Home » Modeling » OCL » Transformate OclText2OclModel
Transformate OclText2OclModel [message #29605] |
Mon, 25 June 2007 04:08  |
Originally posted by: Matthias_Krebber.mra.man.de
I try to solve the task to transformate Ocl Constraints considered in an
OCL File (*.ocl) into Java Code. In order to solve this task first I want
to create an OCL Model (Text2Model Transformation). I want to use OCL MDT
to solve this.
To get experiences with MDT OCL I have written a Test Class. I have taken
your OCLTest.uml Model + test_constraints.ocl of your Testclasses and
tried to produce an ocl model (*.xmi)
I want to use my application standalone so I first have made some
registrations. (URIConverter.URI_MAP, Environment.Registry.INSTANCE,
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ),
EPackage.Registry.INSTANCE,
Resource.Factory.Registry.INSTANCE.getProtocolToFactoryMap() )
Examples:
// local Variables
/** contains the absolute path of the uml2.uml.resource jar file. */
String umlResources = "jar:file:" + getUMLArchive(new
JarArchiveFileNameFilter("org.eclipse.uml2.uml.resources_")) + "!";
String oclStdlib = "jar:file:" + getUMLArchive(new
JarArchiveFileNameFilter("org.eclipse.ocl.uml_")) + "!";
URIConverter.URI_MAP.put(URI.createURI("http://www.eclipse.org/ocl/1.1.0/oclstdlib.uml"),URI.createURI(oclStdlib
+"/model/oclstdlib.uml"));
URIConverter.URI_MAP.put(URI.createURI(UMLResource.LIBRARIES _PATHMAP),URI.createURI(umlResources
+ "/libraries/"));
URIConverter.URI_MAP.put(URI.createURI(UMLResource.METAMODEL S_PATHMAP),URI.createURI(umlResources
+ "/metamodels/"));
URIConverter.URI_MAP.put(URI.createURI(UMLResource.PROFILES_ PATHMAP),URI.createURI(umlResources
+ "/profiles/"));
At next Step I load the UML Model together with the UML Metamodel and the
UML Primitive Types library into a resource Set, create the outputResource
and at this into an OCL facade.
/** Resource Set, containing the referenced Resources of the UML Model */
ResourceSet rs = this.getResources(pathUMLModel);
/** This Resource is used to persist the OCL Model*/
this.outputResource = rs.createResource(URI.createFileURI(new
File(locationOutputModel).getAbsolutePath()));
// Create the ocl facade. OCL Constraints are embedded in an UML
Environment
this.oclEnvironment = OCL.newInstance(new
UMLEnvironmentFactory(this.outputResource.getResourceSet()),
this.outputResource);
this.oclEnvironment.setEvaluationTracingEnabled(true);
this.oclEnvironment.setParseTracingEnabled(true);
Then I parse the ocl_constraints and add the constraints to the output
Resource.
// parse the OCL Constraints -> AST
List<Constraint> constraints = this.parseOclConstraints(this.oclEnvironment,
pathOclText);
// Add the AST to the output Resource
this.outputResource.getContents().addAll(0,constraints);
Add last step I persist the output model
this.outputResource.save(Collections.singletonMap(XMLResourc e.OPTION_SAVE_TYPE_INFORMATION,
Boolean.TRUE));
But If I want to open the created *.xmi File I get error messages like
this:
UnresolvedReferenceException: Unresolved reference
'/0/@specification/self'.
(platform:/resource/OCLText2OclModel/model/output/oclModel.x mi, 18, 104)
in XMI File:
<argument xsi:type="ocl.uml:VariableExp" name="self"
referredVariable="/0/@specification/self">
How can I dissolve this errors?
Re: Transformate OclText2OclModel [message #30319 is a reply to message #29605] |
Mon, 25 June 2007 17:00   |
Hi, Matthias,
The Ecore binding of the OCL metamodel extends the Ecore metamodel, so it
inherits the hierarchical-name-based fragment URIs of Ecore's
ENamedElements (viz. the EModelElementImpl methods eURIFragmentSegment and
eObjectForURIFragmentSegment).
It looks like something is going wrong with the resolution of these URI
fragments. Would you mind raising a bug for that?
In the mean-time, to work around this, try using a custom resource
implementation that uses extrinsic UUIDs as URI fragments, instead of the
fragments computed by the objects, themselves.
Christian
> to solve this.
> Examples:
> // local Variables
> + "/libraries/"));
> + "/metamodels/"));
> + "/profiles/"));
> Environment
> Resource.
> this.parseOclConstraints(this.oclEnvironment, pathOclText);
> Boolean.TRUE));
> this:
> in XMI File:
Re: Transformate OclText2OclModel [message #30598 is a reply to message #30391] |
Tue, 26 June 2007 10:15   |
Hi, Matthias,
The meta-metamodel for OCL is UML, which for all practical purposes is
equivalent to Ecore because the OCL.uml model is used as the source for
OCL.genmodel, from which the code is generated via the OCL.ecore.
OCLCST.uml is the model of the OCL concrete syntax, which is an intermediate
representation of OCL text. The OCL parser works in two phases: parsing
the text into the concrete-syntax tree (CST), then parsing this tree to
produce the abstract-syntax tree (AST).
The UML binding model is OCLUML.uml. For any UML model, you will always see
a corresponding Ecore model because that is an artifact of the EMF code
generation process, and the schema of an EPackage is always represented as
Ecore despite its having originated in a UML model.
