Home » Eclipse Projects » Eclipse Platform » Testing linked resource for existence
Testing linked resource for existence [message #291405] Wed, 14 September 2005 22:50 Go to next message
What is the correct/best way to test if a linked resource still points to
a local file that exists?
Checking for IFile.exists() just tells you if the linked resource is in
the repository, right?
Is there a better way than checking for
IFile.getLocation().toFile().exists()?
Ash
Re: Testing linked resource for existence [message #291492 is a reply to message #291405] Fri, 16 September 2005 14:33 Go to previous message
Originally posted by: john.eclipsefaq.org
I would suggest:
resource.refreshLocal(IResource.DEPTH_INFINITE, null);
resource.exists();
By refreshing first, you can be sure that the workspace contents match
what is on disk. However, your code snippet will also work (assuming
getLocation() does not return null).
> to a local file that exists?
> Ash
Previous Topic:How to acces to a file stored into the plugin project?
Next Topic:How to make image associate with your feature
Current Time: Thu Sep 25 14:32:14 EDT 2025
Powered by FUDForum. Page generated in 0.03747 seconds
