Home » Eclipse Projects » Eclipse Platform » using the compare API
using the compare API [message #294206] Mon, 07 November 2005 05:53 Go to next message
hi,
In my plugin I would like to compare 2 files, for this purpose I would
like to use the org.eclipse.compare API.I searched on the internet for
some proper examples or tutorials for this purpose but couldnt find any. I
also found that for this purpose I need to use the "ContentMergeViewer" or
the "TextMergeViewer". Can someone please shed more light on these or
direct me to some examples on this topic.
thanks,
vijai
Re: using the compare API [message #294214 is a reply to message #294206] Mon, 07 November 2005 08:30 Go to previous messageGo to next message
hi,
is it possible to compare 2 files/IFiles using the eclipse compare API
and if so, how can it be done.
thanks
Vijai
Re: using the compare API [message #294216 is a reply to message #294206] Mon, 07 November 2005 08:35 Go to previous messageGo to next message
Vijai,
One class you can extend to get a two or three way compare is the
CompareEditorInput class. Have a look at the ResourceCompareInput class
in the org.eclipse.compare plugin for an example.
Michael
Vijai wrote:
> hi,
> I also found that for this purpose I need to use the
> "ContentMergeViewer" or the "TextMergeViewer". Can someone please shed
> more light on these or direct me to some examples on this topic.
> thanks,
> vijai
Re: using the compare API [message #294229 is a reply to message #294216] Mon, 07 November 2005 10:18 Go to previous messageGo to next message
hi michael,
thanx for the reply...I am trying to implement the compare feature by
subclassing CompareEditorInput()
The class which extends CompareEditorInput is as follows,
class CompareInput extends CompareEditorInput {
public CompareInput(CompareConfiguration arg0) {
super(arg0);
// TODO Auto-generated constructor stub
protected Object prepareInput(IProgressMonitor arg0)
throws InvocationTargetException, InterruptedException {
// TODO Auto-generated method stub
return null;
When i try to create a CompareEditorInput object out of the class,
passing a CompareConfiguration to its constructor, it throws a
nullpointerException at the place where i create the CompareConfiguration,
Can someone tell me what went wrong, I am still a newbie in Plugin
development...
private void testTextMerge() {
try {
-> CompareConfiguration config=new CompareConfiguration();
CompareEditorInput compare=new CompareInput(config);
} catch (Exception e) {
e.printStackTrace();
The line indicated by the arrow throws the nullpointerexception,
thanks
Vijai
Re: using the compare API [message #294255 is a reply to message #294229] Tue, 08 November 2005 05:48 Go to previous messageGo to next message
Vijai wrote:
> hi michael,
> super(arg0);
> return null;
> development...
> try {
> thanks
> Vijai
I guess i figured out that anything thats got to do with CompareUIPlugin
throws a NullPointerException, for example creating a new
CompareConfiguration(), gets redirected to the method, new
CompareConfiguration(CompareUIPlugin.getPreferenceStore()); and this
statement throws a null pointer exception
Are there any prerequisites that need to be done before calling the
CompareUIPlugin.getPreferenceStore() method, like for example(creating an
empty file somewhere on the file system or calling some other method
before it)
I am attaching the Stack trace of the exception
at
com.vijai.matrix.plugin.ui.Views.JPOCommitView.testTextMerge (JPOCommitView.java:268)
at
com.vijai.matrix.plugin.ui.Views.JPOCommitView.access$0(JPOC ommitView.java:265)
at
com.vijai.matrix.plugin.ui.Views.JPOCommitView$6.widgetSelec ted(JPOCommitView.java:239)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
The start of the exception points to the super() in the following code,
super(new CompareConfiguration());
return null;
Any help or tips is appreciated,
thanks
Vijai
[75% RESOLVED]Re: using the compare API [message #294307 is a reply to message #294255] Wed, 09 November 2005 08:25 Go to previous messageGo to next message
hi,
I have finally managed to compare 2 pieces of text and have managed to
diplay it on a dialog. For this I have used the TextViewMerger, but I
would like to open it on a editor page or the page similar to which
eclipse opens up "compare" results...Do i need to use some extension point
or is there any other way to display the result of the TextMergeViewer...
Thanq
vijai
Re: [75% RESOLVED]Re: using the compare API [message #294312 is a reply to message #294307] Wed, 09 November 2005 11:29 Go to previous messageGo to next message
You'll want to use a CompareEditorInput for that. As I mentioned in my
previous post you should have a look at the ResourceCompareInput in the
compare plugin. If you search for references to that class you will see
how to open an editor as well.
Michael
Vijai wrote:
> hi,
> point or is there any other way to display the result of the
> TextMergeViewer...
> Thanq
> vijai
[RESOLVED finally]Re: using the compare API [message #294339 is a reply to message #294312] Thu, 10 November 2005 05:59 Go to previous messageGo to next message
> Michael
> Vijai wrote:
>> hi,
>> TextMergeViewer...
>> Thanq
>> vijai
thanks Michael,
I finally managed to get the compare editor open and show me the
differences, at first I was trying to use TextMergeViewer(subclass of
ContentMergeViewer) and it showed me differences good enough but it
wouldnt maximize and was always the size of a thumbnail,
Now I used the CompareEditorInput and it works fine now, but the colors
that were present in the TextMergeViewer are missing,but thats ok...
The code i used is as following,
class EditorInput extends CompareEditorInput {
public EditorInput(CompareConfiguration configuration) {
super(configuration);
protected Object prepareInput(IProgressMonitor monitor)
Differencer d = new Differencer();
Object diff = d.findDifferences(false, new NullProgressMonitor(), null,
null, new Input("difference1"), new Input(
"difference2"));
return diff;
class Input implements ITypedElement, IStreamContentAccessor {
String fContent;
public Input(String s) {
fContent = s;
public String getName() {
return "name";
public Image getImage() {
return null;
public String getType() {
return "txt";
public InputStream getContents() throws CoreException {
return new ByteArrayInputStream(fContent.getBytes());
and the command that opens the Compare Editor,
CompareUI.openCompareDialog(new EditorInput(
new CompareConfiguration()));
thanks for the help,
Vijai
Re: [RESOLVED finally]Re: using the compare API [message #987103 is a reply to message #294339] Fri, 23 November 2012 08:46 Go to previous message
new CompareConfiguration() is still giving me NoClassDefFoundError.
I have implemented this in our RCP app. Added the org.eclipse.compare dependency in pom file and have installed it into local maven repo as well.
However one thing i see in the Manifest.MF (Dependency tab) is its not showing up in 'Available versions to match" section when we right click and select 'Properties' on the org.eclipse.compare plugin.
Am i missing something here ?, could someone guide me here.
Previous Topic:Unable to create object of SAXBuilder.
Next Topic:example of opening an IFolder and a filesystem directory in a CompareEditor?
Current Time: Wed Jul 23 16:15:56 EDT 2025
Powered by FUDForum. Page generated in 0.09853 seconds
