Home » Eclipse Projects » Eclipse Platform » plugin.properties with dots in labels
plugin.properties with dots in labels [message #290651] Mon, 29 August 2005 08:33 Go to next message
Originally posted by: a.schuring.topdesk.nl
I encountered a strange artifact when exporting my plugin to a jar file:
all translatable labels with dots were suddenly intranslatable. Replacing
the dots with underscores resolved the problem.
For example, I had a preference page label like %plugin.preferencePage and
a corresponding entry in plugin.properties. When deployed as a jar, the
preference page had the label "%plugin.preferencePage" instead of the
translated name.
When deploying the same plugin as files (instead of as .jar), the problem
did not occur.
Is this by design?
(btw I'm using Eclipse 3.1)
Arno
Re: plugin.properties with dots in labels [message #290667 is a reply to message #290651] Mon, 29 August 2005 11:24 Go to previous messageGo to next message
Open the jar and make sure the plugin.properties file is in the root of
the jar.
Rich Kulp
Re: plugin.properties with dots in labels [message #290713 is a reply to message #290651] Tue, 30 August 2005 10:52 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Depending on which version of Eclipse you're running, you might want to take a look at http://help.eclipse.org/help31/topic/org.eclipse.platform.do c.isv/guide/product_def_nl.htm
Specifically:
The shape of NL fragments has evolved slightly since 2.1. Previously all translation files (including the plugin.properties) were provided in a jar. This was inconsistent since the plugin.properties file was provided at the root of the plug-in.
To adapt your NL fragment to the new model, remove the plugin.properties translation files from the jar and put them at the root of the fragment as siblings of fragment.xml. For example, the new shape of the NL fragment for org.eclipse.ui.workbench is the following
Re: plugin.properties with dots in labels [message #291475 is a reply to message #290713] Fri, 16 September 2005 07:26 Go to previous messageGo to next message
Originally posted by: mdiggory.apache.org
> Specifically:
I'm noticing that with the change to OSGi NLS that the WorkBenchMessages
in the translation pack are now no longer working because to this same
issue, is someone maintaing this translation pack?
http://download.eclipse.org/eclipse/downloads/drops/L-3.0.1_ Translations-200409161125/index.php
Is there an upgraded translation pack?
-Mark Diggory
Re: plugin.properties with dots in labels [message #291477 is a reply to message #291475] Fri, 16 September 2005 07:55 Go to previous messageGo to next message
Mark,
I'm not absolutely sure, but I think the new translation package will be
available with 3.1.1 around the end of the month. Probably the names
were changed to not use "." so that they could be used as Java
identifiers to support the generation of an interface that gives access
to all the name properties and can populate itself reflectively by
mapping field name to property IDs.
Mark Diggory wrote:
>> to take a look at
>> Specifically:
>> following
> WorkBenchMessages in the translation pack are now no longer working
> because to this same issue, is someone maintaing this translation pack?
> -Mark Diggory
Re: plugin.properties with dots in labels [message #291484 is a reply to message #291477] Fri, 16 September 2005 10:27 Go to previous messageGo to next message
Yes, I understand the logic behind the name change.
I've got an immediate need, I went and filtered all the properties file
in the language pack to have underscores instead of dots. But will use
whatever the new language pack has instead when it comes out.
thanks,
Mark
Ed Merks wrote:
> Mark,
> Mark Diggory wrote:
>>> to take a look at
>>> Specifically:
>>> following
>> -Mark Diggory
Re: plugin.properties with dots in labels [message #291489 is a reply to message #291484] Fri, 16 September 2005 12:49 Go to previous messageGo to next message
--------------080103030309030908080906
I've gotten most of what I need fixed in terms of translation by the
approach I took below. The only current issue is that for some reason
the ContentOutline and Properties Views are not getting translated even
though I've translated the properties for these in o.e.ui.views...
-Mark
> thanks,
> Mark
> Ed Merks wrote:
>> Mark,
>> be available with 3.1.1 around the end of the month. Probably the
>> names were changed to not use "." so that they could be used as Java
>> access to all the name properties and can populate itself reflectively
>> by mapping field name to property IDs.
>> Mark Diggory wrote:
>>>> to take a look at
>>>> Specifically:
>>>> following
>>> -Mark Diggory
Content-Type: image/png;
name="snap.png"
Content-Disposition: inline;
filename="snap.png"
iVBORw0KGgoAAAANSUhEUgAAAPkAAACVCAIAAAAVG8vmAAAACXBIWXMAAA7D AAAOwwHHb6hk
AAAFW0lEQVR4nO3cXWscVRzH8RERBCksuIJQBEECBREEEUToneAbMAiCCCUF F8E0CIIQKIIg
BEQQGsg7CGyu2lfgG0gh3vSuLRVtysaipq4PrMeLhfHk/M+cfZglM3N+3+VD mJ6cmZyZ/XaS
