| Re: JavaUI.getWorkingCopyManager() => NullPointerException [message #298974 is a reply to message #298924] |
Wed, 08 February 2006 11:23  |
Originally posted by: daniel.megert.eclipse.org
Tim wrote:
> when i call JavaUI.getWorkingCopyManager() I get this exception
Does your plugin.xml or manifest.mf declare to depend on
org.eclipse.jdt.ui? Are there any other messages in .log?
Dani
> !ENTRY org.eclipse.ui 4 4 2006-02-07 17:01:58.686
> !MESSAGE Unhandled event loop exception
> !ENTRY org.eclipse.ui 4 0 2006-02-07 17:01:58.701
> !MESSAGE java.lang.NullPointerException
> !STACK 0
> at org.eclipse.jdt.ui.JavaUI.getWorkingCopyManager(JavaUI.java: 616)
> at
> test.plugin.TestWorkingCopyManagerAction.run(TestWorkingCopy ManagerAction.java:31)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
> at
> org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
> Code))
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
> at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
> at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
> at
> org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
> at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:85)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:58)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:60)
> at java.lang.reflect.Method.invoke(Method.java:391)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
> at org.eclipse.core.launcher.Main.run(Main.java:973)
> at org.eclipse.core.launcher.Main.main(Main.java:948)
FUDForum. Page generated in 0.03450 seconds
