Home » Archived » XML Schema Definition (XSD) » Weird namespaces when moving objects between XSD schemas
Weird namespaces when moving objects between XSD schemas [message #28174] Thu, 04 September 2003 12:12 Go to next message
I am merging the contents of schemas by iterating over the elements of the
referred schemas of a certain base schema and adding all the contents of
them into the base schema. Here is a snippet of my code:
XSDSchema primaryXSDSchema = getEclipseXSDSchema();
for (Iterator iterator = fReferencedXsdSchemas.iterator();
iterator.hasNext();) {
XSDSchema referredSchema = (XSDSchema) iterator.next();
primaryXSDSchema.getContents().addAll(referredSchema.getCont ents());
This code works nicely. However, sometimes when I run this code, I get a
weird phenomenom. The root of the schema becomes:
<xsd:schema targetNamespace="http://ACORD.org/Standards/Life/2"
xmlns:Q1="http://www.w3.org/2001/XMLSchema"
xmlns="http://ACORD.org/Standards/Life/2"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
elementFormDefault="unqualified" attributeFormDefault="unqualified">
I have no idea where this Q1 comes from, but lots of the xsd elements from
the XMLSchema schema are prefixed with Q1 instead of xsd. Sometimes the
whole schema is Q1. e.g. <Q1:schema>.....
Also, when validating this schema, all elements that are of type
<Q1:string>, <Q1:integer> etc... cannot be resolved by Eclipse. There
seems to have been some duplication of XMLSchema namespaces when objects
were moved over.
Any idea what I may be doing wrong?
Re: Weird namespaces when moving objects between XSD schemas [message #28216 is a reply to message #28174] Thu, 04 September 2003 14:32 Go to previous messageGo to next message
--------------3A07646349EF55C6534EDB66
Content-Type: text/plain; charset=us-ascii
Hayden,
In XSDConcreteComponentImpl there is this method:
protected String niceCreateNamespaceAttribute(String namespace)
XSDSchema xsdSchema = getSchema();
if (namespace == null)
namespace = "";
if (xsdSchema != null && xsdSchema.getElement() != null)
Element schemaElement = xsdSchema.getElement();
if (XSDConstants.isSchemaForSchemaNamespace(namespace))
if (!schemaElement.hasAttributeNS(XSDConstants.XMLNS_URI_2000, "xsd"))
schemaElement.setAttributeNS(XSDConstants.XMLNS_URI_2000,
"xmlns:xsd", namespace);
return "xsd";
String qualifier = "Q";
int count = 1;
while (schemaElement.hasAttributeNS(XSDConstants.XMLNS_URI_2000,
"xmlns:" + qualifier + count))
++count;
schemaElement.setAttributeNS(XSDConstants.XMLNS_URI_2000, "xmlns:" +
qualifier + count, namespace);
return qualifier + count;
else
return null;
It's called from one place that looks like this:
String qualifier = XSDConstants.lookupQualifier(element, namespace);
if (qualifier == null)
qualifier = niceCreateNamespaceAttribute(namespace);
So it should create a new xmlns declaration only if there isn't already one.
I'm not sure how the duplication can happen given this algorithm...
> were moved over.
