Home » Eclipse Projects » Eclipse Platform » unable to create view ID
unable to create view ID [message #299546] Mon, 20 February 2006 09:38 Go to next message
Originally posted by: fabian.eberhardt.sap.com
After changing code in a couple of classes I get the following error
when starting my runtime eclipse:
"Unable to create view ID com.id.of.my.view.ComponentsView: Plug-in
com.name.of.my.plugin was unable to load class
com.path.to.my.view.ComponentsView.
java.lang.ClassNotFoundException: com.path.to.my.view.ComponentsView"
What I did yet:
- check path in plugin.xml: it is the right path to java class
(never changed it - and never changed name of class)
- starting eclipse with "eclipse.exe - clean"
- "Project / Clean" all projects
- "PDE Tools / Update Classpath" of all projects
That helped several times before - but not now.
Any ideas?
Thanks!
Fabian
Re: unable to create view ID [message #299661 is a reply to message #299546] Tue, 21 February 2006 14:24 Go to previous messageGo to next message
Check on plugin dependencies....if it has any dependencies you added in your
new modifications, then make sure that those plugins are also added to the
launch configurations. Most of the time it happens automatically, but double
checking this could help.
"Fabian Eberhardt" <fabian.eberhardt@sap.com> wrote in message
news:dtck9f$a9j$1@utils.eclipse.org...
> After changing code in a couple of classes I get the following error when
> What I did yet:
> Any ideas?
> Thanks!
> Fabian
Re: unable to create view ID [message #299680 is a reply to message #299661] Wed, 22 February 2006 05:20 Go to previous message
problem solved :)
one of the needed packages were not exported any more...
> "Fabian Eberhardt" wrote in message
>>Hi,
>>What I did yet:
>>Any ideas?
>>Thanks!
>> Fabian
Previous Topic:3rd Debugger article
Next Topic:C++ auto completion on amd64 hangs
Current Time: Sun Oct 26 09:46:21 EDT 2025
Powered by FUDForum. Page generated in 0.03246 seconds
