Home » Eclipse Projects » Eclipse Platform » programmatically re-arrange the editors inside the editors view
programmatically re-arrange the editors inside the editors view [message #296120] Thu, 15 December 2005 07:23 Go to next message
Originally posted by: ReplyToNewsgroup.abc.com
How do I programmatically re-arrange the editors inside the editors view
(i.e. after two editors are open - place one editor to the left and the
other to the right). This can be done inside the actual IDE.
Thanks.
Re: programmatically re-arrange the editors inside the editors view [message #296250 is a reply to message #296120] Mon, 19 December 2005 08:30 Go to previous messageGo to next message
You mean re-arrange their tabs? You can't do that programmatically (in
my workspace, it doesn't make sense since I only have one tab).
You can make an editor active (tab highlighted, contents visible) by
using the IWorkbenchPage#activate(...) method.
Later,
PW
Re: programmatically re-arrange the editors inside the editors view [message #296441 is a reply to message #296250] Thu, 22 December 2005 03:23 Go to previous messageGo to next message
I want to be able to open two editors and place them next to eachother
programmatically. In Eclipse 3.1 you can re-arrange the editors next to each
other on the left and right side (for example for comparing two files). You
can also place two editors top and bottom or four editors one in each corner
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:do5r45$qom$1@utils.eclipse.org...
> Later,
> PW
Re: programmatically re-arrange the editors inside the editors view [message #296788 is a reply to message #296441] Tue, 03 January 2006 09:10 Go to previous message
Ah, move open editors to new editor stacks ...
I've seen examples of programmitically doing this in some tests, but
IIRC it was accomplished using internal APIs and faking a drag and drop.
The tests are in the org.eclipse.ui.tests plugin, available from CVS.
Later,
PW
Previous Topic:Junit NoClassDefError when attempting to access a Static
Next Topic:Outline View
Current Time: Thu Sep 18 22:45:49 EDT 2025
Powered by FUDForum. Page generated in 0.03017 seconds
