| Unhandled event loop exception [message #299813] |
Fri, 24 February 2006 09:32  |
Originally posted by: mightymate.gmail.com
I am developing a Plug-in (wizard) for eclipse. It is supposed to connect
to the CVS and add the selected file to the CVS.
I am using org.netbeans.lib.cvsclient.jar
The problem is I keep getting this message when I try to start the wizard
in the run-time work space:
Reason:
org/netbeans/lib/cvsclient/connection/Connection
And the wizard doesnt even open.
I am sure that the above mentioned jar is included in the build path.
The wizard was working fine until I added this bit of code as below:
private void commitFile(String containerLocation) throws CoreException {
GlobalOptions globalOptions = new GlobalOptions();
globalOptions.setCVSRoot(":pserver:reddyva@zug:/jdev/cvs");
PServerConnection c = null;
try {
c = new PServerConnection();
c.setUserName("reddyva");
c.setEncodedPassword("AAd!b=?!");
c.setHostName("zug");
c.setRepository("/jdev/cvs");
c.open();
}catch (Exception ex) {
ex.printStackTrace();
// -problem area.
Client client = new Client(c, new StandardAdminHandler());
AddCommand command = new AddCommand();
try {
client.setLocalPath(containerLocation);
command.setBuilder(null);
File file = new File(page.getAbsoluteFileName());
File[] files = new File[1];
files[0] = file;
command.setFiles(files);
boolean flag = client.executeCommand(command, globalOptions);
System.out.println("AddCommandStatus: " + flag);
If I comment out the part below // -problem area, at least it starts the
wizard without any problem, but I need to get this part to be able to add
the file to the CVS.
Strangely even when I dont call this method in my code, but if its there
the problem persists and if I comment it out, the wizard works.
I tried everything I possible could, but couldnt find what the problem was.
Could somebody please tell me if I am missing some thing very obvious or
is there anything else I have to do?
I checked the log file under .metadata in both the development and
run-time workspace and there seems to be no entry made in the log file as
its empty.
Any help would be appreciated.
Thanks in advance,
Vic.
| Re: Unhandled event loop exception [message #299818 is a reply to message #299814] |
Fri, 24 February 2006 10:49  |
Thanks for the reply Stefan. I am using the netbeans library becuase the
eclipse team API is not public. I mean its quite stable, but as its
internal I was not sure if it would change in the future.
Secondly is there a way I can make sure that any class required by the
netbeans library be loaded before the causing the exception.
Also, if I use the eclipse API. Do I have to write another plugin as an
extension point to the hook provided for
org.eclipse.team.core.repository?? I am really confused here as if I just
use the eclipse library wouldnt it casuse problems with the existing team
plugin for the CVS which I am also using.
Thanks once again.
cheers,
varun.
FUDForum. Page generated in 0.02913 seconds
