Home » Eclipse Projects » Eclipse Platform » Progress Monitor threading leads to undesired code execution order
Progress Monitor threading leads to undesired code execution order [message #296207] Fri, 16 December 2005 14:29 Go to next message
What is the correct way to handle this situation?
1. CellEditor in a TableViewer is active.
2. User takes action which results in an event which causes the
focusLost() to be triggered on the active CellEditor.
3. The CellEditor#modify method spawns a progress monitor in a separate
thread.
4. The action triggering the focusLost() event is then processed while the
progress monitor is working.
5. The rest of the CellEditor#modify method is executed.
I'd like step 5 to occur prior to step 4. So far the fix has been to
filter out other events until the progress monitor completes.
Re: Progress Monitor threading leads to undesired code execution order [message #296488 is a reply to message #296207] Thu, 22 December 2005 16:23 Go to previous messageGo to next message
Originally posted by: nick_edgar._no.spam.please_.ca.ibm.com
Eli,
Sorry for the delay. I looked for your post earlier, but must have
missed it.
The problem is that most progress monitor implementations spin the event
loop while waiting for the operation to complete, in order to keep the
UI responsive.
Which progress monitor are you using? Does the UI need to be responsive
during your operation?
Nick
> thread.
> the progress monitor is working.
Re: Progress Monitor threading leads to undesired code execution order [message #296923 is a reply to message #296488] Wed, 04 January 2006 15:08 Go to previous messageGo to next message
I'm using the ProgressMonitorPart as used in the JFace Wizard framework. I
was able to get the desired behavior by overriding the WizardDialog#run
method to spawn a thread to run the operation and the UI thread waits until
the new thread returns. The culprit in this case was the ModalContextThread
which was spinning through the event loop.
"Nick Edgar" <nick_edgar@_no.spam.please_.ca.ibm.com> wrote in message
news:dof5g5$h0o$1@utils.eclipse.org...
> Eli,
> Sorry for the delay. I looked for your post earlier, but must have missed
> it.
> loop while waiting for the operation to complete, in order to keep the UI
> responsive.
> Nick
>> thread.
Re: Progress Monitor threading leads to undesired code execution order [message #296947 is a reply to message #296923] Thu, 05 January 2006 10:48 Go to previous messageGo to next message
Why even bother spawning a thread in this case? If the UI thread is
blocked until the thread terminates, why not just do the work in the UI
thread?
In either case, how do you report progress, and get the UI to update the
shown progress without spinning the event loop?
Nick
>>Eli,
>>it.
>>responsive.
>>Nick
>>>thread.
Re: Progress Monitor threading leads to undesired code execution order [message #296948 is a reply to message #296947] Thu, 05 January 2006 10:52 Go to previous messageGo to next message
The reason you use another thread is because when the UI thread is
blocked it looks really bad to a user. Nothing is repainted. If you
cover the window and show it again it is left unpainted.
The progress monitor allows you to show progress during the whole time
the other thread is running. So the other thread can say it's 50%
complete and the progress monitor will move to 50%. If you were running
on the UI thread the monitor would never get a chance to paint and say this.
> thread?
> Nick
>> framework. I was able to get the desired behavior by overriding the
>> WizardDialog#run method to spawn a thread to run the operation and the
>> UI thread waits until the new thread returns. The culprit in this
>> case was the ModalContextThread which was spinning through the event
>> loop.
>>> Eli,
>>> missed it.
>>> event loop while waiting for the operation to complete, in order to
>>> keep the UI responsive.
>>> responsive during your operation?
>>> Nick
>>>> separate thread.
>>>> while the progress monitor is working.
>>>> to filter out other events until the progress monitor completes.
Rich Kulp
Re: Progress Monitor threading leads to undesired code execution [message #297002 is a reply to message #296948] Fri, 06 January 2006 09:56 Go to previous messageGo to next message
So it sounds like you are actually processing UI events?
Re: Progress Monitor threading leads to undesired code execution [message #297036 is a reply to message #297002] Fri, 06 January 2006 13:04 Go to previous messageGo to next message
Yes. The Progress monitor simply spins on the UI thread. The other
shells of the application have been disabled. So they will still paint
but you can't click on them. So that way you other thread can process
while the UI thread is still being handled and painting done.
Rich Kulp
Re: Progress Monitor threading leads to undesired code execution [message #297051 is a reply to message #297036] Fri, 06 January 2006 14:19 Go to previous messageGo to next message
So it seems like this won't solve the original problem.
Since events are being processed, his step 4 will still occur before step 5.
Re: Progress Monitor threading leads to undesired code execution [message #297061 is a reply to message #297051] Fri, 06 January 2006 17:44 Go to previous messageGo to next message
The UI thread is looping until the other thread completes. Inside the UI
loop the progress monitor is updated manually. As long as
Display#readAndDispatch isn't called the correct order will occur.
"Nick Edgar" <nick_edgar@ca.ibm.com> wrote in message
news:14740232.1136575204702.JavaMail.root@cp1.javalobby.org...
> 5.
Re: Progress Monitor threading leads to undesired code execution [message #297066 is a reply to message #297061] Fri, 06 January 2006 18:49 Go to previous messageGo to next message
But then you run into the problem that nothing paints and the progress
monitor won't advance. In that case you might as well just run in line
without invoking a progress monitor.
>>5.
Rich Kulp
Re: Progress Monitor threading leads to undesired code execution [message #297426 is a reply to message #297066] Fri, 13 January 2006 09:55 Go to previous message
It does paint, you have to manually set the progress in the UI loop that is
waiting on the other thread to complete. So rather than using the
inderterminate progress indicator you have to set the progress as a
percentage and keep resetting it at 100.
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:dpmvms$7rh$1@utils.eclipse.org...
>>>5.
> Rich Kulp
Previous Topic:3.2 M4 - org.eclipse.core.commands.common.EventManager cannot be resolved
Next Topic:TableViewer losing its virtualization in a Section
Current Time: Wed Sep 03 08:47:53 EDT 2025
Powered by FUDForum. Page generated in 0.10072 seconds
