Home » Eclipse Projects » Eclipse Platform » how to export jars from plugin in 3.0 bundle
how to export jars from plugin in 3.0 bundle [message #283915] Wed, 13 April 2005 15:53 Go to next message
Hi all
I have a plugin that includes some jars in lib/ I'd like all these jars
to be exported so I can use them from another plugin, is there a simple
way of doing this?
Re: how to export jars from plugin in 3.0 bundle [message #283916 is a reply to message #283915] Wed, 13 April 2005 15:54 Go to previous messageGo to next message
If you need to use them from another plugin you need to put them as
libraries in your plugin.xml and export them. Just like any other
runtime jar in a plugin.
Miguel Griffa wrote:
> Hi all
> way of doing this?
Rich Kulp
Re: how to export jars from plugin in 3.0 bundle [message #283919 is a reply to message #283916] Wed, 13 April 2005 16:44 Go to previous messageGo to next message
my plugin.xml does not contain any (old style?) <library tag
these are defined in manifes.mf
like this:
Bundle-ClassPath:
lib/jaxen-core-1.0-fcs.jar,lib/saxpath-1.0-fcs.jar,lib/xerce sImpl-2.6.2.jar,lib/xmlParserAPIs-2.6.2.jar,pmd-eclipse.jar, lib/pmd-3.0.jar
I have not found a way of re-exporting this
>> Hi all
>> jars to be exported so I can use them from another plugin, is there a
>> simple way of doing this?
Re: how to export jars from plugin in 3.0 bundle [message #283924 is a reply to message #283919] Wed, 13 April 2005 19:11 Go to previous messageGo to next message
The plugin manifest should be able to help with that. Try it out.
Rich Kulp
Re: how to export jars from plugin in 3.0 bundle [message #283962 is a reply to message #283924] Thu, 14 April 2005 11:32 Go to previous messageGo to next message
I've tried (without success) the following
<?eclipse version="3.0"?>
<plugin export="true">
<runtime>
[ ...more libs like this ... ]
<library name="pmd-eclipse.jar">
<export name="*"/>
</library>
<library name="lib/pmd-3.0.jar">
<export name="*"/>
</library>
</runtime>
any ideas?
Re: how to export jars from plugin in 3.0 bundle [message #283966 is a reply to message #283962] Thu, 14 April 2005 12:29 Go to previous messageGo to next message
You said you were using the manifest approach, in that case you wouldn't
add libraries to the plugin.xml file itself. I was thinking you would
you the "Runtime" page of the manifest editor to define your libraries.
Then the editor should know you were in the new manifest mode and update
the manifest for you. I've never tried it, but they said it works.
Rich Kulp
SOLVED Re: how to export jars from plugin in 3.0 bundle [message #283970 is a reply to message #283966] Thu, 14 April 2005 13:41 Go to previous message
I installed eclipse 3.1M6, and the manifest editor confirmed some things:
<runtime>
<library>...
is ignored if MANIFEST.MF is present
I had to specify all packages to export, in the editor, The editor is
wise enough to present only packages in plugin and not already exported.
I came up with a pretty long list of exported packages, but it worked
well then
Thanks for the help
Previous Topic:Args passed to IPlatformRunnable
Next Topic:any help with a message board and chat functionality in eclipse plugin
Current Time: Tue Nov 04 04:47:56 EST 2025
Powered by FUDForum. Page generated in 0.06926 seconds
