newbie needs urgent help please [message #28546] |
Fri, 18 February 2005 13:27  |
Originally posted by: rudy-e.gmx.net
I'm new to eclipse and the world of java programming. I have been using
eclipse for 3 days now every thing was good.I just did some
installations(this time other tools.Now eclipse doesn't start again. I
found this line of message in a file(Eclipse directed me to) in the
configuration folder.
!MESSAGE Bundle
initial@reference :file:c:/Eclipse/eclipse/plugins/org.eclipse.core.runtime_3. 0.1/
[1] was not resolved.
What should I do? Help please.Thanks
Re: newbie needs urgent help please [message #28600 is a reply to message #28577] |
Sun, 20 February 2005 23:15   |
Chris Laffra wrote:
> While installing the other tools, you probably corrupted your existing
> configuration.
> I would reinstall eclipse in a different directory and try again.
I did reinsatll eclipse in another directory but the problem still
pserist.I deinsatll and reinstall java SDk but the problem still persist.
HERE IS THE ERROR MESSAGE located in the configuration directory.
!SESSION Feb 20, 2005 20:02:40.247
eclipse.buildId=M200409161125
java.version=1.3.1_01
!ENTRY org.eclipse.osgi Feb 20, 2005 20:02:40.247
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(EclipseAdaptor.java:272)
at
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdaptor.java:253)
at
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemBundleActivator.java:61)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:553)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:477)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:216)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.osgi Feb 20, 2005 20:02:40.307
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:557)
at
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:111)
at
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:660)
at
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:233)
at
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:191)
at
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
at
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:280)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:451)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
at
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
at
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:659)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:219)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:800)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:429)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
at
!ENTRY org.eclipse.osgi Feb 20, 2005 20:02:40.317
!MESSAGE Bundle
initial@reference :file:c:/eclipse-SDK-3.0.1-win32/eclipse/plugins/org.eclipse .core.runtime_3.0.1/
COULD ANY ONE HELP ME? I WOULD RELY MUCH APPRECIATE ANY HELP.THANKS
Re: newbie needs urgent help please [message #28602 is a reply to message #28600] |
Mon, 21 February 2005 00:38   |
Originally posted by: windheavennights.aol.com
I am having this very same problem. I had a previously installed java SDK
on my hard drive and then I downloaded eclipse as a zip file and extracted
it to where I wanted it. I then tried to run the program but it said I
needed the JRE. I downloaded that and installed it and then I recieved
this same error. I am not sure why this is occuring. I reinstalled my java
sdk's and the JRE as well as unzipped eclipse again. Any help would be
much appreciated.
James
Rudy wrote:
>> configuration.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Bundle
Re: newbie needs urgent help please [message #28616 is a reply to message #28602] |
Mon, 21 February 2005 07:50   |
Originally posted by: Chris_Laffra.ca.ibm.com
You need a 1.4 VM to run Eclipse 3.0. See the note on the download page.
Chris Laffra, http://eclipsefaq.org
"James" <windheavennights@aol.com> wrote in message
news:cvbs4h$h66$1@www.eclipse.org...
> much appreciated.
> James
> Rudy wrote:
> >> configuration.
> > Hi,
persist.
> > !STACK 0
> > at
> > at
r.java:253)
> > at
> > at
xtImpl.java:958)
> > at
> > at
xtImpl.java:937)
> > at
> > at
lManager.java:477)
> > at
> > at
Manager.java:243)
> > at
va:166)
> > at
> > at
216)
> > at
> > !STACK 1
> > at
> > at
> > at
> > at
undleData.java:233)
> > at
eData.java:191)
> > at
Data.java:159)
> > at
undleData.java:280)
> > at
> > at
> > at
ramework.java:746)
> > at
> > at
ava:715)
> > at
ava:659)
> > at
> > at
r.java:800)
> > at
ter.java:429)
> > at
222)
> > at
> > !MESSAGE Bundle
initial@reference:file:c:/eclipse-SDK-3.0.1-win32/eclipse/plugins/org.eclips
e.core.runtime_3.0.1/
Re: newbie needs urgent help please [message #28672 is a reply to message #28668] |
Mon, 21 February 2005 18:08  |
Until the next time some other software installer changes your path
variable...
Darins
"Rudy" <rudy-e@gmx.net> wrote in message
news:cvdp8m$p03$1@www.eclipse.org...
> Rudy wrote:
>> I have j2sdk1-4-2 installed. I do not think that is the real problem
>> here. What I think is that the initial VM path has been changed by the
>> programms I later on installed. How can I change the VM path to
>> c:j2sdk1-4-2binjavaw ?. I think this might be the issue here. Could any
>> one tell me how to change this?
> THE PROBLEM HAS BEEN SOLVED.I DID THE FOLLOWING: I edited the Path
> variables to point to c:\j2sdk1-4-2.( right click on my
> computer-->properties-->under Advance in WIN XP and click on Environment
> virables.--> Click edit and change the path to point ot your java path.
> Click ok and start up eclipse again.) Every thing went well.
FUDForum. Page generated in 0.40909 seconds
