Home » Eclipse Projects » Eclipse Platform » Howto terminate external editor launched with IEditorLauncher or force GC?
Howto terminate external editor launched with IEditorLauncher or force GC? [message #282465] Mon, 14 March 2005 05:05 Go to next message
Originally posted by: de_klutzie.yahoo.com
Hi people~
I'm writing a plugin for Eclipse 3, and in my plugin, user is able to
launch an external editor. I'm implementing the
org.eclipse.ui.IEditorLauncher, and the open(IPath) API is used to launch
my external editor. My editor is a Frame, which allows me to edit some of
my stuff.
I realize when the external editor is launched, it is actually using the
same VM which eclipse is using, and of course, memory usage of this VM
increased whenever i launch the editor. However when I close my editor,
the memory usage remains the same (it doesn't drop).
Is there anyway to solve this problem? I've tried to de-reference all the
instances that i've created and called a garbage collection, but it
doesn't help. Calling System.exit(int) will definately wont help as the
whole Eclipse will be terminated.
Is there a way to terminate this external editor? Or to free up the memory
usage?
And by the way, i've tried to force a garbage collection within my editor,
but it doesnt seem to be working. I've tried to run my editor in a
standalone version (not in eclipse) and profiled the execution, the
garbage collection works, and it actually free up the memory, but not in
the eclipse environment. Any idea?
Would really appreciate the help.
klutzie
Re: Howto terminate external editor launched with IEditorLauncher or force GC? [message #282483 is a reply to message #282465] Mon, 14 March 2005 13:38 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
klutzie wrote:
> Hi people~
> launch my external editor. My editor is a Frame, which allows me to edit
> some of my stuff.
According to whom? Are you using the windows task manager or Linux
equivalent to check the memory, or java.lang.System calls?
> the instances that i've created and called a garbage collection, but it
Do you think you have a memory leak? Or do you just not like seeing the
number so high? You can't force garbage collection, you can only
request it. Nothing is guaranteed to be done though. If you really
want to see the garbage collector run to find out if one of your classes
is being collected or not, you can add an array of say, 1,000,000 byte
to one of your classes, and I think Java will be more agressive at
collecting it just so you can see what is goign on.
> memory usage?
The memory will be reclaimed when the JVM requires it. Not a minute
before, unless repeated calls to GC may get you back a few bytes if they
are not referenced (and your lucky)
> editor, but it doesnt seem to be working. I've tried to run my editor in
> a standalone version (not in eclipse) and profiled the execution, the
The JVM is not going to be giving back memory to the OS if that is what
you are wondering. You can adjust the JVM memory settings with stuff
like -Xmx100m and -Xms50m.
> Thanks
> klutzie
If you are DEAD SET on seeing that memory back try -Xincgc to turn on
the incremental garbage collector.
Hope that helped,
CL
Re: Howto terminate external editor launched with IEditorLauncher or force GC? [message #282497 is a reply to message #282483] Mon, 14 March 2005 23:22 Go to previous messageGo to next message
Hi CL, thanks for the fast reply.
Yes, I'm using the Window Task Manager to check for the memory usage.
The scenario is like this. The editor for my plugin works just fine for
the first few instances, but after that, it started to become slower and
slower, and in the end, it hangs. I realized there are continuous increase
of the memory usage for my eclipse (from the Windows Task Manager),
everytime when i load my editor. Somehow the resources cannot be released,
even when the memory usage reaches the peak, thus causing my eclipse and
editor to hang. Things resume normal after i restart my eclipse.
I've tried to use JProfiler to profile a standalone version of my editor
(running outside eclipse), and everytime when I close a window in my
editor (my editor may consist more than one window), I call System.gc(),
and it works. In JProfiler, it shows that resources are actually released.
However it doesn't seems to be working when i run my editor within eclipse.
My editor will be used by other developers, and thus it may not be a good
approach to ask the developers to set parameters for their eclipse. But i
will definately try out the incremental garbage collection thingy.
Any suggestion, anyone?
klutzie
CL [dnoyeb] Gilbert wrote:
> klutzie wrote:
>> Hi people~
>> some of my stuff.
>> memory usage?
>> Thanks
>> klutzie
> Hope that helped,
> CL
Re: Howto terminate external editor launched with IEditorLauncher or force GC? [message #282514 is a reply to message #282497] Tue, 15 March 2005 09:13 Go to previous messageGo to next message
Looks like you have a memory leak and the incremental GC is not going to
help you. Im not familiar with JProfiler, but if it can, you should
find what is holding on to references to your Frame. Somehow after the
Frame is closed, the reference is not being released.
I have had to jump through hoops myself with my editors to ensure
Eclipse does not hold onto them. Such as making my IEditorInput not
persistable, and making it light weight since the IEditorInputs may be
held onto by the eclipse architecture. But my editors are internal.
> increase of the memory usage for my eclipse (from the Windows Task
> Manager), everytime when i load my editor. Somehow the resources cannot
> be released, even when the memory usage reaches the peak, thus causing
> my eclipse and editor to hang. Things resume normal after i restart my
> eclipse.
> released. However it doesn't seems to be working when i run my editor
> within eclipse.
> good approach to ask the developers to set parameters for their eclipse.
> But i will definately try out the incremental garbage collection thingy.
> klutzie
>> klutzie wrote:
>>> Hi people~
>>> edit some of my stuff.
>>> the same VM which eclipse is using, and of course, memory usage of
>>> this VM increased whenever i launch the editor. However when I close
>>> my editor, the memory usage remains the same (it doesn't drop).
>>> it doesn't help. Calling System.exit(int) will definately wont help
>>> as the whole Eclipse will be terminated.
