Home » Eclipse Projects » Eclipse Platform » Slowdown after "Run"
Slowdown after "Run" [message #291557] Mon, 19 September 2005 15:54 Go to next message
Hello all,
I'm running Eclipse 3.1 on my iBook (Mac OS 10.4.2).
I run the Swing application I am creating, which is pretty bog standard
and rather small at the moment. A simple JFrame is called, with a few
components. When I quit the application (OPTION-Q), and return to my
editor, everything is slow. There is a lag even with typing. Code
completion lag is extremely noticeable.
The most obvious effect is scrolling. After a single run of my
application, scrolling is no longer smooth - it is now reduced to ~2fps!
Simply restarting Eclipse solves this problem, but it is rather irritating
having to do this every time I "Run".
No special "Run" settings were used. I experience the same effect with
1.4.2 and 1.5 JVM. Other than that, I really cant give any more
information to help you I'm afraid.
Re: Slowdown after "Run" [message #291575 is a reply to message #291557] Tue, 20 September 2005 09:15 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
I seem to recal there being a known problem on the Mac VM about this. What version of java are you using? (java -version from Terminal.app). There was an update for Java a few days ago that probably required a restart... don't know if that may have caused the problem.
Re: Slowdown after "Run" [message #291618 is a reply to message #291575] Wed, 21 September 2005 03:53 Go to previous messageGo to next message
No luck I'm afraid. I have just finished installing that update you
mentioned (available through "Software Update...." on the menubar.
My old version:
java version "1.4.2_07"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_07-215)
Java HotSpot(TM) Client VM (build 1.4.2-50, mixed mode)
My new version:
java version "1.4.2_09"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_09-232)
Java HotSpot(TM) Client VM (build 1.4.2-54, mixed mode)
I can also confirm that this is not necessarily an Eclipse issue - when I
run the program at the command prompt, the same thing happens to Eclipse.
Therefor, could somebody refer me to the right place to report a bug?
Re: Slowdown after "Run" (on Mac OS X) [message #291620 is a reply to message #291618] Wed, 21 September 2005 06:18 Go to previous messageGo to next message
Bug reports for Eclipse are at http://bugs.eclipse.org (free registration required).
Bug reports for Apple are at http://bugreport.apple.com (ADC membership required, maybe free registration also)
In any case, this is bug is already on the radar (sic) at both Eclipse and Apple:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95475
It's a Mac OS X bug, as opposed to an Eclipse bug. There are reports that it's to do with quitting a second app whilst Eclipse is/isn't in the foreground:
"If I run my app in Eclipse and quit from inside my app, performance immediately goes down the tubes. If instead, I terminate the app from inside Eclipse, things remain fine."
I don't know if that information is of any use to you ... hopefully 10.4.3 (which alledgedly fixes this) will be out in the next couple of weeks.
Re: Slowdown after "Run" (on Mac OS X) [message #291664 is a reply to message #291620] Wed, 21 September 2005 12:48 Go to previous message
Thanks for your help - this sounds exactly like the problem I am having.
Cheers
Previous Topic:Plugin.xml and registering extensions
Next Topic:How to get the breakpoint visible as well as a quickfix icon on the same line?
Current Time: Sat Oct 25 06:54:50 EDT 2025
Powered by FUDForum. Page generated in 0.04308 seconds
