Home » Eclipse Projects » Eclipse Platform » Intercepting
Intercepting [message #282537] Tue, 15 March 2005 20:31 Go to next message
Originally posted by: sabell.txesystems.com
I'm using EMF to generate a model and the associated simple UI.
When I use the right-click menu to create a new child of an item in a tree,
I need to intercept that object before it is added to its parent and make
some modifications.
Where can one get ahold of this child just before it is added?
Steve
Re: Intercepting [message #282551 is a reply to message #282537] Wed, 16 March 2005 08:07 Go to previous messageGo to next message
--------------080608090704040402020305
Steve,
You can modify the generated method:
protected void collectNewChildDescriptors(Collection
newChildDescriptors, Object object)
to initialize the new instance however you like.
>some modifications.
>Thanks,
>Steve
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Steve,<br>
<br>
You can modify the generated method:<br>
<blockquote>protected void collectNewChildDescriptors(Collection
newChildDescriptors, Object object)<br>
</blockquote>
to initialize the new instance however you like.<br>
<br>
<br>
<blockquote cite="midd1826g$7pl$1@www.eclipse.org" type="cite">
<pre wrap="">I'm using EMF to generate a model and the associated simple UI.
some modifications.
Steve
</pre>
</blockquote>
<br>
</body>
</html>
--------------080608090704040402020305--
Re: Intercepting [message #282571 is a reply to message #282551] Wed, 16 March 2005 11:53 Go to previous messageGo to next message
------=_NextPart_000_004E_01C52A05.970FB800
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Unfortunately, that won't work here.
I need to get the single object that is actually selected.
Modifying all objects that are created in collectNewChildDescriptors()
will create an unrecoverable mess in this situation.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:d19b26$6bv$1@www.eclipse.org...
Steve,
protected void collectNewChildDescriptors(Collection =
Steven T Abell wrote:=20
When I use the right-click menu to create a new child of an item in a =
tree,
I need to intercept that object before it is added to its parent and =
make=20
some modifications.
Steve
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.2604" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Unfortunately, that won't work =
here.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I need to get the single object that is =
actually=20
selected.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Modifying all objects that are created =
in=20
collectNewChildDescriptors()</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>will create an unrecoverable mess in =
this=20
situation.</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:d19b26$6bv$1@www.eclipse.org">news:d19b26$6bv$1@www.eclipse.=
org</A>...</DIV>Steve,<BR><BR>You=20
can modify the generated method:<BR>
<BLOCKQUOTE>protected void collectNewChildDescriptors(Collection=20
newChildDescriptors, Object object)<BR></BLOCKQUOTE>to initialize =
the new=20
instance however you like.<BR><BR><BR>Steven T Abell wrote:=20
<BLOCKQUOTE cite=3Dmidd1826g$7pl$1@www.eclipse.org type=3D"cite"><PRE =
wrap=3D"">I'm using EMF to generate a model and the associated simple =
UI.
tree,
make=20
some modifications.
Steve
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_004E_01C52A05.970FB800--
Re: Intercepting [message #282608 is a reply to message #282571] Wed, 16 March 2005 16:04 Go to previous message
--------------080307060006080006090505
Steve,
Your comment seems to imply that the initialization of the new child
will depend on where you add it. Is that true? If so, Marcos comment
about overriding the create child command behavior is the way to go...
(This question is asked in so many newsgroups, where EMF seems the only
place you should ask this.)
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:d19b26$6bv$1@www.eclipse.org...
> Steve,
>>some modifications.
>>Thanks,
>>Steve
<html>
<head>
</head>
Steve,<br>
<br>
will depend on where you add it.&nbsp; Is that true?&nbsp; If so, Marcos comment
about overriding the create child command behavior is the way to go...&nbsp;
place you should ask this.)<br>
<br>
<br>
<blockquote cite="midd19o5v$jka$1@www.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.2604" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Unfortunately, that won't work here.</font></div>
<div><font face="Arial" size="2">I need to get the single object that
is actually selected.</font></div>
<div><font face="Arial" size="2">Modifying all objects that are
created in collectNewChildDescriptors()</font></div>
<div><font face="Arial" size="2">will create an unrecoverable mess in
this situation.</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" &lt;<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>&gt;
wrote in message <a href="news:d19b26$6bv$1@www.eclipse.org">news:d19b26$6bv$1@www.eclipse.org</a>...</div>
Steve,<br>
<br>
</blockquote>
<br>
<br>
some modifications.
Steve
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------080307060006080006090505--
Previous Topic:Adding Ant launch from context menu
Next Topic:junit-plug-in-test
Current Time: Sun Nov 09 14:59:12 EST 2025
Powered by FUDForum. Page generated in 0.03390 seconds
