control handle in X [message #290005] |
Tue, 16 August 2005 22:07  |
Originally posted by: ubguada.hotmail.com
Hi all
I'm trying to access the underlying X window structure of an SWT control.
On Windows control.handle will be exactly the same as the control's HWND.
But on X what's the relationship? Is it a Display*?
Thanks!
Re: control handle in X [message #290092 is a reply to message #290032] |
Thu, 18 August 2005 10:59   |
Originally posted by: bbiggs.ca.ibm.com
Ulisses wrote:
>> If you create a Composite with the style SWT.EMBEDDED style, then under
>>SWT/GTK+ Composite.embeddedHandle will be an X window ID you can use for
>>parenting an XEMBED child. Maybe this is what you're looking for.
> In fact, Im trying to get a (X) ::Window handle from an arbitrary
> org.eclipse.swt.widgets.Control object.
> Not sure if it is even possible to do it in a cross-platform way.
> It works wonderfully under Windows but fails miserably under Linux/Gtk.
> Here's what I'm getting so far.
> Window 0 created from handle 136011016 (that's my programs output)
> The error was 'BadWindow (invalid Window parameter)'.
> (Details: serial 8 error_code 3 request_code 3 minor_code 0)
You're doing XGetWindowAtributes on something that isn't a window.
If you need the X window, there's no way to do this from the public
SWT API (even going through internals), and furthermore even if there
was a way I don't think you could guarentee it for all controls. I'm
not sure if this works but the closest you could get might be to:
1. make Control.fixedHandle public
2. Use OS.GTK_WIDGET_WINDOW (control.fixedHandle) to get a GdkWindow
3. Use OS.gdk_x11_drawable_get_xid (gdkWindow) to translate that to
an X window
I guess the other way might be to take Control.handle, and then call
GTK_WIDGET_WINDOW() on it, or if that's null keep calling it on its
parents until you find one with a GdkWindow, and then translate that to
an X window.
The difficulty here is that SWT talks to GTK+, which talks to GDK,
which then talks to X. So, there's three layers between you and the X
window.
-Billy
Re: control handle in X [message #290097 is a reply to message #290089] |
Thu, 18 August 2005 11:32  |
Originally posted by: sunil_kamath.nohotspammail.com
"Ulisses" <ubguada@hotmail.com> wrote in message
news:de233i$94p$1@news.eclipse.org...
>> See for yourself. Do a search.
> I knew your unwillingness to help was just plain bluff.
> Good luck mister, you'll certainly need it.
Your unwillingness to do anything for yourself indicates that the more
pressing need for luck is surely yours.
Sunil
FUDForum. Page generated in 0.05448 seconds
