Home » Eclipse Projects » Eclipse Platform » Dynamically check out a file under source control with a plugin
Dynamically check out a file under source control with a plugin [message #292543] Fri, 07 October 2005 05:03 Go to next message
Originally posted by: john.obyrne.gmail.com
I am doing a plugin to extend the IDE to be able to generate code and I need
to check out the file I am modifying automatically. (this is the default
behavior of any Editor in Eclipse).
I am modifying the file using the IFile.setContents(...) method with an
InputStream. I thought at first that this method would automatically check
out the file but this is not the case.
I had a look on the org.eclipse.team.core package but didn't find any
methods to be able to check out a file having an IFile as input.
The only thing I found is that: RepositoryProvider.isShared(IProject) so I
can be able to know if a project is under source control.
Does anyone know how to manipulate an IFile under source control ?
John O'Byrne
Re: Dynamically check out a file under source control with a plugin [message #292560 is a reply to message #292543] Fri, 07 October 2005 07:05 Go to previous messageGo to next message
Originally posted by: daniel.megert.eclipse.org
John O'Byrne wrote:
>Hello,
Take a look at IWorkspace.validateEdit().
Dani
>Thanks,
>John O'Byrne
Re: Dynamically check out a file under source control with a plugin [message #292569 is a reply to message #292560] Fri, 07 October 2005 08:09 Go to previous message
Thanks that works exactly as I wanted !
"Daniel Megert" <daniel.megert@eclipse.org> wrote in message
news:di5kpo$b5l$2@news.eclipse.org...
> John O'Byrne wrote:
>>Hello,
>>need to check out the file I am modifying automatically. (this is the
>>default behavior of any Editor in Eclipse).
> Dani
>>Thanks,
>>John O'Byrne
Previous Topic:form editor
Next Topic:measure build time
Current Time: Thu Nov 06 10:50:56 EST 2025
Powered by FUDForum. Page generated in 0.02842 seconds
