Home » Eclipse Projects » Eclipse Platform » IncrementalProjectBuilder args variable question
IncrementalProjectBuilder args variable question [message #287578] Mon, 04 July 2005 05:17 Go to next message
hi,
i use the IncrementalProjectBuilder to build my project compilation files.
method build has the parameter "Map args" but the hash is empty every
time. for what is it used? can i use the map for something? (especially i
wan't to know the reason of the build(if a project reference has been
attached or removed...))
thx
mseele
Re: IncrementalProjectBuilder args variable question [message #287637 is a reply to message #287578] Tue, 05 July 2005 13:31 Go to previous message
The map is used to supply constant arguments. They are supplied through
the .project file that defines the usage of the builder.
As for the reason for the build, that comes from the delta that is
supplied to it.
See:
http://eclipse.org/articles/Article-Builders/builders.html
For how builders work.
Rich Kulp
Previous Topic:Community driven translations
Next Topic:TableTreeViewer deprecation?
Current Time: Wed Nov 05 17:45:20 EST 2025
Powered by FUDForum. Page generated in 0.02969 seconds
