Home » Eclipse Projects » Eclipse Platform » How to add jar to .classpath
How to add jar to .classpath [message #289063] Thu, 28 July 2005 08:10 Go to next message
Originally posted by: andreas140983.libero.it
I have create a plugin that in one of his functionality it add to the
classpath file of an existent project any library.
How to do this?
There is any method associated to the IProject that I can use?
Excuse for my English but I come from Italy!
Thanks, Andrea
Re: How to add jar to .classpath [message #289065 is a reply to message #289063] Thu, 28 July 2005 09:23 Go to previous messageGo to next message
Excuse I correct me, the .classpath is a file inside every javaProject!
Re: How to add jar to .classpath [message #289100 is a reply to message #289065] Fri, 29 July 2005 04:18 Go to previous messageGo to next message
I use:
IJavaProject javaProject=...;
IClasspathEntry[] entries = javaProject.getRawClasspath();
IClasspathEntry[] newEntries = new IClasspathEntry[entries.length + 1];
System.arraycopy(entries, 0, newEntries, 0, entries.length);
IClasspathEntry newEntry = JavaCore.newLibraryEntry(new Path("path to
library"),null, null);
newEntries[entries.length] = newEntry;
javaProject.setRawClasspath(newEntries, null);
bye
"Andrea Sichel" <andreas140983@libero.it> schrieb im Newsbeitrag
news:68f942b9192970e6bbd11b0bf07ef060$1@www.eclipse.org...
Re: How to add jar to .classpath [message #289106 is a reply to message #289100] Fri, 29 July 2005 06:56 Go to previous messageGo to next message
Excuse me but I have an error when I would use the IJavaProject.
I write this code:
IJavaProject JavaProject=
(IJavaProject)ResourcesPlugin.getWorkspace().getRoot().getPr oject( "name of
my project");
this line cause an error in my code and I don't say why!
You can help me?
Re: How to add jar to .classpath [message #289111 is a reply to message #289106] Fri, 29 July 2005 10:24 Go to previous messageGo to next message
getProject() returns an IProject, not an IJavaProject so you are getting
a ClassCastException.
To get the IJavaProject from an IProject you would do
JavaCore.create(IProject).
> I write this code:
> of my project");
> You can help me?
Rich Kulp
Re: How to add jar to .classpath [message #289119 is a reply to message #289111] Fri, 29 July 2005 12:10 Go to previous messageGo to next message
Thanks very much!!
I have resolved this problem but I have another problem:
how I can control if a library is already present before I try to insert
it?
In other words if, for example, the project created by a user has already
the library "soap.jar" and with my plugin I would to insert the same
"soap.jar", eclipse return me an error and stop the execution of my plugin.
How I can control if this library is already present?
Excuse me for my bad English but I'm Italian!
Thanks, Andrea
Re: How to add jar to .classpath [message #289121 is a reply to message #289119] Fri, 29 July 2005 12:18 Go to previous messageGo to next message
You need to get the classpath entries from the IJavaProject and see if
already there.
> Thanks very much!!
> it?
> already the library "soap.jar" and with my plugin I would to insert the
> same "soap.jar", eclipse return me an error and stop the execution of my
> plugin.
> Thanks, Andrea
Rich Kulp
Re: How to add jar to .classpath [message #289142 is a reply to message #289121] Sat, 30 July 2005 09:54 Go to previous messageGo to next message
But I have to control the entirely path of the library that I would to
insert or only the name of the library?
In other words, if I have to insert the soap.jar and the user have already
insert it(the path is for example c:/library/soap.jar), I have to
controlonly "soap.jar" or "c:/library/soap.jar"?
Thanks, Andrea
Re: How to add jar to .classpath [message #289643 is a reply to message #289142] Tue, 09 August 2005 10:41 Go to previous message
If it is an external jar, then you need to fully-qualify it, the entire
path.
So if the user already added c:/library/soap.jar then you should not add
it again.
> already insert it(the path is for example c:/library/soap.jar), I have
> to controlonly "soap.jar" or "c:/library/soap.jar"?
> Thanks, Andrea
Rich Kulp
Previous Topic:Load/access external icons, files and other resources
Next Topic:Annotations in external file
Current Time: Sat Jul 19 02:04:24 EDT 2025
Powered by FUDForum. Page generated in 0.11474 seconds