> Thanks
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Hayden,
<p>In XSDConcreteComponentImpl there is this method:
<p><tt>&nbsp; protected String niceCreateNamespaceAttribute(String namespace)</tt>
<br><tt>&nbsp; {</tt>
<br><tt>&nbsp;&nbsp;&nbsp; XSDSchema xsdSchema = getSchema();</tt>
<br><tt>&nbsp;&nbsp;&nbsp; if (namespace == null)</tt>
<br><tt>&nbsp;&nbsp;&nbsp; {</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; namespace = "";</tt>
<br><tt>&nbsp;&nbsp;&nbsp; }</tt>
<br><tt>&nbsp;&nbsp;&nbsp; if (xsdSchema != null &amp;&amp; xsdSchema.getElement()
!= null)</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Element schemaElement = xsdSchema.getElement();</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (XSDConstants.isSchemaForSchemaNamespace(namespace))</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (!schemaElement.hasAttributeNS(XSDConstants.XMLNS_URI_2000,
"xsd"))</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; schemaElement.setAttributeNS(XSDConstants.XMLNS_URI_2000,
"xmlns:xsd", namespace);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return "xsd";</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }</tt><tt></tt>
<p><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; String qualifier = "Q";</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; int count = 1;</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; while (schemaElement.hasAttributeNS(XSDConstants.XMLNS_URI_2000,
"xmlns:" + qualifier + count))</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; ++count;</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; schemaElement.setAttributeNS(XSDConstants.XMLNS_URI_2000,
"xmlns:" + qualifier + count, namespace);</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return qualifier + count;</tt>
<br><tt>&nbsp;&nbsp;&nbsp; else</tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return null;</tt>
<br><tt>&nbsp; }</tt>
<p>It's called from one place that looks like this:
<p> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; String qualifier = XSDConstants.lookupQualifier(element,
namespace);
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (qualifier == null)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; qualifier =
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }
<p>So it should create a new xmlns declaration only if there isn't already
one.
<p>I'm not sure how the duplication can happen given this algorithm...
<br>&nbsp;
<p>Hayden Marchant wrote:
<blockquote TYPE=CITE>I am merging the contents of schemas by iterating
<br>referred schemas of a certain base schema and adding all the contents
of
<br>them into the base schema. Here is a snippet of my code:
<p> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; XSDSchema primaryXSDSchema
<p> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; for (Iterator iterator =
<br>iterator.hasNext();) {
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
<p> primaryXSDSchema.getContents().addAll(referredSchema.getCont ents());
<p>This code works nicely. However, sometimes when I run this code, I get
a
<br>weird phenomenom. The root of the schema becomes:
<p>&lt;?xml version="1.0" encoding="UTF-8"?>
<br>&lt;xsd:schema targetNamespace="<a href="http://ACORD.org/Standards/Life/2">http://ACORD.org/Standards/Life/2</a>"
<br>xmlns:Q1="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br>xmlns="<a href="http://ACORD.org/Standards/Life/2">http://ACORD.org/Standards/Life/2</a>"
<br>xmlns:xsd="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br>elementFormDefault="unqualified" attributeFormDefault="unqualified">
<p>I have no idea where this Q1 comes from, but lots of the xsd elements
from
<br>the XMLSchema schema are prefixed with Q1 instead of xsd. Sometimes
the
<br>whole schema is Q1. e.g. &lt;Q1:schema>.....
<p>Also, when validating this schema, all elements that are of type
<br>&lt;Q1:string>, &lt;Q1:integer> etc... cannot be resolved by Eclipse.
There
<br>seems to have been some duplication of XMLSchema namespaces when objects
<br>were moved over.
<p>Any idea what I may be doing wrong?
<p>Thanks</blockquote>
</html>
--------------3A07646349EF55C6534EDB66--
Re: Weird namespaces when moving objects between XSD schemas [message #28293 is a reply to message #28216] Sat, 06 September 2003 15:36 Go to previous messageGo to next message
Ed,
Shouldn't the code read:
"xsd"))
return "xsd";
as opposed to :
"xsd"))
return "xsd";
i.e. when I debugged the code, I got to this method call. My schema
element does have the relevant attribute set to 'xsd'. So the code does
not need to call setAttributeNS and should return nicely. However, it
carries on a resets a duplicate namespace for XSD.
In my opinion, it's a simple bug - I made a local change in my copy of the
eclipse src and it sort of solved it. Am I talking sense?
I am still not clear of the case that the code is ever supposed to get to
make a "Q" XSD namespace. Also isn't it a bit presumptious that the XSD
namespace is 'xsd'? It could just as easily be 'xs', no? Mightn't it be
more correct to check ALL of the attributes, and if there exists an
attribute that has a valid value for
XSDConstants.isSchemaForSchemaNamespace() then that's the one and the name
of that attribute should be returned as the namespace for that method.