zUKK4t37gISn3rkNKChGx3cABbQOFbQOFbQOFbQOFbQOFbQOFbQOFbQOFbQO FbQOFbQOFbQO
FbQOFbQOFbQOFbQOFbQOFbQOFYXjwUPjwX0dKmgdKmgdKmgdKmgdKmgdKmgd KmgdKmgdKmgd
KmgdKmgdKmgdKmgdKmgdKmgdKmgdKmgdKmgdKmgdKmgdKmgdKmgdKmgdKoqD /b2cRE+y8VWh
DXK7rx+Y3A/294r3HkixFwGjLH+G8Z/pg/29p9//URC5W/m3/swHPwmidSv/ 1p/98GdffzAM
BBPyQOvWuba+tbmRsKq9gtaf++ihrz8Y3v/DlfqDYTAhD7RunXfrVX8vON36 QnsFrV+4cuzr
D4aHI3c4crdP3OGJ6w+GF64cf//QBYK9OofWrW60Xue+3rv6yNcfDG/dndy8 O7l1b3Lz3qQ/
GPauPuqt74TO7tWs8mRnDpZo3erGzzB17uvPfzzy9QfD3aPx7g/j3aPx7tG4 PxgGE1bIObeS
45RXYGtzo2okQOtWB16b1mz9hU9OfPa1aTAhofy66TnBdnr+PPwrML0v+P+M 7kLrVv6tv/jp
LzOV3SfmOOei28tNW1T0ImxtblTNp3Ur/9YvXns8U299xznXW9+5eO1xfzCc bvicc9ERf7wc
mT6COf6y/V2CkYTgOmxtbiQm07qVf+svffbrTOVL0qoJzrnoiD+eHplnZppt PTGZ1q38W3/5
89989uf1YEKUcy464o+nR6Lj/iO9gKqfYarm07rVjdbr/M7xlS9+99n3koIJ Uc656Ig/nh5J
z0xLvzaN7kLrVgdaX1TQ+tr2qc++l7S2fWrfSwr2Wts+dc7ZbTtYNTLPzCr+ bxirRgK0buXf
+qXrT3z2vaRL15/Y95KCvabKu2l0sBwvt+3HckLigFb5TWzmYInWrfxbf/XL sc++lxRMyAOt
W/m3/tpXf/rsa9NgQh5o3cq/9de//ksQrVv5t/7Gzt+CaN3Kv/U3v/lHEK1b +bf+1rcTQbRu
5fY3M6b81t/+7l9BjT8FLZT/ff3yDQdcvuFoHSpUWm98VWgcrUMFra/oOhb5 XMmqc7Hj3Trr
Lq11TonWi6JY4dPjH2q6vcTB669n5WdE653RYOuNWPmXpvXOqGq9fGL8jfIR uTRnPxW9i5cT
go/2sFVfyC4muobEoRJHTq+/ak7is1XHTFzG9mj14pazUOv/XwgTWbA9/8g8 MxMT6iwjcZDE
GhLrX+5826m9K1taO1uP3qGDCZGnp0brVbfh4Aj+nKr7+szzrTq7VmnvypYW bb0wj9H5tl75
BJjy6iwjsaOdn17/cufbZt1Y5UKqWj9z2s21nvhC9ZeR2HGe7fqtR/8jtUTr FlTfSlofed+a
7Yj/jM5TSfRowUoSn515qKp9ozMTc+yNP/isPf3EkhovIbwgja9g5XjfFFG0 DhW0DhW0DhW0
DhW0DhW0DhW0DhW0DhW0DhW0DhW0DhW0DhW0DhW0DhW0DhW0DhW0DhW0DhW0 DhW0DhW0DhW0
DhW0DhW0DhW0DhW0DhW0DhW0DhW0DhX/AehQbH8wpClEAAAAAElFTkSuQmCC
--------------080103030309030908080906--
Re: plugin.properties with dots in labels [message #291490 is a reply to message #291489] Fri, 16 September 2005 13:03 Go to previous messageGo to next message
--------------070805000301010504070802
Mark,
If you change the default/English versions, do those changes show up?
> even though I've translated the properties for these in o.e.ui.views...
> -Mark
>> file in the language pack to have underscores instead of dots. But
>> will use whatever the new language pack has instead when it comes out.
>> thanks,
>> Mark
>> Ed Merks wrote:
>>> Mark,
>>> will be available with 3.1.1 around the end of the month. Probably
>>> the names were changed to not use "." so that they could be used as
>>> Java identifiers to support the generation of an interface that
>>> gives access to all the name properties and can populate itself
>>> reflectively by mapping field name to property IDs.
>>>>> Specifically:
>>>>> the following
>>>> pack?
>>>> -Mark Diggory
Content-Type: multipart/related;
boundary="------------020709030104030607060307"
--------------020709030104030607060307
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Mark,<br>
<br>
If you change the default/English versions, do those changes show up?<br>
<br>
<br>
Mark Diggory wrote:
<blockquote cite="mid432AF7A3.7080104@apache.org" type="cite">I've
<br>
<br>
-Mark
<br>
<br>
<br>
Mark Diggory wrote:
<br>
<blockquote type="cite">Yes, I understand the logic behind the name
change.
<br>
<br>
<br>
<br>
thanks,
<br>
Mark
<br>
<br>
Ed Merks wrote:
<br>
<br>
<blockquote type="cite">Mark,
<br>
<br>
be available with 3.1.1 around the end of the month.&nbsp; Probably the
<br>
<br>
<br>
Mark Diggory wrote:
<br>
<br>
<blockquote type="cite">Alex Blewitt wrote:
<br>
<br>
<blockquote type="cite">Depending on which version of Eclipse
<a class="moz-txt-link-freetext" href=" http://help.eclipse.org/help31/topic/org.eclipse.platform.do c.isv/guide/product_def_nl.htm"> http://help.eclipse.org/help31/topic/org.eclipse.platform.do c.isv/guide/product_def_nl.htm</a>
<br>
<br>
Specifically:
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://download.eclipse.org/eclipse/downloads/drops/L-3.0.1_ Translations-200409161125/index.php"> http://download.eclipse.org/eclipse/downloads/drops/L-3.0.1_ Translations-200409161125/index.php</a>
<br>
<br>
<br>
<br>
<br>
-Mark Diggory
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
<hr size="4" width="90%"><br>
<center><img src="cid:part1.02090500.05020901@ca.ibm.com"></center>
</blockquote>
<br>
</body>
</html>
Content-ID: <part1.02090500.05020901@ca.ibm.com>
--------------020709030104030607060307--
--------------070805000301010504070802--
Re: plugin.properties with dots in labels [message #291497 is a reply to message #291490] Fri, 16 September 2005 19:03 Go to previous messageGo to next message
--------------020309070300060505020403
I've attached my nls plugin in zip.
Only for the properties in the jar, not the plugin.properties.
o.e.ui.views/src/o.e.ui.internal.views.contentoutline/messag es.properties
o.e.ui.views/src/o.e.ui.internal.views.properties/messages.p roperties
but not
o.e.ui.views/plugin.properties
-Mark
Ed Merks wrote:
> Mark,
>> -Mark
>>> thanks,
>>> Mark
>>> Ed Merks wrote:
>>>> Mark,
>>>>>> Specifically:
>>>>>> the following
>>>>> pack?
