Home » Archived » Test and Performance Tools Platform (TPTP) » No data problem with TPTP 4.0, Eclipse 3.1
No data problem with TPTP 4.0, Eclipse 3.1 [message #29494] Fri, 02 September 2005 16:26 Go to next message
I downloaded and installed TPTP 4.0 via the update site, and then I
installed the Agent Controller. I went to profile an application and
everything appeared to be working fine (the app and host showed up in
Profiling Monitor), but when I try to open any of the analysis tabs
every one of them shows "No data is available for display.". Just to
check, I ran the profile again with a full set of profiling (memory,
execution, code coverage) and additionally specified that the profiling
data should be sent to a file. When the run was complete, the analysis
tabs still show "No data...", but I have a .trcxml file where I told it
to put the profile data and it appears to be full of trace info. Have I
missed a step to get the profiling data into the profile analysis
engine? I went through the tutorial here:
http://www.eclipse.org/tptp/home/documents/tutorials/profili ngtool/profilingexample_32.html
(I know it's 3.2 but it looks like it should work) and I got the same
results. Any leads would be appreciated. Can I just import the profiling
data I dumped to a file?
Derek
Re: No data problem with TPTP 4.0, Eclipse 3.1 [message #29528 is a reply to message #29494] Fri, 02 September 2005 17:00 Go to previous message
Derek Chen-Becker wrote:
OK, I figured out what I had wrong. The default filter for the profiling
filter set excludes org*, which is the package that my code is in. I
guess the intent was to filter out libraries, but I think that this
should be noted somewhere in the documentation/tutorials.
Derek
Previous Topic:TPTP and Testing WebApps
Next Topic:TPTP support for new Java 5 features?
Current Time: Sat Jul 26 19:21:39 EDT 2025
Powered by FUDForum. Page generated in 0.25553 seconds