Ed Merks wrote:
> Hayden,
> namespace = "";
"xsd"))
> return "xsd";
> int count = 1;
> ++count;
> else
> return null;
> > <?xml version="1.0" encoding="UTF-8"?>
> > were moved over.
> > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #28331 is a reply to message #28293] Sun, 07 September 2003 09:46 Go to previous messageGo to next message
Hayden,
As I indicated in my previous note, the method is called from a guard:
> Ed,
> "xsd"))
> return "xsd";
> as opposed to :
> "xsd"))
> return "xsd";
> Ed Merks wrote:
> > Hayden,
> > namespace = "";
> "xsd"))
> > return "xsd";
> > int count = 1;
> > ++count;
> > else
> > return null;
> > > were moved over.
> > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #28368 is a reply to message #28293] Sun, 07 September 2003 10:03 Go to previous messageGo to next message
--------------D85D31BE0E6A8FCC58FEE674
Hayden,
Sorry for the earlier miss send.
protected void niceSetAttributeURIValue(Element element, String attribute,
String uriList)
So if there is an xmlns declaration already for the namespace, it should be used.
I.e., all the attributes are checked as you suggest.
I have a strong suspicion that the DOM elements you are manipulating were created
without namespace awareness. Could that be the case?
The xsd prefix is not so presumptuous considering the Primer example:
http://www.w3.org/TR/2001/REC-xmlschema-0-20010502/primer.ht ml#POSchema
This special case is only there to avoid the use "Q" for the special schema
namespace itself.
The change you show doesn't look right. The code is written to avoid using "xsd"
if it's being used for something else already. A Q prefix will be introduced in
the case of adding a declaration with a namespace not previously used or in the
case that "xsd" is used for something else...
The important question here is why is the guarded failing to find an existing
xmlns declaration? I suspect it has to do with namespace awareness in how the DOM
was constructed...
> Ed,
> "xsd"))
> return "xsd";
> as opposed to :
> "xsd"))
> return "xsd";
> Ed Merks wrote:
> > Hayden,
> > namespace = "";
> "xsd"))
> > return "xsd";
> > int count = 1;
> > ++count;
> > else
> > return null;
> > > were moved over.
> > > Thanks
<html>
Hayden,
<p>Sorry for the earlier miss send.
<p>As I indicated in my previous note, the method is called from a guard:
<p>&nbsp; protected void niceSetAttributeURIValue(Element element, String
attribute, String uriList)
<br>&nbsp; {
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ....
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; <font color="#CC0000">String
qualifier = XSDConstants.lookupQualifier(element, namespace);</font>
<p>So if there is an xmlns declaration already for the namespace, it should
be used.&nbsp; I.e., all the attributes are checked as you suggest.
<p>I have a strong suspicion that the DOM elements you are manipulating
were created without namespace awareness.&nbsp; Could that be the case?
<p>The xsd prefix is not so presumptuous considering the Primer example:
<blockquote><a href=" http://www.w3.org/TR/2001/REC-xmlschema-0-20010502/primer.ht ml#POSchema"> http://www.w3.org/TR/2001/REC-xmlschema-0-20010502/primer.ht ml#POSchema</a></blockquote>
namespace itself.
<p>The change you show doesn't look right.&nbsp; The code is written to
avoid using "xsd" if it's being used for something else already.&nbsp;
A Q prefix will be introduced in the case of adding a declaration with
a namespace not previously used or in the case that "xsd" is used for something
else...
<p>The important question here is why is the guarded failing to find an
existing xmlns declaration?&nbsp; I suspect it has to do with namespace
awareness in how the DOM was constructed...
