Home » Newcomers » Newcomers » Remove older Eclipse releases
Remove older Eclipse releases [message #29880] Fri, 04 March 2005 10:36 Go to next message
Originally posted by: Rainer.Faulstich.ifp-beisch.com
after updating my eclipse several times over the web more and more older
releases accumulate on my disk. How can i remove these no more used older
realeases from my disk without any damage to the currently installed
release ?
Thanks Rainer
Re: Remove older Eclipse releases [message #29882 is a reply to message #29880] Fri, 04 March 2005 11:13 Go to previous messageGo to next message
Hi Rainer,
Yes, you can just delete them from file system, in folder "features" and
"plugins". I did this before.
But beware you can't rollback your configuration by doing this.
Hangsu
"Rainer Faulstich" <Rainer.Faulstich@ifp-beisch.com> wrote in message
news:d09v9n$l5b$1@www.eclipse.org...
> release ?
> Thanks Rainer
Re: Remove older Eclipse releases [message #29890 is a reply to message #29882] Fri, 04 March 2005 12:05 Go to previous messageGo to next message
Originally posted by: ronw.karwin.homeunix.net
Hangsu Ma wrote:
> Hi Rainer,
Just be real careful when deleting plugins/features. Some plugins have
cross dependences. I have trashed my installed eclipse twice doing just
that. Now I just think, disks are cheap, and do not bother. I also
install new milestones enough to not worry about it anymore.
Consider yourself warned.
ronw.
> Hangsu
>>Hi,
>>release ?
>>Thanks Rainer
Re: Remove older Eclipse releases [message #29894 is a reply to message #29880] Fri, 04 March 2005 12:56 Go to previous messageGo to next message
Besides the other replies, which I also delete the plugins/features, then
install over the top. I would also set your workspace OUTSIDE of the eclipse
directory, so that you don't blow it away when overwriting or accidentally
delete anything.
> release ?
> Thanks Rainer
Re: Remove older Eclipse releases [message #29900 is a reply to message #29880] Fri, 04 March 2005 14:55 Go to previous message
Originally posted by: eclipse.rizzoweb.com
Rainer Faulstich wrote:
> older realeases from my disk without any damage to the currently
> installed release ?
You should never install Eclipse on top of another installation - always
either use a new location or completely remove the old one. I'm pretty
sure most builds/releases state this in their release notes or readme or
somewhere like that.
I, personally use a directory structure like this:
Java/
Eclipse/
2.1/
3.0/
3.1M4/
workspaces/
2.1/
3.0/
3.1/
Eric
Previous Topic:CVS Repositories doesn't show projects
Next Topic:Emacs in Eclipse
Current Time: Sun Jul 20 02:42:31 EDT 2025
Powered by FUDForum. Page generated in 0.08599 seconds