>>>>> -Mark Diggory
Content-Type: application/x-zip-compressed;
name="nls.zip"
filename="nls.zip"
UEsDBBQACAAIAFSYMDMAAAAAAAAAAAAAAAAjAAAAb3JnLmVjbGlwc2UudWku dmlld3Mubmwx
Ly5jbGFzc3BhdGidjz0LwjAURWcF/0PIbqqbQ2sRqaBDlVJnqcmjjcaXmA/R f29Vii46uL17
OZzLi9PrSZELWCc1JnTMRpQAci0k1gndlovhhKbTQT/mqnLOVL5pQ++dAL29 kaNEkVBnOSWP
8nVG30musSO1rRlwJY0DdhCeqSogb9p1tiqy3Xydl7NlnhV/2IwAxrUFZuEc pAWxUaGW6H6p
dPAm+M62l/iE4+jz+ztQSwcI1Ryc0qUAAAAzAQAAUEsDBBQACAAIAFSYMDMA AAAAAAAAAAAA
AAAhAAAAb3JnLmVjbGlwc2UudWkudmlld3MubmwxLy5wcm9qZWN0vZLPTgMh EMbPmvgOzd6F
9uaBbhM13mpMqg+AMG5pYCD8WX18AVnNZjXxYLzN9818/AgM270ZvRrBB2Vx 223IulsBCisV
Dtvu6fHu8qrb9RfnzHl7AhFvIQivXMzT2T1jyA301g8EhFYuAEmKjApeA0G9 YbS2y5ywxgDG
ntGpKm47NFRBZ+o5KS0PDkRRTd7kKEdZnW/QJxmJsD4XfOQ1AP7rCjnB/ZAK OzRN5wajC8qv
uE4C2XNULxDi9f9iD+IIhv8JtDnTk2deTB7a9IdY4B90GhTe12ah16GfArPv wUVmqgvxcxfm
6/YOUEsHCPt+TVrqAAAArQIAAFBLAwQUAAgACABUmDAzAAAAAAAAAAAAAAAA LQAAAG9yZy5l
Y2xpcHNlLnVpLnZpZXdzLm5sMS9NRVRBLUlORi9NQU5JRkVTVC5NRm2OsQ6C QBBEe77iYmci
G0ArjI0mxkKIiYmN1YIrnlnuyN2B0a8XxTMW1m/mzWSo5JmsCw9krNQqFTFE wbJVJ6Yw+8Av
SzzJsaZU5ByLtcGqJuU82d/rQrMsh4Q2FVDJsrEErYRO0s2C4tinf1f7XS8L N9q6/+15MTS7
obkYHaeQQDSZvQTjkRdvdYksH+je9obbSirPVozW7tBdUtFfgSua4AlQSwcI 8Bck+6MAAAAH
AQAAUEsDBBQACAAIAFSYMDMAAAAAAAAAAAAAAABgAAAAb3JnLmVjbGlwc2Uu dWkudmlld3Mu
bmwxL2Jpbi9vcmcvZWNsaXBzZS91aS9pbnRlcm5hbC92aWV3cy9jb250ZW50 b3V0bGluZS9t
ZXNzYWdlc19mci5wcm9wZXJ0aWVztVLBTsMwDL0j8Q+WdgAklnZIXCbtMCYO k0DsAFxRlprW
Ik0iJ221v8dpYUicN99ivef3np3Z7KR1eTGDjQ8HprpJcG1u4K4s7wG2D8/S 5+BZJ/IOtKvA
pwY5qkxZWwsjJQJjRO6xUvDaUITAvmbdjgTBgzbGt0G7A7kaWp2QSduYZ2hG aVQC6TVZvbcI
nauQR5rg2gj+c3w8GkshIuy6vSUDT2TQybNfqDIPGhoyzVGIMApJnFQUE9O+ y/5vRz/S/NPS
KXOblMKyKIZhUDipKM91YbHWtsBg5/2iVE1qrYCnXblpqOe4zI1c/5c1B3KU JCesd9tJuQ0W
W3RpBAjv1FfMVoI2X7rGJUiCY5qOVE84RGXEuRjwXbLkMDMyZ3XSyhNfJgF4 F9VzKGymHD8y
H87/Cq7gzUFO6TsGd4UxyUbGbxC8Izm5+gZQSwcIuELV3EkBAAA8AwAAUEsD BBQACAAIAFSY
MDMAAAAAAAAAAAAAAABcAAAAb3JnLmVjbGlwc2UudWkudmlld3MubmwxL2Jp bi9vcmcvZWNs
aXBzZS91aS9pbnRlcm5hbC92aWV3cy9wcm9wZXJ0aWVzL21lc3NhZ2VzX2Zy LnByb3BlcnRp
ZXO1VE2L20AMvQfyHwSB0MKuky30EghLmrQQ2C2hhL0uE1tri45nzIzs1P21 vbX+F9XYibMf
gV7SORg8ek9P0kgajS56hoMRLG1RO0ozhnfxe/gwnU6vwvcjrD/di9EV1ikm a0CZBCxn6HwU
eAutoeV5cOjRVZhEsM3IQ+Fs6lTeEgQPKo5tXihTk0khV4yOlPbBh3IoF4lA KkVa7TRCaRJ0
LU1wuQf71P58jjUVHmFT7jTFcEcxGvmtbqJpcLTPKM56IUIvJIkkIc+OdmWI /6qNRy5PWooD
N2MuZpPJfr+PsFOJrEsnGlOlJ1jo6+pmGmWcawF3BTOdU+v8LFyE87pY10CG WPKExWbdKeeF
xhwNtwDhXfopQyiFir+rFGcgGfTZlBRVhHsfycMU6FjK06HnFz3B46ZXgAeR /B8iw8FSWii1
TkQeGX8wzOE+PAn+hDvRHYu56cwvodbqLRWv0M/BApdZOKRQH32P5ZIwWFf4 pErNveqD0lg6
qbmDpBETwwph/A09q9IdXvnE6eXP0l6yhoMvpKX/z+UX4nPUcCOpLiplfjch 9iP+bJLPKCfG
cHDMNLyUcA/dUQu5J7wBVUqX2CfxxpyTj8W6okrWxLGiW7uURtxZ5RKBy+Dl KxkMmz4yscZ5
e/cnR4il0Mow/AKtoNDKxBky4z+c5Oi9tPx8raFuZ5tlh4Qd1DlFE9ZCk5xx DLJ4fO1ZYBHA
V1tWqHXYO+2MVnj7F1BLBwjk8x3aJwIAAG4FAABQSwMEFAAIAAgAVJgwMwAA AAAAAAAAAAAA
ACkAAABvcmcuZWNsaXBzZS51aS52aWV3cy5ubDEvYnVpbGQucHJvcGVydGll c0vKzNPLzEvO
KU1JLVawVfB1DXHU9fRz09eJ4eVSQAV5OYZ6WYlFWGQKckrTM/Pi04r0Cory C1KLSjJTi3m5
gGqL9ZLzcwsyc1L18otSUouAFkAN4eUqzi8tSk7Vg/KBMsVFyfq8XPmlJQWl JUjCSZl5QGEA
UEsHCEVjgUR0AAAApwAAAFBLAwQUAAgACABUmDAzAAAAAAAAAAAAAAAALQAA AG9yZy5lY2xp
