava:402)
at
org.eclipse.ui.internal.PartSashContainer.handleDeferredEven ts(PartSashContainer.java:1317)
at
org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1260)
at
org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1250)
at
org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1224)
at
org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:1279)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:54 )
at org.eclipse.ui.internal.PartStack.close(PartStack.java:495)
at org.eclipse.ui.internal.EditorStack.close(EditorStack.java:1 97)
at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:102 )
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:81)
at
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:267)
at
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:276)
at
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
at
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$1.closeButtonPressed(DefaultTabFolder.java:67 )
at
org.eclipse.ui.internal.presentations.PaneFolder.notifyClose Listeners(PaneFolder.java:584)
at
org.eclipse.ui.internal.presentations.PaneFolder$3.close(Pan eFolder.java:190)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:20 75)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:292)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.ui 4 0 2006-02-24 12:17:05.603
!SESSION 2006-02-24 12:18:22.428
Re: My Java project disappeared! [message #299836 is a reply to message #299827] Sat, 25 February 2006 10:21 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Sounds like a file corruption case. It's difficult to know what advice to give you given that almost any file could be broken. I'd recommend taking a backup of your hard drive (if possible) and then try to run file system checks like chkdsk to see if there's any file corruption. Sometimes it will be able to save it; other times it won't.
I'd recommend getting rid of your entire workspace/.metadata directory, in case any of those files have been corrupted. I'd also recommend that you get rid of the configuration directory, and replace it with any default files that are in the Eclipse install (though IIRC the configuration directory is created the first time you run Eclipse).
You should also check your project's files out too. I'd recommend backing those up; for example, creating a Zip file. You should then be able to import the existing project into the workspace.
If you have the bandwidth available, it might just be easier to download a new 3.1.2 install and put that in a fresh place. You can then use the zip file you created above to import it into an entirely new workspace, and once you're happy with the contents, you can get rid of the old install.
Incidentally, this is one of the arguments for using a version control system like CVS or SVN, even when you're the only one doing any work. If there's a problem with the hard drive, you've at least got a second copy of it somewhere else on the hard drive, though it's better still if it's on a different hard drive or another computer.
Alex.
Re: My Java project disappeared! [message #299884 is a reply to message #299836] Mon, 27 February 2006 12:27 Go to previous messageGo to next message
I'm afraid I didn't express myself very well.
We ARE using Subversion (Subclipse), and I have all my files. In fact, my
current directory structure is just fine. It is just Eclipse that isn't
showing anything. All my files are there, and I can even open up my
project with Eclipse 3.0 (using an old workspace, of course).
However, it is a royal pain in the rear to get a new project set up (we
have a ton of 'ignore' files, I'm pretty particular about how my editors
are configured, etc). I just want to tell Eclipse to re-compute the
project and find my files again.
Re: My Java project disappeared! [message #299894 is a reply to message #299884] Mon, 27 February 2006 15:14 Go to previous messageGo to next message
If the .project and .classpath files still exist in the root of your
project, then Eclipse will be able to recognize you project automatically.
These files define what is included in your project. Use
File->New->Project to select Java Project. From the wizard select the
Create project from existing source and select the project root.
Re: My Java project disappeared! [message #299895 is a reply to message #299884] Mon, 27 February 2006 15:53 Go to previous messageGo to next message
Originally posted by: varavamu.yahoo.com
make sure that the ignore file filters are not also filtering out your
java sources.
vijay
> my current directory structure is just fine. It is just Eclipse that
> isn't showing anything. All my files are there, and I can even open up
> my project with Eclipse 3.0 (using an old workspace, of course).
> (we have a ton of 'ignore' files, I'm pretty particular about how my
> editors are configured, etc). I just want to tell Eclipse to
> re-compute the project and find my files again.
Re: My Java project disappeared! [message #299898 is a reply to message #299895] Mon, 27 February 2006 16:30 Go to previous messageGo to next message
> java sources.
> vijay
I have not modified my filters at all. Java files definately not in the
ignore filter. When I launch Eclipse, as long as I didn't have any
existing files opened up when I last quit, the log doesn't get touched at
all. Not even the "!SESSION" line or buildID log line. If I did have a
Java file opened, then I get the exception noted on my initial post.
Re: My Java project disappeared! [message #299900 is a reply to message #299894] Mon, 27 February 2006 17:00 Go to previous messageGo to next message
The only thing in the .project is the name of the project, the
buildCommand, and the nature. The only thing in the .classpath is, of
course, the classpath. All my other project settings will still be lost.
Since this was a recent event, without any modifications to my Project
itself (just in the source code), I took a look at all project files
modified in the past month. I have a bunch of files from the 22nd that are
all null. They have length, but no data.
workspace\.metadata\.plugins\org.eclipse.search\dialog_setti ngs.xml
workspace\.metadata\.plugins\org.eclipse.core.resources\proj ects\ <My
Project>\.markers
Project>\.syncinfo
Project>\.indexes\15\e4\81\fe\15\history.index
Project>\.indexes\15\e4\81\fe\db\history.index
Project>\.indexes\15\e4\81\fe\37\6e\history.index
All of these were at 4:40 pm, which may have been around the time of a
power outage. I tried restoring the dialog_settings.xml, .markers, and
syncinfo files from my previous 3.0 project, and just deleting the
Project>\.indexes\15 folder, but it made no difference.
I just have to assume that the project was lost to the gods of file
corruption, and I'll have to recreate it. :-(
Re: My Java project disappeared! [message #696635 is a reply to message #299827] Thu, 14 July 2011 09:03 Go to previous messageGo to next message
I had the same kind of condition, except it happened to me without reason. This morning I worked with Eclipse and closed it properly, and when opening Eclipse again this evening, the projects were gone, and the still open editors showed "The file <> does not exist".
Luckily I had a backup on another computer because I use dropbox as a repository, and I was able to determine which files were effectively causing this.
index.php/fa/3358/0/
Left is the working copy, right is the erroneous copy.
Just copying the red files didn't work. Just copying the green files didn't work. Copying everything except the log, the 192.tree and the workbench file worked for me.
Re: My Java project disappeared! [message #696645 is a reply to message #696635] Thu, 14 July 2011 09:29 Go to previous message
On 14.07.2011 15:03, forums-noreply@eclipse.org wrote:
> I had the same kind of condition, except it happened to me without reason. This morning I worked with Eclipse and closed it properly, and when opening Eclipse again this evening, the projects were gone, and the still open editors showed "The file<> does not exist".
Please open a bug against Platform Resources and fill in all that
information.
Dani
Previous Topic:CompareUIPlugin throws a NullPointerException
Next Topic:Eclipse can't be start from Eclipse.app (Mac OS X Snow Leopard)
Current Time: Sun Jul 27 08:19:14 EDT 2025
Powered by FUDForum. Page generated in 0.25755 seconds