Yes, the M1 layer of models is in your world: the UML, Ecore, Library,
Employee, etc. models on which you are defining OCL constraints and
queries. You can serialize OCL constraints as separate resources or
embedded in your models; that is up to you.
Dynamic EObjects are one option for M0 models, yes, but so are the instances
of Java classes that you generate using EMF (the static EObjects).
Christian
> Thank your for your answer. I will raise a Bug for this.
> I have another question about MDT OCLŽs Metadata Architecture.
> Like Meta Object Facility (MOF) defines, there are existing four Meta
> Layers:
> M3: The MDT OCL Metametamodel is conform to ECORE (ECORE Metamodel)
> -> Are the metametamodels at org.eclipse.ocl/model (OCL.ecore,
> OCL.uml)?
> -> I donŽt understand the models OCLCST.ecore and OCLCST.uml at
> M2: There are existing bindings for UML and ECORE (Extensions of ECORE
> Metamodell). These are the metamodels.
> -> ECORE Binding: org.eclipse.ocl.ecore/model OCLEcore.ecore ?
> -> UML Binding: org.eclipse.ocl.uml/model OCLUML.uml or OCLUML.ecore ?
> M1: Are these the models that I may serialize after parsing?
> - For example: oclOutput.xmi
> M0: Dynamic EMF Objects
Re: Transformate OclText2OclModel [message #30952 is a reply to message #30882] |
Wed, 27 June 2007 10:36   |
Hi, Matthias,
For the purposes of ATL, the metamodel of MDT OCL can be considered to be
Ecore (with UML2-generated models, you can always choose to work with them
on UML or on Ecore terms since the code-generation always transforms the
UML to Ecore anyway). Moreover, since you are not dealing with UML models,
anyway, you would be using OCL's Ecore binding, so you are working only in
Ecore terms.
You should not be losing information about the kind of constraint if you are
persisting constraints (rather than just the expressions). Ecore
constraints (the org.eclipse.ocl.ecore.Constraint metaclass) have a
"stereotype" property whose value is "invariant", "precondition", etc.
according to the kind of constraint. In UML constraints
(org.eclipse.uml2.uml.Constraint), these values are applied as keywords to
the Constraint element. The values of this stereotype attribute are
enumerated in the org.eclipse.ocl.utilities.UMLReflection interface.
The metamodel for the org.eclipse.ocl.ecore.Constraint is Ecore.
HTH,
Christian
> Okay,
> Like I told I want to generate an OCL Model with MDT OCL. (Transformate
> OclText2OclModel) After solving this task I will use ATL to transformate a
> Java Model conforming to a Java Metamodel (Transformate
> OCLModel2JavaModel)
> ATL needs as input model(s) conforming to their metamodel(s) and
> transformate target model(s) conforming to their metamodel(s).
> To work with ATL I have to know the input metamodel of my OCL Model.
> Actually I just want to persist the OCL Text (*.ocl file) into a model
> conforming to a metamodel. The metamodel has either be conformed to ecore
> or to MOF because this are the metamodel technologies ATL provides. It is
> important for me not to lose the informations about the OCL Constraint
> types like pre:, post:, inv: etc. I do not want to evaluate OCL
> Constraints against an UML model.
> I parse the Ocl Text in order to get the AST. First, after parsing, I
> persisted the OCL Expression into a XMI Model. But I noticed that I lose
> informations about the constraint type (pre, post etc.) For now I persist
> the Constraint themselves because it contains the informations about the
> OCL Type.
> Is the metamodel of these Constraint Model UML (UML.Metamodel.uml) ?
> (Constraints are embedded in an UML Model)
> Is there another alternative to persist the OCL Text into a model without
> losing all informations with MDT OCL (for example persist the AST Model
> conforms to a AST metamodel)? (I do not want to persist the OCL
> Constraints together with the according UML Model)
Re: Transformate OclText2OclModel [message #31195 is a reply to message #31091] |
Thu, 28 June 2007 10:06  |
Hi, Matthias,
If you are parsing OCL constraints on UML models, then usually the
org.eclipse.ocl.uml.OCL is the better fit because UML's metamodel is UML
(i.e., the UML2 project defines the UML metamodel using UML and generates
the code from that UML model).
However, since Ecore is more convenient for your transformation, the
org.eclipse.ocl.ecore.OCL should work, too. The main disadvantage is that
it does not support such UML-isms as:
- disallowing calls on Operations for which isQuery is not true
- navigating non-navigable association ends
- (others that are less relevant because the UML metamodel does not employ
constructs such as association classes and association-end qualifiers)
Can you describe the problems that you are having? Any error messages,
stack traces, log entries would be useful. It really should just *work* as
it does for Ecore models.
Christian
> thank you for the answer.
> First I tried to use org.eclipse.ocl.ecore.OCL but I get problems to parse
> ocl constraints that are embedded in an UML Model. Therefore I exchanged
> to org.eclipse.ocl.uml.OCL.
> The idea of my work is, that a software architect creates for example with
> MagicDraw an UML model together with ocl constraints.
> These embedded constraints, first I want to put into a separate file
> (*.ocl)
> At next step I want to parse them and build the ocl model. After that I
> want to transformate this Ocl model into a Java model and than into Java
> code. (MDA)
> How can I parse ocl constraints, based on an UML Model (for example
> created with MagicDraw) with org.eclipse.ocl.ecore binding?
Current Time: Tue Jul 22 23:04:14 EDT 2025
Powered by FUDForum. Page generated in 0.46798 seconds
