Home » Eclipse Projects » Eclipse Platform » Is there a JFace directory dialog that presents a list of files found given the starting directory a
Is there a JFace directory dialog that presents a list of files found given the starting directory a [message #294379] Thu, 10 November 2005 17:27 Go to next message
given the starting directory and the file extension?
Thanks for any tips!
Re: Is there a JFace directory dialog that presents a list of files found [message #294391 is a reply to message #294379] Thu, 10 November 2005 23:34 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Cooked up one fastly with org.eclipse.ui.dialogs.ElementListSelectionDialog. Try this ...
private void openFileList(String dirPath)
ElementListSelectionDialog dlg = new ElementListSelectionDialog(window.getShell(), new FileLblProvider());
dlg.setMultipleSelection(true);
File directory = new File(dirPath);
dlg.setElements(directory.listFiles());/* filter just files if you need to */
dlg.open();
class FileLblProvider extends LabelProvider
public String getText(Object element) {
return ((File)element).getName();
public Image getImage(Object element) {
return null; /* TODO: Show file/folder image */
Hope that helps.
Venkat
Re: Is there a JFace directory dialog that presents a list of files found [message #294392 is a reply to message #294379] Thu, 10 November 2005 23:36 Go to previous messageGo to next message
	dlg.open();
Hope that helps.
Venkat
Re: Is there a JFace directory dialog that presents a list of files found [message #295013 is a reply to message #294392] Mon, 21 November 2005 19:38 Go to previous message
Thank you very much!
> 	dlg.open();
> Hope that helps.
> Thanks
> Venkat
Previous Topic:Keys don't work
Next Topic:tree viewer and expaneded state
Current Time: Sat Nov 08 16:33:45 EST 2025
Powered by FUDForum. Page generated in 0.04934 seconds