cHNlLnVpLnZpZXdzLm5sMS9wbHVnaW5fZnIucHJvcGVydGllc61SyU7EMAy9 9ysszQGQmExB
4oI0B0BzGIllJBD3TGpaS9nkpC3zyfwFbssulgs5RLLz/N6z49nsX08xg4sQ d0x1k2HfHMBx
WZaHw30C6/MreeQYWGcKHrSvIOQGOSkpO7MWxrIEjAm5w0rBXUMJIoeatRvx AgdtTHBR+x35
GpzOyKRtEgrNKHEliE6T1VuL0PoKeawSmEsQHsZgZSzFhLBpt5YMXJJBL2F3 pErh6RsyzZsM
YZIa8VFRykzbdjB/OLqR5LuUzlLa5BxPF4u+7xVOGipwvbBYa7vAaOfdUama 7GwxjcpPjIHT
qcTD+TqlOZCnLB3C2WY9qbpo0aHPI6D43w+cFdG2Nflr7XAJ9y2mQubfkYxx Sq3e2yqKe8I+
qQ2HiJx3tw1ihuXwYZHpKT8leEEMjYrhmzZb8igQI4nQMkwUF8E56UzFj0TK i943bN+DK0yG
KY4jWwI+xpBoDKyGrkWQrfiJyHwy9yr75vAX6J+ie8NaOdmOZ1BLBwjhRH81 egEAAGcDAABQ
SwMEFAAIAAgAVJgwMwAAAAAAAAAAAAAAAGAAAABvcmcuZWNsaXBzZS51aS52 aWV3cy5ubDEv
c3JjL29yZy9lY2xpcHNlL3VpL2ludGVybmFsL3ZpZXdzL2NvbnRlbnRvdXRs aW5lL21lc3Nh
Z2VzX2ZyLnByb3BlcnRpZXO1UsFOwzAMvSPxD5Z2ACSWdkhcJu0wJg6TQOwA XFGWmtYiTSIn
bbW/x2lhSJw332K95/eendnspHV5MYONDwemuklwbW7grizvAbYPz9Ln4Fkn 8g60q8CnBjmq
TFlbCyMlAmNE7rFS8NpQhMC+Zt2OBMGDNsa3QbsDuRpanZBJ25hnaEZpVALp NVm9twidq5BH
muDaCP5zfDwaSyEi7Lq9JQNPZNDJs1+oMg8aGjLNUYgwCkmcVBQT077L/m9H P9L809Ipc5uU
wrIohmFQOKkoz3Vhsda2wGDn/aJUTWqtgKdduWmo57jMjVz/lzUHcpQkJ6x3 20m5DRZbdGkE
CO/UV8xWgjZfusYlSIJjmo5UTzhEZcS5GPBdsuQwMzJnddLKE18mAXgX1XMo bKYcPzIfzv8K
ruDNQU7pOwZ3hTHJRsZvELwjObn6BlBLBwi4QtXcSQEAADwDAABQSwMEFAAI AAgAVJgwMwAA
AAAAAAAAAAAAAFwAAABvcmcuZWNsaXBzZS51aS52aWV3cy5ubDEvc3JjL29y Zy9lY2xpcHNl
L3VpL2ludGVybmFsL3ZpZXdzL3Byb3BlcnRpZXMvbWVzc2FnZXNfZnIucHJv cGVydGllc7VU
TYvbQAy9B/IfBIHQwq6TLfQSCEuatBDYLaGEvS4TW2uLjmfMjOzU/bW9tf4X 1diJsx+BXtI5
GDx6T0/SSBqNLnqGgxEsbVE7SjOGd/F7+DCdTq/C9yOsP92L0RXWKSZrQJkE LGfofBR4C62h
5Xlw6NFVmESwzchD4WzqVN4SBA8qjm1eKFOTSSFXjI6U9sGHcigXiUAqRVrt NEJpEnQtTXC5
B/vU/nyONRUeYVPuNMVwRzEa+a1uomlwtM8oznohQi8kiSQhz452ZYj/qo1H Lk9aigM3Yy5m
k8l+v4+wU4msSycaU6UnWOjr6mYaZZxrAXcFM51T6/wsXITzuljXQIZY8oTF Zt0p54XGHA23
AOFd+ilDKIWKv6sUZyAZ9NmUFFWEex/JwxToWMrToecXPcHjpleAB5H8HyLD wVJaKLVORB4Z
fzDM4T48Cf6EO9Edi7npzC+h1uotFa/Qz8ECl1k4pFAffY/lkjBYV/ikSs29 6oPSWDqpuYOk
ERPDCmH8DT2r0h1e+cTp5c/SXrKGgy+kpf/P5Rfic9RwI6kuKmV+NyH2I/5s ks8oJ8ZwcMw0
vJRwD91RC7knvAFVSpfYJ/HGnJOPxbqiStbEsaJbu5RG3FnlEoHL4OUrGQyb PjKxxnl79ydH
iKXQyjD8Aq2g0MrEGTLjP5zk6L20/HytoW5nm2WHhB3UOUUT1kKTnHEMsnh8 7VlgEcBXW1ao
ddg77YxWePsXUEsHCOTzHdonAgAAbgUAAFBLAQIUABQACAAIAFSYMDPVHJzS pQAAADMBAAAj
AAAAAAAAAAAAAAAAAAAAAABvcmcuZWNsaXBzZS51aS52aWV3cy5ubDEvLmNs YXNzcGF0aFBL
AQIUABQACAAIAFSYMDP7fk1a6gAAAK0CAAAhAAAAAAAAAAAAAAAAAPYAAABv cmcuZWNsaXBz
ZS51aS52aWV3cy5ubDEvLnByb2plY3RQSwECFAAUAAgACABUmDAz8Bck+6MA AAAHAQAALQAA
AAAAAAAAAAAAAAAvAgAAb3JnLmVjbGlwc2UudWkudmlld3MubmwxL01FVEEt SU5GL01BTklG
RVNULk1GUEsBAhQAFAAIAAgAVJgwM7hC1dxJAQAAPAMAAGAAAAAAAAAAAAAA AAAALQMAAG9y
Zy5lY2xpcHNlLnVpLnZpZXdzLm5sMS9iaW4vb3JnL2VjbGlwc2UvdWkvaW50 ZXJuYWwvdmll
d3MvY29udGVudG91dGxpbmUvbWVzc2FnZXNfZnIucHJvcGVydGllc1BLAQIU ABQACAAIAFSY
MDPk8x3aJwIAAG4FAABcAAAAAAAAAAAAAAAAAAQFAABvcmcuZWNsaXBzZS51 aS52aWV3cy5u
bDEvYmluL29yZy9lY2xpcHNlL3VpL2ludGVybmFsL3ZpZXdzL3Byb3BlcnRp ZXMvbWVzc2Fn
ZXNfZnIucHJvcGVydGllc1BLAQIUABQACAAIAFSYMDNFY4FEdAAAAKcAAAAp AAAAAAAAAAAA
AAAAALUHAABvcmcuZWNsaXBzZS51aS52aWV3cy5ubDEvYnVpbGQucHJvcGVy dGllc1BLAQIU
ABQACAAIAFSYMDPhRH81egEAAGcDAAAtAAAAAAAAAAAAAAAAAIAIAABvcmcu ZWNsaXBzZS51
aS52aWV3cy5ubDEvcGx1Z2luX2ZyLnByb3BlcnRpZXNQSwECFAAUAAgACABU mDAzuELV3EkB
