Home » Eclipse Projects » Eclipse Platform » All the sub-menus in Eclipse are disabled
All the sub-menus in Eclipse are disabled [message #297482] Mon, 16 January 2006 02:49 Go to next message
Originally posted by: sacoskun.gmail.com
I'm using Linux(Ubuntu Kernel 2.6) and installed Eclipse 3.1.1 on my OS.
When I opened Eclipse all the sub-menus(i.e. All sub-menus under File,
Edit Source, ... Window,Help) disabled and therefore I cannot create any
project.
What could be the problem, how can I solve this?
Kind Regards,
Sarp Arda Coskun
Re: All the sub-menus in Eclipse are disabled [message #297490 is a reply to message #297482] Mon, 16 January 2006 07:09 Go to previous messageGo to next message
Originally posted by: daniel.megert.eclipse.org
Sarp Arda Coskun wrote:
> any project.
Maybe there's no perspective open. Try:
1. Window > Open Perspective > Other...
2. select 'Java'
3. press 'OK'
4. File > New > Project...
HTH
Dani
> Kind Regards,
> Sarp Arda Coskun
Re: All the sub-menus in Eclipse are disabled [message #297506 is a reply to message #297490] Mon, 16 January 2006 10:23 Go to previous messageGo to next message
Hi Sir,
When I do what you wanted it gives an error like
Problems openning perspective 'org.eclipse.jdt.ui.JavaPerspective'
How can I be sure that I have installed the eclipse correctly?
I have downloaded the .tar.gz file from eclipse.org and then right clicked
and select 'Extract Here'. Lastly I have double clicked the 'eclipse' file
in the main folder to open the eclipse.
Kind Regards,
Sarp Arda Coskun
Re: All the sub-menus in Eclipse are disabled [message #297508 is a reply to message #297506] Mon, 16 January 2006 10:44 Go to previous messageGo to next message
> Hi Sir,
Make sure you
- download "Eclipse SDK" (not Platform)
- install the archive into an empty directory
- preserve the directory structure when extracting the archive
Dani
> clicked and select 'Extract Here'. Lastly I have double clicked the
> 'eclipse' file in the main folder to open the eclipse.
> Kind Regards,
> Sarp Arda Coskun
Re: All the sub-menus in Eclipse are disabled [message #297517 is a reply to message #297506] Mon, 16 January 2006 11:30 Go to previous messageGo to next message
Hey,
It sounds like you're running Eclipse with the GCJ Java runtime that
came with Ubuntu, rather than a Java runtime from Sun or IBM. Download
an official runtime and make sure it shows up first on your path, and
Eclipse should work fine.
Hope this helps,
- Jeff
Re: All the sub-menus in Eclipse are disabled [message #297528 is a reply to message #297517] Mon, 16 January 2006 18:14 Go to previous message
Thanks for all replies,
It worked in Jeff's way, I have created a launcher for my eclipse file
that enforces Ubuntu to use Sun's JRE.
Is there any way that I can set the Sun's JRE to be the default JRE for my
Ubuntu?
Kind Regards,
Sarp Arda Coskun
Previous Topic:Multi-select on linux
Next Topic:Platform log errors?
Current Time: Sat Sep 27 13:47:26 EDT 2025
Powered by FUDForum. Page generated in 0.04494 seconds
