Home » Eclipse Projects » Eclipse Platform » problem with a plug-in depending on another project
problem with a plug-in depending on another project [message #290737] Wed, 31 August 2005 03:27 Go to next message
Originally posted by: guillaume.india.gmail.com
Hello
I had a plug-in that I decided to split up into different projects in
eclipse. I have now a plug-in that depends on another project from the
same workspace. The plug-in works until I have actions who use objects
from the depending project.
I tried to export the depending project in the buid path configuration of
the plug-in project but it does not work.
Is there a way to make it work?
thanks for your help
guillaume
Re: problem with a plug-in depending on another project [message #290743 is a reply to message #290737] Wed, 31 August 2005 04:54 Go to previous message
Originally posted by: thhal.mailblocks.com
guillaume wrote:
> Hello
> same workspace.
A plugin must have dependencies to other plugins (entered using the
manifest editor), a mere project dependency will not suffice. You can
compile using it but you can't run unless you package the plugin so that
it contain a jar from the non-plugin project.
> of the plug-in project but it does not work.
The simplest way is to make both projects plugins and change the project
dependency to a plugin dependency.
If you for some reason don't want to convert one of the projects to a
plugin, then you can use a jar packager and then bundle that jar as a
runtime dependency in the plugin.
Thomas Hallgren
Previous Topic:Atomic workspace changes
Next Topic:Headless build, automated Junit tests and code coverage
Current Time: Sun Jul 27 22:58:52 EDT 2025
Powered by FUDForum. Page generated in 0.23938 seconds