AAA8AwAAYAAAAAAAAAAAAAAAAABVCgAAb3JnLmVjbGlwc2UudWkudmlld3Mu bmwxL3NyYy9v
cmcvZWNsaXBzZS91aS9pbnRlcm5hbC92aWV3cy9jb250ZW50b3V0bGluZS9t ZXNzYWdlc19m
ci5wcm9wZXJ0aWVzUEsBAhQAFAAIAAgAVJgwM+TzHdonAgAAbgUAAFwAAAAA AAAAAAAAAAAA
LAwAAG9yZy5lY2xpcHNlLnVpLnZpZXdzLm5sMS9zcmMvb3JnL2VjbGlwc2Uv dWkvaW50ZXJu
YWwvdmlld3MvcHJvcGVydGllcy9tZXNzYWdlc19mci5wcm9wZXJ0aWVzUEsF BgAAAAAJAAkA
3QMAAN0OAAAAAA==
--------------020309070300060505020403--
Re: plugin.properties with dots in labels [message #291507 is a reply to message #291497] Sat, 17 September 2005 08:45 Go to previous messageGo to next message
--------------020904000600000400060503
Mark,
Did you use this source project to build the nl1.jar specified by the
manifest?
Bundle-ClassPath: nl1.jar
I don't see the nl1.jar in this zip so maybe you just need to create
that jar to make this work?
> but not
> -Mark
> Ed Merks wrote:
>> Mark,
>>> reason the ContentOutline and Properties Views are not getting
>>> translated even though I've translated the properties for these in
>>> o.e.ui.views...
>>> -Mark
>>>> thanks,
>>>> Mark
>>>> Ed Merks wrote:
>>>>> Mark,
>>>>> Probably the names were changed to not use "." so that they could
>>>>> be used as Java identifiers to support the generation of an
>>>>> interface that gives access to all the name properties and can
>>>>> populate itself reflectively by mapping field name to property IDs.
>>>>>>> Specifically:
>>>>>>> plug-in.
>>>>>> working because to this same issue, is someone maintaing this
>>>>>> translation pack?
>>>>>> -Mark Diggory
<html>
<head>
</head>
Mark,<br>
<br>
manifest?&nbsp; <br>
<blockquote>Bundle-ClassPath: nl1.jar<br>
</blockquote>
that jar to make this work?<br>
<br>
<br>
Mark Diggory wrote:
<blockquote cite="mid432B4F5E.40508@apache.org" type="cite">I've
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
but not
<br>
<br>
<br>
<br>
-Mark
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
Mark Diggory wrote:
<br>
<br>
<blockquote type="cite">I've gotten most of what I need fixed in
terms of translation by the approach I took below. The only current
issue is that for some reason the ContentOutline and Properties Views
are not getting translated even though I've translated the properties
<br>
<br>
-Mark
<br>
<br>
<br>
Mark Diggory wrote:
<br>
<br>
name change.
<br>
<br>
<br>
<br>
thanks,
<br>
Mark
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Mark Diggory wrote:
<br>
<br>
<br>
<br>
<br>
<br>
Specifically:
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
-Mark Diggory
<br>
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------020904000600000400060503--
Re: plugin.properties with dots in labels [message #291514 is a reply to message #291507] Sat, 17 September 2005 17:35 Go to previous message
--------------050608030701080202040904
Actually, I changed it to be a full fledged 3.1 OSGi based plugin jar
and it seems to work fine now. Here's the plugin jar with source included.
-Mark
Ed Merks wrote:
> Mark,
> manifest?
>> but not
>> -Mark
>> Ed Merks wrote:
>>> Mark,
>>>> o.e.ui.views...
>>>> -Mark
>>>>> thanks,
>>>>> Mark
>>>>> Ed Merks wrote:
>>>>>> Mark,
>>>>>>>> Specifically:
>>>>>>>> plug-in.
>>>>>>> translation pack?
