Home » Eclipse Projects » Eclipse Platform » 3.x Preference Scopes and Nodes Confusion
3.x Preference Scopes and Nodes Confusion [message #284212] Tue, 19 April 2005 16:06 Go to next message
Originally posted by: mark_melvin.amis.com
Hi All,
I have been messing about with scoped preferences in 3.1M6, and I find
them to be very cool, but I have a point I am confused on, and I need
some help.
I am writing a whole whack of preferences to a ProjectScope-based
preference, let's call it "myprefs", in project "MyProject". What this
does is create a file in my project (as expected and desired) called
MyProject/.settings/myprefs.prefs
One of my use cases dictates that I delete all preferences defined in
this particular node, and replace them with a new set. So, what I am
doing is something like the following:
// "project" is a reference to MyProject
IScopeContext context = new ProjectScope(project);
// Get rid of all existing preferences
IEclipsePreferences baseNode = context.getNode("myprefs");
Preferences parent = baseNode.parent();
baseNode.removeNode();
// Flush to make removal permanent
if (parent != null) {
parent.flush();
This *seems* to work, as accessing any preferences seems to fail,
however - what I am seeing is that I still have the file
"MyProject/.settings/myprefs.prefs" sitting in my project, full of
preferences. How can I make the preferences framework delete this file?
I basically want a brute force method of clearing all preferences in a
node (including the file in which they are persisted), without
necessarily knowing all of the children in that node. Otherwise, this
file gradually accumulates cruft. What am I doing wrong here?
Mark.
Re: 3.x Preference Scopes and Nodes Confusion [message #284219 is a reply to message #284212] Tue, 19 April 2005 16:39 Go to previous messageGo to next message
Answering my own question - this seems to do what I want... I guess
this is the way to go about it?
try {
removePreferenceNode(baseNode);
} catch ...
public static void removePreferenceNode(Preferences node) throws
BackingStoreException {
String[] children = node.childrenNames();
// Remove all keys in this node
node.clear();
// Now remove all children nodes
for (int i = 0; i < children.length; i++) {
node.node(children[i]).removeNode();
// Persist to backing store
node.flush();
Mark Melvin wrote:
> Hi All,
> some help.
> parent.flush();
> Mark.
Re: 3.x Preference Scopes and Nodes Confusion [message #284302 is a reply to message #284219] Wed, 20 April 2005 14:08 Go to previous messageGo to next message
Originally posted by: dj_houghton.nospam.ca.ibm.com
Hmm...smells like a bug. Entered bug 92123.
> try {
> } catch ...
> node.clear();
> node.flush();
> Mark Melvin wrote:
>> Hi All,
>> some help.
>> this does is create a file in my project (as expected and desired) called
>> parent.flush();
>> file? I basically want a brute force method of clearing all
>> preferences in a node (including the file in which they are
>> persisted), without necessarily knowing all of the children in that
>> node. Otherwise, this file gradually accumulates cruft. What am I
>> doing wrong here?
>> Mark.
Re: 3.x Preference Scopes and Nodes Confusion [message #284341 is a reply to message #284302] Thu, 21 April 2005 09:56 Go to previous message
Ah, I wasn't sure if this was desired behaviour or not. I guess I
should have just opened the bug anyway - so thanks for doing it for me...
...adding myself on CC list.
Mark.
>> try {
>> } catch ...
>> node.clear();
>> node.flush();
>> Mark Melvin wrote:
>>> Hi All,
>>> find them to be very cool, but I have a point I am confused on, and I
>>> need some help.
>>> called
>>> parent.flush();
>>> doing wrong here?
>>> Mark.
Previous Topic:How to disable Watchpoints
Next Topic:Opening a single editor
Current Time: Fri Jul 25 12:13:18 EDT 2025
Powered by FUDForum. Page generated in 0.05017 seconds
