Home » Eclipse Projects » Eclipse Platform » Eclipse 3.1 Remote Debug - Start Tomcat 5.5 in debug mode on WinXP?
Eclipse 3.1 Remote Debug - Start Tomcat 5.5 in debug mode on WinXP? [message #289329] Wed, 03 August 2005 14:58 Go to next message
Originally posted by: rick.strong.med.nyu.edu
I would like to debug servlets using Eclipse 3.1, servlets are running
on Tomcat 5.5 on a WinXP machine, but I'm having a bit of difficulty
finding the right way to start Tomcat in debug mode and connecting to it
with the Eclipse debugger.
I would be most grateful for any tips, pointers to HOWTOs, or any other
info that specifically targets WinXP and the current version of Tomcat.
Rick Strong
Re: Eclipse 3.1 Remote Debug - Start Tomcat 5.5 in debug mode on WinXP? [message #289331 is a reply to message #289329] Wed, 03 August 2005 15:07 Go to previous messageGo to next message
start tomcat from a command shell with
"catalina.bat jpda start"
Configure Eclipse "Run->Debug..."
create new "Remote Java Application" Entry and configure the port to 8000
press the 'Debug' button....
...thats all (I hope!!)
greetings
Andreas
Re: Eclipse 3.1 Remote Debug - Start Tomcat 5.5 in debug mode on WinXP? [message #289333 is a reply to message #289331] Wed, 03 August 2005 15:28 Go to previous messageGo to next message
Thanks for the reply,
When I installed Tomcaton XP, I ended up with no .BAT files. New
feature? I expect there is another way to pass debug configuration info
to the service, but I've been unsuccessful so far.
Rick
FreeGroup wrote:
> Hi
> greetings
> Andreas
Re: Eclipse 3.1 Remote Debug - Start Tomcat 5.5 in debug mode on WinXP? [message #289468 is a reply to message #289333] Fri, 05 August 2005 08:13 Go to previous messageGo to next message
don't use the tomcat installation .exe
You can find a tomcat_xyz.zip on the jakarta webSite.
unzip the package in any directory. In the bin directory is
the required catalinat.bat
> Rick
> FreeGroup wrote:
>> Hi
>> greetings
>> Andreas
Re: Eclipse 3.1 Remote Debug - Start Tomcat 5.5 in debug mode on WinXP? [message #289737 is a reply to message #289468] Wed, 10 August 2005 10:40 Go to previous message
Andreas,
Thanks very much, I've got it working now. So much better than 2500
println() statements :-)
Rick
>> info to the service, but I've been unsuccessful so far.
>> Rick
>> FreeGroup wrote:
>>> Hi
>>> 8000
>>> greetings
>>> Andreas
Previous Topic:How to install the EclipseUML Free Edition plugin...
Next Topic:Missing Variable Information When Debuging
Current Time: Wed Nov 05 12:00:15 EST 2025
Powered by FUDForum. Page generated in 0.03554 seconds