<br>&nbsp;
<blockquote TYPE=CITE>Ed,
<p>Shouldn't the code read:
<p> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (!schemaElement.hasAttributeNS(XSDConstants.XMLNS_URI_2000,
<br>"xsd"))
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; schemaElement.setAttributeNS(XSDConstants.XMLNS_URI_2000,
<br>"xmlns:xsd", namespace);
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; return "xsd";
<p>as opposed to :
<br>"xsd"))
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return "xsd";
<p>i.e. when I debugged the code, I got to this method call. My schema
<br>element does have the relevant attribute set to 'xsd'. So the code
does
<br>not need to call setAttributeNS and should return nicely. However,
it
<br>carries on a resets a duplicate namespace for XSD.
<p>In my opinion, it's a simple bug - I made a local change in my copy
of the
<br>eclipse src and it sort of solved it. Am I talking sense?
<p>I am still not clear of the case that the code is ever supposed to get
to
<br>make a "Q" XSD namespace. Also isn't it a bit presumptious that the
XSD
<br>namespace is 'xsd'? It could just as easily be 'xs', no? Mightn't it
be
<br>more correct to check ALL of the attributes, and if there exists an
<br>attribute that has a valid value for
<br>XSDConstants.isSchemaForSchemaNamespace() then that's the one and the
name
<br>of that attribute should be returned as the namespace for that method.
<p>Ed Merks wrote:
<p>> Hayden,
<p>> In XSDConcreteComponentImpl there is this method:
<p>>&nbsp;&nbsp; protected String niceCreateNamespaceAttribute(String namespace)
<br>>&nbsp;&nbsp; {
<br>>&nbsp;&nbsp;&nbsp;&nbsp; XSDSchema xsdSchema = getSchema();
<br>>&nbsp;&nbsp;&nbsp;&nbsp; if (namespace == null)
<br>>&nbsp;&nbsp;&nbsp;&nbsp; {
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; namespace = "";
<br>>&nbsp;&nbsp;&nbsp;&nbsp; }
<br>>&nbsp;&nbsp;&nbsp;&nbsp; if (xsdSchema != null &amp;&amp; xsdSchema.getElement()
!= null)
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Element schemaElement = xsdSchema.getElement();
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (XSDConstants.isSchemaForSchemaNamespace(namespace))
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; if (!schemaElement.hasAttributeNS(XSDConstants.XMLNS_URI_2000,
<br>"xsd"))
<p>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; {
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; schemaElement.setAttributeNS(XSDConstants.XMLNS_URI_2000,
<br>> "xmlns:xsd", namespace);
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; return
"xsd";
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; }
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }
<p>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; String qualifier = "Q";
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; int count = 1;
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; while (schemaElement.hasAttributeNS(XSDConstants.XMLNS_URI_2000,
<br>> "xmlns:" + qualifier + count))
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; ++count;
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; schemaElement.setAttributeNS(XSDConstants.XMLNS_URI_2000,
"xmlns:" +
<br>> qualifier + count, namespace);
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return qualifier + count;
<br>>&nbsp;&nbsp;&nbsp;&nbsp; else
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; return null;
<br>>&nbsp;&nbsp; }
<p>> It's called from one place that looks like this:
<p>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; String qualifier =
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; if (qualifier ==
null)
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; {
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; qualifier
<p>> So it should create a new xmlns declaration only if there isn't already
one.
<p>> I'm not sure how the duplication can happen given this algorithm...
<p>> Hayden Marchant wrote:
<p>> > I am merging the contents of schemas by iterating over the elements
of the
<br>> > referred schemas of a certain base schema and adding all the contents
of
<br>> > them into the base schema. Here is a snippet of my code:
<br>> >
<br>> > &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; XSDSchema primaryXSDSchema
<br>> >
<br>> > &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; for (Iterator iterator
<br>> > iterator.hasNext();) {
<br>> > &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
<br>> >
<br>> > primaryXSDSchema.getContents().addAll(referredSchema.getCont ents());
<br>> > &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; }
<br>> >
<br>> > This code works nicely. However, sometimes when I run this code,
I get a
<br>> > weird phenomenom. The root of the schema becomes:
<br>> >
<br>> > &lt;?xml version="1.0" encoding="UTF-8"?>
<br>> > &lt;xsd:schema targetNamespace="<a href="http://ACORD.org/Standards/Life/2">http://ACORD.org/Standards/Life/2</a>"
<br>> > xmlns:Q1="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br>> > xmlns="<a href="http://ACORD.org/Standards/Life/2">http://ACORD.org/Standards/Life/2</a>"
<br>> > xmlns:xsd="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br>> > elementFormDefault="unqualified" attributeFormDefault="unqualified">
<br>> >
<br>> > I have no idea where this Q1 comes from, but lots of the xsd elements
from
<br>> > the XMLSchema schema are prefixed with Q1 instead of xsd. Sometimes
the
<br>> > whole schema is Q1. e.g. &lt;Q1:schema>.....
