Home » Archived » XML Schema Definition (XSD) » Convert XMI to XSD.
Convert XMI to XSD. [message #29361] Fri, 12 September 2003 05:40
Originally posted by: jan.odstrcil.systinet.com
is here any way how to create XSD from XMI using EMF/XSD ?
Exactly I have Class Diagram serialized in XMI and need to get correspondent
XSD file that describes same data from XSD point of view.
Jan
Re: Convert XMI to XSD. [message #29399 is a reply to message #29361] Thu, 11 September 2003 18:26 Go to previous message
Jan,
The only way to do this would be to import the class diagram as an Ecore model
and then to use the code generator to generate the model; if the "Generate
Schema" property set to true, the generation step will produce .xsd files
corresponding to the XMI serialization of the model. Unfortunately EMF doesn't
support importing directly from an XMI serialization of a class diagram, so this
may not be very helpful. The resulting schema is pretty ugly too, and we are
currently looking at how to generate better schemas...
Jan Odstrcil wrote:
> Thanks
> Jan
Re: Convert XMI to XSD. [message #578031 is a reply to message #29361] Thu, 11 September 2003 18:26 Go to previous message
Jan,
Jan Odstrcil wrote:
> Thanks
> Jan
Previous Topic:unexpected differences with/without target namespace
Next Topic:Convert XMI to XSD.
Current Time: Sat Jul 26 08:07:39 EDT 2025
Powered by FUDForum. Page generated in 0.04027 seconds
