Home » Eclipse Projects » Eclipse Platform » Eclipse synchronization with external repository library
Eclipse synchronization with external repository library [message #297671] Wed, 18 January 2006 07:28 Go to next message
So the CVS repository API is now in internal packages, we do the cvs
manipulations with an external library.
That works good with what is on the file system but Eclipse isn't warned
that a action has occured and the synchrnization state is corrupted…
We've take a look at the Synchronizer, Subscriber and TeamProvider but we
don't see how to use these API…
How can we synchronize Eclipse with the new CVS state in an easy way?
Thx for your help
Best regards
JJ
Re: Eclipse synchronization with external repository library [message #297675 is a reply to message #297671] Wed, 18 January 2006 07:46 Go to previous messageGo to next message
I've forgot to say that for the Eclipse 3.1.1...
Re: Eclipse synchronization with external repository library [message #297690 is a reply to message #297675] Wed, 18 January 2006 09:19 Go to previous messageGo to next message
Originally posted by: mvalenta.ca.ibm.com
If you are using another tool to perform CVS operations, you can perform
a refresh on the project involved. There is an entry available in the
context menu of the Navigator and Packages Explorer. You can also do it
programmatically bu calling IResource#refreshLocal.
Michael
Re: Eclipse synchronization with external repository library [message #297704 is a reply to message #297690] Wed, 18 January 2006 11:02 Go to previous messageGo to next message
Hi Michael,
I thought that this refresh gets only the workspace refresh vs the
filesystem.
After this refresh, will the team synchronizer not tell that the file is
locally modified ?
Jacques
Re: Eclipse synchronization with external repository library [message #297760 is a reply to message #297704] Thu, 19 January 2006 09:03 Go to previous message
It should.
Jacques Leclercq wrote:
> Hi Michael,
> filesystem.
> locally modified ?
> Jacques
Previous Topic:Error activating custom builder
Next Topic:StructuredViewer.setSelection - make a default selection
Current Time: Sat Jul 26 21:36:58 EDT 2025
Powered by FUDForum. Page generated in 0.05450 seconds