<br>> >
<br>> > Also, when validating this schema, all elements that are of type
<br>> > &lt;Q1:string>, &lt;Q1:integer> etc... cannot be resolved by Eclipse.
There
<br>> > seems to have been some duplication of XMLSchema namespaces when
objects
<br>> > were moved over.
<br>> >
<br>> > Any idea what I may be doing wrong?
<br>> >
<br>> > Thanks</blockquote>
</html>
--------------D85D31BE0E6A8FCC58FEE674--
Re: Weird namespaces when moving objects between XSD schemas [message #30389 is a reply to message #28368] Mon, 29 September 2003 13:18 Go to previous messageGo to next message
I'm still getting another related problem - in fact, I have cornered it
down quite a specific scenario:
1. Load a simple XSDSchema, for example:
<xsd:complexType name="INQUIRY_LEVEL_CODES">
<xsd:simpleContent>
<xsd:extension base="xsd:string">
<xsd:attribute name="tc" use="required">
<xsd:simpleType>
<xsd:restriction base="xsd:nonNegativeInteger">
<xsd:enumeration value="1"/>
<xsd:enumeration value="2"/>
<xsd:enumeration value="3"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:attribute>
</xsd:extension>
</xsd:simpleContent>
</xsd:complexType>
<xsd:element name="VendorName">
<xsd:complexType>
<xsd:simpleContent>
<xsd:attribute name="VendorCode" type="xsd:string" use="required"/>
</xsd:extension>
</xsd:complexType>
</xsd:element>
</xsd:schema>
The schema is valid 100% and has no diagnostics.
2. Load an XSDSchema2 that has nested includes.
3. Remove elements from both this schemas and some of the includes (if I
only remove from this schema and NOT from includes, bug does not happen).
4. dump the pruned main XSDSchema2 to an OutputStream.
5. Repeat step 1 - this step the same schema has the following diagnostic:
Line 11: XSD: Type reference 'http://www.w3.org/2001/XMLSchema#string' is
unresolved.
Basically, Eclipse XSD seems to break after removing items from nested
schemas. I cna't isolate this bug to such an extent that I can send a
reproducable code but above is that basic scenario. Has anyone come across
something like this?
Ed Merks wrote:
> Hayden,
> String uriList)
used.
created
> namespace itself.
"xsd"
introduced in
the
the DOM
> was constructed...
> > Ed,
> > "xsd"))
> > return "xsd";
> > as opposed to :
> > "xsd"))
> > return "xsd";
> > Ed Merks wrote:
> > > Hayden,
> > > namespace = "";
> > "xsd"))
> > > return "xsd";
> > > int count = 1;
> > > ++count;
> > > else
> > > return null;
namespace);
one.
the
of
a
from
objects
> > > > were moved over.
> > > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #30461 is a reply to message #30389] Mon, 29 September 2003 14:30 Go to previous messageGo to next message
Hayden,
There is a significant hole in the editing support that editing changes don't
propagate across schemas. So if you delete something from an included schema, the
including schema won't know about that. You should restrict editing to the "root"
schema, i.e., the one that includes and imports the others; or you need to rebuild
model for the schemas affected by the change. There should probably be a method on
XSDSchema that forces such a recomputation to happen...
> <xsd:simpleContent>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:attribute>
> </xsd:extension>
> </xsd:complexType>
> <xsd:complexType>
> <xsd:simpleContent>
> </xsd:extension>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> unresolved.
