| NoClassDefFoundError in packaged plugin [message #294759] |
Thu, 17 November 2005 10:31  |
hi,
I have developed a plugin which works fine when i run it on the runtime
workbench but when I have packaged it and deployed it on eclipse, and when
I activate a control thats supposed to open up a ContainerSelectionDialog,
I get a NoClassDefFoundError, The stack trace is as follows,
java.lang.NoClassDefFoundError:
org/eclipse/ui/dialogs/ContainerSelectionDialog
at
com.vijai.matrix.plugin.ui.Views.ExistingFileView.displayJPO Program(ExistingFileView.java:388)
at
com.vijai.matrix.plugin.ui.Views.ExistingFileView.handleDoub leClick(ExistingFileView.java:295)
at
com.vijai.matrix.plugin.ui.Views.ExistingFileView.access$3(E xistingFileView.java:293)
at
com.vijai.matrix.plugin.ui.Views.ExistingFileView$5.mouseDou bleClick(ExistingFileView.java:208)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:141)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
Is there someway I can resolve it
Vijai
| Re: NoClassDefFoundError in packaged plugin [message #294823 is a reply to message #294759] |
Fri, 18 November 2005 04:30  |
I vaguely remember that your described problem occured in cases,
when export was done. Please try the following: Before doing your export
go into your filesystem and delete manually **all** files from the
configuration directory, where you want to export in! There exist cases
where the export process does not completely clean the target directory.
Hope that helps,
Daniel Krügler
FUDForum. Page generated in 0.03223 seconds