>>>>>>> -Mark Diggory
Content-Type: application/java-archive;
name="org.eclipse.ui.views.nl1_1.0.0.jar"
filename="org.eclipse.ui.views.nl1_1.0.0.jar"
UEsDBAoAAAAAACmMMTMAAAAAAAAAAAAAAAAJAAAATUVUQS1JTkYvUEsDBAoA AAAAACmMMTMA
AAAAAAAAAAAAAAAEAAAAb3JnL1BLAwQKAAAAAAApjDEzAAAAAAAAAAAAAAAA DAAAAG9yZy9l
Y2xpcHNlL1BLAwQKAAAAAAApjDEzAAAAAAAAAAAAAAAADwAAAG9yZy9lY2xp cHNlL3VpL1BL
AwQKAAAAAAApjDEzAAAAAAAAAAAAAAAAGAAAAG9yZy9lY2xpcHNlL3VpL2lu dGVybmFsL1BL
AwQKAAAAAAApjDEzAAAAAAAAAAAAAAAAHgAAAG9yZy9lY2xpcHNlL3VpL2lu dGVybmFsL3Zp
ZXdzL1BLAwQKAAAAAAApjDEzAAAAAAAAAAAAAAAALQAAAG9yZy9lY2xpcHNl L3VpL2ludGVy
bmFsL3ZpZXdzL2NvbnRlbnRvdXRsaW5lL1BLAwQKAAAAAAApjDEzAAAAAAAA AAAAAAAAKQAA
AG9yZy9lY2xpcHNlL3VpL2ludGVybmFsL3ZpZXdzL3Byb3BlcnRpZXMvUEsD BAoAAAAAACmM
MTMAAAAAAAAAAAAAAAAEAAAAc3JjL1BLAwQKAAAAAAApjDEzAAAAAAAAAAAA AAAACAAAAHNy
Yy9vcmcvUEsDBAoAAAAAACmMMTMAAAAAAAAAAAAAAAAQAAAAc3JjL29yZy9l Y2xpcHNlL1BL
AwQKAAAAAAApjDEzAAAAAAAAAAAAAAAAEwAAAHNyYy9vcmcvZWNsaXBzZS91 aS9QSwMECgAA
AAAAKYwxMwAAAAAAAAAAAAAAABwAAABzcmMvb3JnL2VjbGlwc2UvdWkvaW50 ZXJuYWwvUEsD
BAoAAAAAACmMMTMAAAAAAAAAAAAAAAAiAAAAc3JjL29yZy9lY2xpcHNlL3Vp L2ludGVybmFs
L3ZpZXdzL1BLAwQKAAAAAAApjDEzAAAAAAAAAAAAAAAAMQAAAHNyYy9vcmcv ZWNsaXBzZS91
aS9pbnRlcm5hbC92aWV3cy9jb250ZW50b3V0bGluZS9QSwMECgAAAAAAKYwx MwAAAAAAAAAA
AAAAAC0AAABzcmMvb3JnL2VjbGlwc2UvdWkvaW50ZXJuYWwvdmlld3MvcHJv cGVydGllcy9Q
SwMECgAAAAgAKYwxM9UcnNKlAAAAMwEAAAoAAAAuY2xhc3NwYXRonY89C8Iw FEVnBf9DyG6q
m0NrEamgQ5VSZ6nJo43Gl5gP0X9vVYouOri9ezmcy4vT60mRC1gnNSZ0zEaU AHItJNYJ3ZaL
4YSm00E/5qpyzlS+aUPvnQC9vZGjRJFQZzklj/J1Rt9JrrEjta0ZcCWNA3YQ nqkqIG/adbYq
st18nZezZZ4Vf9iMAMa1BWbhHKQFsVGhluh+qXTwJvjOtpf4hOPo8/s7UEsD BAoAAAAIACmM
MTP7fk1a6gAAAK0CAAAIAAAALnByb2plY3S9ks9OAyEQxs+a+A7N3oX25oFu EzXeakyqD4Aw
bmlgIPxZfXwBWc1mNfFgvM33zXz8CAzbvRm9GsEHZXHbbci6WwEKKxUO2+7p 8e7yqtv1F+fM
eXsCEW8hCK9czNPZPWPIDfTWDwSEVi4ASYqMCl4DQb1htLbLnLDGAMae0akq bjs0VEFn6jkp
LQ8ORFFN3uQoR1mdb9AnGYmwPhd85DUA/usKOcH9kAo7NE3nBqMLyq+4TgLZ c1QvEOL1/2IP
4giG/wm0OdOTZ15MHtr0h1jgH3QaFN7XZqHXoZ8Cs+/BRWaqC/FzF+br9g5Q SwMECgAAAAgA
KYwxM/XT3ZaUAAAA7QAAABQAAABNRVRBLUlORi9NQU5JRkVTVC5NRm2NvQ6C MBRGd56CsJnI
DUUnjIuDcRAWExengtfmJrctoQWjT+9PrXFwPt85Xy0NXdD5/IiDI2uqVECR bEZzZszrD/yy
MpJGaqzShkW6HaTSaHwkh5tuLVMXFnZQgB1T7xBGgonw6sCwiOvf1+dvjOU7 6/x/e9UGcwrm
OjstoIRivnwFZlkM720nme7Sv+s9j4pM8gBQSwMECgAAAAgAKYwxM1x4ICCX AAAAXwEAABAA
AABidWlsZC5wcm9wZXJ0aWVzjZAxDsIwDEX3SL1DDgDuCRgYQGKAiREJNa4p rkIS2QnnJ4IF
pKjCm9+37P/tOAAH9GUktRt73J2368Np368unbG/lXyZOFxvAkliIslM2hiD zsyDKGB8JPYE
UUaSurpyjUWQAGqngn1nYsmp5DdwHCqo+NsOoB9U05DvrUPVxkyYWxI+lacQ hRriUkZX2I/L
+f58wyfgC1BLAwQKAAAACAApjDEzuELV3EkBAAA8AwAAQwAAAG9yZy9lY2xp cHNlL3VpL2lu
dGVybmFsL3ZpZXdzL2NvbnRlbnRvdXRsaW5lL21lc3NhZ2VzX2ZyLnByb3Bl cnRpZXO1UsFO
wzAMvSPxD5Z2ACSWdkhcJu0wJg6TQOwAXFGWmtYiTSInbbW/x2lhSJw332K9 5/eendnspHV5
MYONDwemuklwbW7grizvAbYPz9Ln4Fkn8g60q8CnBjmqTFlbCyMlAmNE7rFS 8NpQhMC+Zt2O
BMGDNsa3QbsDuRpanZBJ25hnaEZpVALpNVm9twidq5BHmuDaCP5zfDwaSyEi 7Lq9JQNPZNDJ
s1+oMg8aGjLNUYgwCkmcVBQT077L/m9HP9L809Ipc5uUwrIohmFQOKkoz3Vh sda2wGDn/aJU