> Thanks
> Ed Merks wrote:
> > Hayden,
> > String uriList)
> used.
> created
> > namespace itself.
> "xsd"
> introduced in
> the
> the DOM
> > was constructed...
> > > Ed,
> > > "xsd"))
> > > return "xsd";
> > > as opposed to :
> > > "xsd"))
> > > return "xsd";
> > > Ed Merks wrote:
> > > > Hayden,
> > > > namespace = "";
> > > "xsd"))
> > > > return "xsd";
> > > > int count = 1;
> > > > ++count;
> > > > else
> > > > return null;
> namespace);
> one.
> the
> of
> a
> from
> objects
> > > > > were moved over.
> > > > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #30635 is a reply to message #30461] Tue, 30 September 2003 00:42 Go to previous messageGo to next message
The hold in editing support is not a problem for me - I delete lots of
items from included schemas, and then I move all of the elements from the
included schemas into the main including schema and then I save the new
schema. So I don't need to tell the including schema that an included
schema changed since ?I then dump everything all into the including schema
after that anyway.
The idea is that there's a very large XSD standard which is spread over a
few documents. The XSD Standard is too big to be validated against, so
several legal subsets of this standard need to be generated acording to
certain criteria - this is what I'm doing. I chop off the irrelevant parts
of the schema whilst making sure I don't leave any bad bits hanging. Then
I merge all the smaller schemas into 1 large schema. There is not a
problem with this - it works great. The problem is, is that after doing
this action, when I open another extremely trivial schema that Eclipse was
very happy with before, I now get errors. In a different JVM the small
schema is fine, it's just that after doing the removing of elements and
merging that the Eclipse parser seems to 'break'.
Any ideas how I can proceed, or maybe that's enough suspicions to look
into a certain part. Again, it looks like the xsd namespace -
http://www.w3.org/2001/XMLSchema seems to have been duplicated or lost or
something, as can be seen from the diagnostic that I got below with the
perfectly legal xsd.
Ed Merks wrote:
> Hayden,
schema, the
"root"
rebuild
method on
> > <xsd:simpleContent>
> > <xsd:simpleType>
> > </xsd:restriction>
> > </xsd:simpleType>
> > </xsd:attribute>
> > </xsd:extension>
> > </xsd:complexType>
> > <xsd:complexType>
> > <xsd:simpleContent>
> > </xsd:extension>
> > </xsd:complexType>
> > </xsd:element>
> > </xsd:schema>
> > unresolved.
> > Thanks
> > Ed Merks wrote:
> > > Hayden,
attribute,
> > > String uriList)
namespace);
be
> > used.
> > created
schema
> > > namespace itself.
using
> > "xsd"
> > introduced in
in
> > the
existing
how
> > the DOM
> > > was constructed...
> > > > Ed,
> > > > "xsd"))
> > > > return "xsd";
> > > > as opposed to :
> > > > "xsd"))
> > > > return "xsd";
the
to
name
> > > > Ed Merks wrote:
> > > > > Hayden,
> > > > > namespace = "";
> > > > > if
> > > > "xsd"))
> > > > > return "xsd";
> > > > > int count = 1;
> > > > > while
> > > > > ++count;
"xmlns:"
> > > > > else
> > > > > return null;
> > namespace);
already
> > one.
elements of
> > the
contents
> > of
get
> > a
elements
> > from
Sometimes the
There
> > objects
> > > > > > were moved over.
> > > > > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #30705 is a reply to message #30635] Tue, 30 September 2003 08:00 Go to previous messageGo to next message
Hayden,
It sounds like perhaps maybe the schema for schemas itself got edited
accidentally. It lives in global resource set with static lifetime. It's the
schema returned by XSDSchema.getSchemaForSchema. You could try adding an
org.eclipse.emf.ecore.util.EContentAdapter to it and putting a print statement in
the notifyChanged method to see if maybe some of your code is accidentally editing
it.