>> the number so high? You can't force garbage collection, you can only
>> classes is being collected or not, you can add an array of say,
>> 1,000,000 byte to one of your classes, and I think Java will be more
>> agressive at collecting it just so you can see what is goign on.
>>> memory usage?
>> they are not referenced (and your lucky)
>>> in a standalone version (not in eclipse) and profiled the execution,
>>> the garbage collection works, and it actually free up the memory, but
>>> not in the eclipse environment. Any idea?
>> what you are wondering. You can adjust the JVM memory settings with
>> stuff like -Xmx100m and -Xms50m.
>>> Thanks
>>> klutzie
>> Hope that helped,
>> CL
Re: Howto terminate external editor launched with IEditorLauncher or force GC? [message #282536 is a reply to message #282514] Tue, 15 March 2005 19:51 Go to previous messageGo to next message
The thing that is bugging is that, how come when i call System.gc() when
im running my editor in a standalone version, the resources can be
released, but not within eclipse...
anyway, thanks a lot CL for sharing your knowledge. :)
klutzie
>> eclipse.
>> within eclipse.
>> klutzie
>>> klutzie wrote:
>>>> Hi people~
>>>> memory usage?
>>>> Thanks
>>>> klutzie
>>> Hope that helped,
>>> CL
Re: Howto terminate external editor launched with IEditorLauncher or force GC? [message #282558 is a reply to message #282536] Wed, 16 March 2005 08:53 Go to previous messageGo to next message
Because in Eclipse the resources are still being held onto. You have to
determine what object is still holding a reference to your editor within
eclipse.
The GC will only release memory from objects that are not presently
being used. some class in eclipse is still using your object, and you
should be able ot use JProfiler to figure out which.
CL
> klutzie
>> to help you. Im not familiar with JProfiler, but if it can, you
>> should find what is holding on to references to your Frame. Somehow
>> after the Frame is closed, the reference is not being released.
>>> for the first few instances, but after that, it started to become
>>> slower and slower, and in the end, it hangs. I realized there are
>>> continuous increase of the memory usage for my eclipse (from the
>>> Windows Task Manager), everytime when i load my editor. Somehow the
>>> resources cannot be released, even when the memory usage reaches the
>>> peak, thus causing my eclipse and editor to hang. Things resume
>>> editor (running outside eclipse), and everytime when I close a window
>>> in my editor (my editor may consist more than one window), I call
>>> System.gc(), and it works. In JProfiler, it shows that resources are
>>> actually released. However it doesn't seems to be working when i run
>>> eclipse. But i will definately try out the incremental garbage
>>> collection thingy.
>>> klutzie
>>>> klutzie wrote:
>>>>> Hi people~
>>>>> to launch an external editor. I'm implementing the
>>>>> using the same VM which eclipse is using, and of course, memory
>>>>> usage of this VM increased whenever i launch the editor. However
>>>>> when I close my editor, the memory usage remains the same (it
>>>>> doesn't drop).
>>>>> all the instances that i've created and called a garbage
>>>>> collection, but it doesn't help. Calling System.exit(int) will
>>>>> definately wont help as the whole Eclipse will be terminated.
>>>> only request it. Nothing is guaranteed to be done though. If you
>>>> really want to see the garbage collector run to find out if one of
>>>> your classes is being collected or not, you can add an array of say,
>>>>> memory usage?
>>>>> editor in a standalone version (not in eclipse) and profiled the
>>>>> execution, the garbage collection works, and it actually free up
>>>>> the memory, but not in the eclipse environment. Any idea?
>>>>> Thanks
>>>>> klutzie
>>>> on the incremental garbage collector.
>>>> Hope that helped,
>>>> CL
Re: Howto terminate external editor launched with IEditorLauncher or force GC? [message #282627 is a reply to message #282558] Wed, 16 March 2005 20:38 Go to previous messageGo to next message
Is there a way to profile the activities in Eclipse? i mean the whole
eclipse runtime? because with JProfiler, I believe i can only profile
class or .jar file, but not .exe file
klutzie
> eclipse.
> CL
>> klutzie
>>>> collection thingy.
>>>> klutzie
>>>>> klutzie wrote:
>>>>>> Hi people~
>>>>>> doesn't drop).
>>>>>> memory usage?
>>>>>> Thanks
>>>>>> klutzie
>>>>> Hope that helped,
>>>>> CL
Re: Howto terminate external editor launched with IEditorLauncher or force GC? [message #282632 is a reply to message #282627] Wed, 16 March 2005 22:55 Go to previous messageGo to next message
im sure it can. perhaps ask some jprofiler people. eclipse is pretty
popular so they will probably have a quick answer for you.
CL
> klutzie
>> to determine what object is still holding a reference to your editor
>> within eclipse.
>> CL
>> klutzie wrote:
Re: Howto terminate external editor launched with IEditorLauncher or force GC? [message #283120 is a reply to message #282632] Sat, 26 March 2005 16:43 Go to previous message
Originally posted by: varavamu.yahoo.com
you might be able to use sleak (from the eclipse sqt team). you can find out
more abt it here: http://www.eclipse.org/articles/swt-design-2/sleak.htm
HTH,
Vijay
> CL
>> klutzie
>>> within eclipse.
>>> you should be able ot use JProfiler to figure out which.
>>> CL
>>> klutzie wrote:
Previous Topic:Lost the ability to export/import Preferences
Next Topic:Linkage error when using 3.1M5a
Current Time: Thu Jul 24 21:09:47 EDT 2025
Powered by FUDForum. Page generated in 0.26493 seconds