TWqtgKdduWmo57jMjVz/lzUHcpQkJ6x320m5DRZbdGkECO/UV8xWgjZfusYl SIJjmo5UTzhE
ZcS5GPBdsuQwMzJnddLKE18mAXgX1XMobKYcPzIfzv8KruDNQU7pOwZ3hTHJ RsZvELwjObn6
BlBLAwQKAAAACAApjDEz5PMd2icCAABuBQAAPwAAAG9yZy9lY2xpcHNlL3Vp L2ludGVybmFs
L3ZpZXdzL3Byb3BlcnRpZXMvbWVzc2FnZXNfZnIucHJvcGVydGllc7VUTYvb QAy9B/IfBIHQ
wq6TLfQSCEuatBDYLaGEvS4TW2uLjmfMjOzU/bW9tf4X1diJsx+BXtI5GDx6 T0/SSBqNLnqG
gxEsbVE7SjOGd/F7+DCdTq/C9yOsP92L0RXWKSZrQJkELGfofBR4C62h5Xlw 6NFVmESwzchD
4WzqVN4SBA8qjm1eKFOTSSFXjI6U9sGHcigXiUAqRVrtNEJpEnQtTXC5B/vU /nyONRUeYVPu
NMVwRzEa+a1uomlwtM8oznohQi8kiSQhz452ZYj/qo1HLk9aigM3Yy5mk8l+ v4+wU4msSyca
U6UnWOjr6mYaZZxrAXcFM51T6/wsXITzuljXQIZY8oTFZt0p54XGHA23AOFd +ilDKIWKv6sU
ZyAZ9NmUFFWEex/JwxToWMrToecXPcHjpleAB5H8HyLDwVJaKLVORB4ZfzDM 4T48Cf6EO9Ed
i7npzC+h1uotFa/Qz8ECl1k4pFAffY/lkjBYV/ikSs296oPSWDqpuYOkERPD CmH8DT2r0h1e
+cTp5c/SXrKGgy+kpf/P5Rfic9RwI6kuKmV+NyH2I/5sks8oJ8ZwcMw0vJRw D91RC7knvAFV
SpfYJ/HGnJOPxbqiStbEsaJbu5RG3FnlEoHL4OUrGQybPjKxxnl79ydHiKXQ yjD8Aq2g0MrE
GTLjP5zk6L20/HytoW5nm2WHhB3UOUUT1kKTnHEMsnh87VlgEcBXW1aoddg7 7YxWePsXUEsD
BAoAAAAIACmMMTPhRH81egEAAGcDAAAUAAAAcGx1Z2luX2ZyLnByb3BlcnRp ZXOtUslOxDAM
vfcrLM0BkJhMQeKCNAdAcxiJZSQQ90xqWkvZ5KQt88n8BW7LLpYLOUSy8/ze s+PZ7F9PMYOL
EHdMdZNh3xzAcVmWh8N9AuvzK3nkGFhnCh60ryDkBjkpKTuzFsayBIwJucNK wV1DCSKHmrUb
8QIHbUxwUfsd+RqczsikbRIKzShxJYhOk9Vbi9D6CnmsEphLEB7GYGUsxYSw abeWDFySQS9h
d6RK4ekbMs2bDGGSGvFRUcpM23Ywfzi6keS7lM5S2uQcTxeLvu8VThoqcL2w WGu7wGjn3VGp
muxsMY3KT4yB06nEw/k6pTmQpywdwtlmPam6aNGhzyOg+N8PnBXRtjX5a+1w CfctpkLm35GM
cUqt3tsqinvCPqkNh4icd7cNYobl8GGR6Sk/JXhBDI2K4Zs2W/IoECOJ0DJM FBfBOelMxY9E
yoveN2zfgytMhimOI1sCPsaQaAyshq5FkK34ich8Mvcq++bwF+ifonvDWjnZ jmdQSwMECgAA
AAgAKYwxM7hC1dxJAQAAPAMAAEcAAABzcmMvb3JnL2VjbGlwc2UvdWkvaW50 ZXJuYWwvdmll
d3MvY29udGVudG91dGxpbmUvbWVzc2FnZXNfZnIucHJvcGVydGllc7VSwU7D MAy9I/EPlnYA
JJZ2SFwm7TAmDpNA7ABcUZaa1iJNIidttb/HaWFInDffYr3n956d2eykdXkx g40PB6a6SXBt
buCuLO8Btg/P0ufgWSfyDrSrwKcGOapMWVsLIyUCY0TusVLw2lCEwL5m3Y4E wYM2xrdBuwO5
GlqdkEnbmGdoRmlUAuk1Wb23CJ2rkEea4NoI/nN8PBpLISLsur0lA09k0Mmz X6gyDxoaMs1R
iDAKSZxUFBPTvsv+b0c/0vzT0ilzm5TCsiiGYVA4qSjPdWGx1rbAYOf9olRN aq2Ap125aajn
uMyNXP+XNQdylCQnrHfbSbkNFlt0aQQI79RXzFaCNl+6xiVIgmOajlRPOERl xLkY8F2y5DAz
Mmd10soTXyYBeBfVcyhsphw/Mh/O/wqu4M1BTuk7BneFMclGxm8QvCM5ufoG UEsDBAoAAAAI
ACmMMTPk8x3aJwIAAG4FAABDAAAAc3JjL29yZy9lY2xpcHNlL3VpL2ludGVy bmFsL3ZpZXdz
L3Byb3BlcnRpZXMvbWVzc2FnZXNfZnIucHJvcGVydGllc7VUTYvbQAy9B/If BIHQwq6TLfQS
CEuatBDYLaGEvS4TW2uLjmfMjOzU/bW9tf4X1diJsx+BXtI5GDx6T0/SSBqN LnqGgxEsbVE7
SjOGd/F7+DCdTq/C9yOsP92L0RXWKSZrQJkELGfofBR4C62h5Xlw6NFVmESw zchD4WzqVN4S
BA8qjm1eKFOTSSFXjI6U9sGHcigXiUAqRVrtNEJpEnQtTXC5B/vU/nyONRUe YVPuNMVwRzEa
+a1uomlwtM8oznohQi8kiSQhz452ZYj/qo1HLk9aigM3Yy5mk8l+v4+wU4ms SycaU6UnWOjr
6mYaZZxrAXcFM51T6/wsXITzuljXQIZY8oTFZt0p54XGHA23AOFd+ilDKIWK v6sUZyAZ9NmU
FFWEex/JwxToWMrToecXPcHjpleAB5H8HyLDwVJaKLVORB4ZfzDM4T48Cf6E O9Edi7npzC+h
1uotFa/Qz8ECl1k4pFAffY/lkjBYV/ikSs296oPSWDqpuYOkERPDCmH8DT2r 0h1e+cTp5c/S
XrKGgy+kpf/P5Rfic9RwI6kuKmV+NyH2I/5sks8oJ8ZwcMw0vJRwD91RC7kn vAFVSpfYJ/HG
