No javaME project [message #28221] |
Sat, 28 March 2009 08:02  |
I just installed MJT version 1.0 stable.
Problem:
-In Windows/Preferences JavaME doesn't appear
-In New/Project I don't have the option for JavaME
I have eclipse Version: 3.3.2 Build id: M20080221-1800
I installed MJT version 1.0 stable.
I modified the config.ini file.
In the plugin list I have:
-org.eclipse.mtj.branding 0.9.0.v200903210230
-org.eclipse.mtj.core.hooks 0.9.0.v200903210230
-org.eclipse.mtj.docs.isv 1.0.0.v200903210230
-org.eclipse.mtj.doc.user 0.9.0.v200903210230
-org.eclipse.mtj.example.so 1.0.0.v200903210230
-org.eclipse.mtj.source 1.0.0.v200903210230
Anna
Re: No javaME project [message #28262 is a reply to message #28221] |
Mon, 30 March 2009 07:03  |
Hi Anna,
MTJ 1.0 only support Eclipse SDK 3.4.x or 3.5.x because we require some
features that were only made available in the 3.4 version.
If you require using the eclipse version 3.3.2 I suggest that you try to
use MTJ 0.9.1 but if not, you could upgrade your eclipse installation to a
3.4.x version or higher and try out the new MTJ 1.0M6 version :)
Diego
Re: No javaME project [message #572165 is a reply to message #28221] |
Hi Anna,
Diego
FUDForum. Page generated in 0.03283 seconds
