Home » Eclipse Projects » Eclipse Platform » [howto] Invoke a view programmatically?
[howto] Invoke a view programmatically? [message #29960] Tue, 13 May 2003 14:41 Go to next message
I have written an Extension Point for a View and implemented a class
"MyView" derived from ViewPart. I have implemented the methods
"createPartControl" and
"setFocus". The view works just fine if I activate it via the menu
("Window/ShowView/Java/MyView").
But how can I activate it programmatically? I have looked into the source
of the jdt.junit plugin (since my view deals with different VM's, too) and
(I think I) followed their example. That is, I have written a class
"MyPlugin" which extends AbstractUIPlugin. In this class, I call a
"getActiveWorkbenchWindow().getActivePage().showView(<id of my view>);",
however "getActiveWorkbenchWindow()" returns null... And I cannot see,
why. In the plugin.xml file, I specified the correct plugin-class (i.e. I
specified the fully qualified name of MyPlugin).
Do I have to "register" my plugin somewhere? To I have to tell Eclipse
that "I am a View"? What did I forget to do?
Do you have any ideas?
Thanks for your help,
Philipp
Re: [howto] Invoke a view programmatically? [message #29968 is a reply to message #29960] Tue, 13 May 2003 15:31 Go to previous messageGo to next message
Sorry, just found it:
the "getActiveWorkbenchWindow().getActivePage().showView(...)" method must
be called from a different (new) display thread...
Now it works...
Philipp
> Philipp
Re: [howto] Invoke a view programmatically? [message #31651 is a reply to message #29968] Wed, 14 May 2003 11:03 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
You should avoid using getActionWorkbenchWindow(). It can and will return
null in some situations. I do not understand what you mean by "called from a
different (new) display thread". Are you creating a new Display?
Can you provide use with the use case for showing the view programmatically?
For instance, is it the case where you have a menu action, and if the user
runs this action you want to open the view? Or you want your view visible in
a given perspective X when perspective X is open?
Simon :-)
"Philipp Bouillon" <Philipp.Bouillon@t-online.de> wrote in message
news:b9rh64$fg2$1@rogue.oti.com...
> Now it works...
> Philipp
> > Hi,
source
and
I
> > Philipp
Re: [howto] Invoke a view programmatically? [message #36987 is a reply to message #31651] Sun, 18 May 2003 16:39 Go to previous messageGo to next message
Sorry for the late reply, but I did not notice your post until now.
I am checking the return value of "getActiveWorkbenchWindow" -- so far, it
never returned null... But if it does, I "simply" do not show my view.
However, I have seen this method of diplaying a view by looking at the
code of the jdt.junit plugin.
All I am trying is to open a view at a certain point during the execution
of my plugin. Say, a user runs a JUnit test. One test fails. I do some
analysis. And I'd like to show the progress of the analysis in a separate
view (very similar to the JUnit view). So, I assume that a Java
perspective (or Java Browsing or Debugging, or whatever) is already open,
and all I'd like to do, is to show my view on top of the package explorer.
What I meant by "called from a different (new) display thread" was simply
that I had to make the call as a new Runnable object:
display.syncExec(new Runnable() {
public void run() {
listeningView = MyPlugin.getDefault().connectMyView();
and this works fine for me -- did I overlook anything?
Thanks for your advice,
Philipp
> Simon :-)
> > Now it works...
> > Philipp
> > > Hi,
> source
> and
> I
> > > Philipp
Re: [howto] Invoke a view programmatically? [message #40447 is a reply to message #36987] Tue, 20 May 2003 11:50 Go to previous messageGo to next message
news:ba8r2s$uvc$1@rogue.oti.com...
Does not mean they are doing it right ;-)
You want to open a view at a point in the execution of your plugin. What
started that long running execution in your plugin? Was it an action? If so,
it should have enough context for you to determine what the window is. Then
past that along to show any views you need to (still using the syncExec call
since it seems this long running operation is in the background thread)
Simon :-)
Re: [howto] Invoke a view programmatically? [message #46068 is a reply to message #40447] Fri, 23 May 2003 11:01 Go to previous message
Aaaaahh... Yes. That sounds good. Thanks for the information. My code
seems to be a lot cleaner now ;-)).
Philipp
> Simon :-)
Previous Topic:ISharedImages
Next Topic:My solution on using JDK document in Eclipse
Current Time: Wed Sep 03 01:32:38 EDT 2025
Powered by FUDForum. Page generated in 1.91528 seconds