nJOPxbqiStbEsaJbu5RG3FnlEoHL4OUrGQybPjKxxnl79ydHiKXQyjD8Aq2g 0MrEGTLjP5zk
6L20/HytoW5nm2WHhB3UOUUT1kKTnHEMsnh87VlgEcBXW1aoddg77YxWePsX UEsBAhQDCgAA
AAAAKYwxMwAAAAAAAAAAAAAAAAkAAAAAAAAAAAAQAO1BAAAAAE1FVEEtSU5G L1BLAQIUAwoA
AAAAACmMMTMAAAAAAAAAAAAAAAAEAAAAAAAAAAAAEADtQScAAABvcmcvUEsB AhQDCgAAAAAA
KYwxMwAAAAAAAAAAAAAAAAwAAAAAAAAAAAAQAO1BSQAAAG9yZy9lY2xpcHNl L1BLAQIUAwoA
AAAAACmMMTMAAAAAAAAAAAAAAAAPAAAAAAAAAAAAEADtQXMAAABvcmcvZWNs aXBzZS91aS9Q
SwECFAMKAAAAAAApjDEzAAAAAAAAAAAAAAAAGAAAAAAAAAAAABAA7UGgAAAA b3JnL2VjbGlw
c2UvdWkvaW50ZXJuYWwvUEsBAhQDCgAAAAAAKYwxMwAAAAAAAAAAAAAAAB4A AAAAAAAAAAAQ
AO1B1gAAAG9yZy9lY2xpcHNlL3VpL2ludGVybmFsL3ZpZXdzL1BLAQIUAwoA AAAAACmMMTMA
AAAAAAAAAAAAAAAtAAAAAAAAAAAAEADtQRIBAABvcmcvZWNsaXBzZS91aS9p bnRlcm5hbC92
aWV3cy9jb250ZW50b3V0bGluZS9QSwECFAMKAAAAAAApjDEzAAAAAAAAAAAA AAAAKQAAAAAA
AAAAABAA7UFdAQAAb3JnL2VjbGlwc2UvdWkvaW50ZXJuYWwvdmlld3MvcHJv cGVydGllcy9Q
SwECFAMKAAAAAAApjDEzAAAAAAAAAAAAAAAABAAAAAAAAAAAABAA7UGkAQAA c3JjL1BLAQIU
AwoAAAAAACmMMTMAAAAAAAAAAAAAAAAIAAAAAAAAAAAAEADtQcYBAABzcmMv b3JnL1BLAQIU
AwoAAAAAACmMMTMAAAAAAAAAAAAAAAAQAAAAAAAAAAAAEADtQewBAABzcmMv b3JnL2VjbGlw
c2UvUEsBAhQDCgAAAAAAKYwxMwAAAAAAAAAAAAAAABMAAAAAAAAAAAAQAO1B GgIAAHNyYy9v
cmcvZWNsaXBzZS91aS9QSwECFAMKAAAAAAApjDEzAAAAAAAAAAAAAAAAHAAA AAAAAAAAABAA
7UFLAgAAc3JjL29yZy9lY2xpcHNlL3VpL2ludGVybmFsL1BLAQIUAwoAAAAA ACmMMTMAAAAA
AAAAAAAAAAAiAAAAAAAAAAAAEADtQYUCAABzcmMvb3JnL2VjbGlwc2UvdWkv aW50ZXJuYWwv
dmlld3MvUEsBAhQDCgAAAAAAKYwxMwAAAAAAAAAAAAAAADEAAAAAAAAAAAAQ AO1BxQIAAHNy
Yy9vcmcvZWNsaXBzZS91aS9pbnRlcm5hbC92aWV3cy9jb250ZW50b3V0bGlu ZS9QSwECFAMK
AAAAAAApjDEzAAAAAAAAAAAAAAAALQAAAAAAAAAAABAA7UEUAwAAc3JjL29y Zy9lY2xpcHNl
L3VpL2ludGVybmFsL3ZpZXdzL3Byb3BlcnRpZXMvUEsBAhQDCgAAAAgAKYwx M9UcnNKlAAAA
MwEAAAoAAAAAAAAAAAAAAKSBXwMAAC5jbGFzc3BhdGhQSwECFAMKAAAACAAp jDEz+35NWuoA
AACtAgAACAAAAAAAAAAAAAAApIEsBAAALnByb2plY3RQSwECFAMKAAAACAAp jDEz9dPdlpQA
AADtAAAAFAAAAAAAAAAAAAAApIE8BQAATUVUQS1JTkYvTUFOSUZFU1QuTUZQ SwECFAMKAAAA
CAApjDEzXHggIJcAAABfAQAAEAAAAAAAAAAAAAAApIECBgAAYnVpbGQucHJv cGVydGllc1BL
AQIUAwoAAAAIACmMMTO4QtXcSQEAADwDAABDAAAAAAAAAAAAAACkgccGAABv cmcvZWNsaXBz
ZS91aS9pbnRlcm5hbC92aWV3cy9jb250ZW50b3V0bGluZS9tZXNzYWdlc19m ci5wcm9wZXJ0
aWVzUEsBAhQDCgAAAAgAKYwxM+TzHdonAgAAbgUAAD8AAAAAAAAAAAAAAKSB cQgAAG9yZy9l
Y2xpcHNlL3VpL2ludGVybmFsL3ZpZXdzL3Byb3BlcnRpZXMvbWVzc2FnZXNf ZnIucHJvcGVy
dGllc1BLAQIUAwoAAAAIACmMMTPhRH81egEAAGcDAAAUAAAAAAAAAAAAAACk gfUKAABwbHVn
aW5fZnIucHJvcGVydGllc1BLAQIUAwoAAAAIACmMMTO4QtXcSQEAADwDAABH AAAAAAAAAAAA
AACkgaEMAABzcmMvb3JnL2VjbGlwc2UvdWkvaW50ZXJuYWwvdmlld3MvY29u dGVudG91dGxp
bmUvbWVzc2FnZXNfZnIucHJvcGVydGllc1BLAQIUAwoAAAAIACmMMTPk8x3a JwIAAG4FAABD
AAAAAAAAAAAAAACkgU8OAABzcmMvb3JnL2VjbGlwc2UvdWkvaW50ZXJuYWwv dmlld3MvcHJv
cGVydGllcy9tZXNzYWdlc19mci5wcm9wZXJ0aWVzUEsFBgAAAAAZABkAUwcA ANcQAAAAAA==
--------------050608030701080202040904--
Previous Topic:KeyListeners
Next Topic:MessageConsole BadPositionCategoryException Question
Current Time: Mon Nov 03 16:05:58 EST 2025
Powered by FUDForum. Page generated in 0.04785 seconds
