Home » Newcomers » Newcomers » Eclipse on Terminal Server
Eclipse on Terminal Server [message #28609] Mon, 21 February 2005 03:39 Go to next message
Originally posted by: matteogiacometti.luxottica.com
Hi!
Is it possible to run Eclipse 3 on a Windows terminal server?
Are there any precautions to observe?
Thanks in advance
Matteo
Re: Eclipse on Terminal Server [message #28612 is a reply to message #28609] Mon, 21 February 2005 07:27 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
If it will be accessed by several users simultaneously, you might want
to take caution that Eclipse creates a .lock file preventing you from
launching Eclipse twice.
Look into using command-line parameters to specify the user's home
directory for the workspace and for the lockfiles (use Windows'
%USERNAME% variable for this).
Good luck
Matteo wrote:
> Hi!
> Thanks in advance
> Matteo
Re: Eclipse on Terminal Server [message #28618 is a reply to message #28612] Mon, 21 February 2005 08:02 Go to previous messageGo to next message
My idea is to install Eclipse on terminal server.
Then (this is my goal) several users should be able to run it
simultaneously.
Any user should have his workspace, and all users should be able to use
eclipse and its plug-ins simultaneously.
Anyone experienced?
thank you again
Matteo
> Good luck
> Matteo wrote:
>> Hi!
>> Thanks in advance
>> Matteo
Re: Eclipse on Terminal Server [message #28635 is a reply to message #28618] Mon, 21 February 2005 13:32 Go to previous messageGo to next message
Originally posted by: poppenhe.umich.edu
sounds like you already got your answer...
> simultaneously.
> Anyone experienced?
> thank you again
> Matteo
>> Good luck
>> Matteo wrote:
>>> Hi!
>>> Thanks in advance
>>> Matteo
Re: Eclipse on Terminal Server [message #28687 is a reply to message #28635] Tue, 22 February 2005 05:54 Go to previous messageGo to next message
I'm able to install GEF plug-in, but when I try to install (I'm connecting
to terminal server via remote desktop connection with an administrator
user) JFaceDbc e sunshinereports plug-ins, the import wizard doesn't find
them.
Every user has his own workspace.
Any suggestions about this?
thank you
Matteo
>> simultaneously.
>> Anyone experienced?
>> thank you again
>> Matteo
>>> Good luck
>>> Matteo wrote:
>>>> Hi!
>>>> Thanks in advance
>>>> Matteo
Re: Eclipse on Terminal Server [message #56676 is a reply to message #28687] Sun, 24 April 2005 11:22 Go to previous message
> connecting to terminal server via remote desktop connection with an
> administrator user) JFaceDbc e sunshinereports plug-ins, the import
> wizard doesn't find them. Every user has his own workspace.
Use common extension location for system-wide plugins and personal
extension location for user-specific plugins.
MAN-UANIC
Eclipse.org downloads @ http://eclipse.osdn.org.ua/
Previous Topic:config tomcat source javadoc
Next Topic:verilog
Current Time: Sun Jun 15 18:04:21 EDT 2025
Powered by FUDForum. Page generated in 0.12227 seconds
