Home » Newcomers » Newcomers » DrJava plugin??
DrJava plugin?? [message #29588] Fri, 25 February 2005 09:31 Go to next message
Originally posted by: gfghh.hhh.com
I have downloaded the drJava plugn found at:
http://drjava.sourceforge.net/
I have extracted it to:
H:\eclipse\plugins
When I restart eclipse and choose:
Window->Open Perspective->Other...)
i can't find the plugin
can someone help?
Re: DrJava plugin?? [message #29626 is a reply to message #29588] Fri, 25 February 2005 10:39 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
Extracting into eclipse/plugins is not enough.
Since Eclipse 3.0 you need to tell the platform to check for new plugin.
This is for performance reasons.
Run eclipse once with "eclipse -clean".
Chris Laffra, http://eclipsefaq.org
"bunallo" <gfghh@hhh.com> wrote in message
news:cvncqu$qp$1@www.eclipse.org...
> H:\eclipse\plugins
> can someone help?
Re: DrJava plugin?? [message #29628 is a reply to message #29626] Fri, 25 February 2005 10:46 Go to previous messageGo to next message
"Chris Laffra" <Chris_Laffra@ca.ibm.com> skrev i en meddelelse
news:cvngr9$n59$1@www.eclipse.org...
just did the following
start -> run -> H:\eclipse\eclipse.exe "eclipse -clean"
restarted eclipse, but still cannot find the DrJava plugin
Re: DrJava plugin?? [message #29630 is a reply to message #29628] Fri, 25 February 2005 11:28 Go to previous messageGo to next message
Try
start -> run -> H:\eclipse\eclipse.exe -clean
instead.
Also make sure that the zip of the plug-in you download does not contain
the plugins folder in the folder path. In that case, you'd need to
unzip to the eclipse directory rather than the plugins subdirectory.
Hope this helps,
- Jeff
Re: DrJava plugin?? [message #29632 is a reply to message #29630] Fri, 25 February 2005 11:59 Go to previous message
"Jeff Myers" <myersj@gmail.com> skrev i en meddelelse
news:cvnjnh$6ec$1@www.eclipse.org...
> Try
> instead.
Thank you!
Previous Topic:Problems with JRE/JDK
Next Topic:CVS repository tuning
Current Time: Sat Jul 19 01:15:43 EDT 2025
Powered by FUDForum. Page generated in 0.08504 seconds