> after that anyway.
> Ed Merks wrote:
> > Hayden,
> schema, the
> "root"
> rebuild
> method on
> > > <xsd:simpleContent>
> > > <xsd:simpleType>
> > > </xsd:restriction>
> > > </xsd:simpleType>
> > > </xsd:attribute>
> > > </xsd:extension>
> > > </xsd:complexType>
> > > <xsd:complexType>
> > > <xsd:simpleContent>
> > > </xsd:extension>
> > > </xsd:complexType>
> > > </xsd:element>
> > > </xsd:schema>
> > > unresolved.
> > > Thanks
> > > Ed Merks wrote:
> > > > Hayden,
> attribute,
> > > > String uriList)
> namespace);
> be
> > > used.
> > > created
> schema
> > > > namespace itself.
> using
> > > "xsd"
> > > introduced in
> in
> > > the
> existing
> how
> > > the DOM
> > > > was constructed...
> > > > > Ed,
> > > > > "xsd"))
> > > > > return "xsd";
> > > > > as opposed to :
> > > > > "xsd"))
> > > > > return "xsd";
> the
> to
> name
> > > > > Ed Merks wrote:
> > > > > > Hayden,
> > > > > > namespace = "";
> > > > > > if
> > > > > "xsd"))
> > > > > > return "xsd";
> > > > > > int count = 1;
> > > > > > while
> > > > > > ++count;
> "xmlns:"
> > > > > > else
> > > > > > return null;
> > > namespace);
> already
> > > one.
> elements of
> > > the
> contents
> > > of
> get
> > > a
> elements
> > > from
> Sometimes the
> There
> > > objects
> > > > > > > were moved over.
> > > > > > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #30778 is a reply to message #30705] Tue, 30 September 2003 08:54 Go to previous message
Ed,
You pointed me in exactly the right direction - you were correct in your
analysis - I was removing some quite vital parts of the static schema.
That probably solves the Q1 namespace problem aswell.
Thanks so much for your help.
I'm glad it was a bug in my code and not in Eclipse :)
Ed Merks wrote:
> Hayden,
the
statement in
editing
> it.
> > after that anyway.
> > Thanks,
> > Ed Merks wrote:
> > > Hayden,
don't
> > schema, the
the
> > "root"
to
> > rebuild
> > method on
> > > > <xsd:simpleContent>
> > > > <xsd:simpleType>
> > > > </xsd:restriction>
> > > > </xsd:simpleType>
> > > > </xsd:attribute>
> > > > </xsd:extension>
> > > > </xsd:complexType>
> > > > <xsd:complexType>
> > > > <xsd:simpleContent>
use="required"/>
> > > > </xsd:extension>
> > > > </xsd:complexType>
> > > > </xsd:element>
> > > > </xsd:schema>
I
happen).
diagnostic:
is
> > > > unresolved.
across
> > > > Thanks
> > > > Ed Merks wrote:
> > > > > Hayden,
guard:
> > attribute,
> > > > > String uriList)
> > namespace);
should
> > be
> > > > used.
were
> > > > created
> > schema
> > > > > namespace itself.
> > using
> > > > "xsd"
> > > > introduced in
used or
> > in
> > > > the
> > existing
in
> > how
> > > > the DOM
> > > > > was constructed...
> > > > > > Ed,
> > > > > > if
> > > > > > "xsd"))
> > > > > > return "xsd";
> > > > > > as opposed to :
> > > > > > if
> > > > > > "xsd"))
> > > > > > return "xsd";
does
it
copy of
> > the
get
> > to
the XSD
it be
the
> > name
method.
> > > > > > Ed Merks wrote:
> > > > > > > Hayden,
> > > > > > > namespace = "";
> > > > > > > if
> > > > > > "xsd"))
> > > > > > > return "xsd";
> > > > > > > int count = 1;
> > > > > > > while
> > > > > > > ++count;
> > "xmlns:"
> > > > > > > else
> > > > > > > return null;
> > > > namespace);
> > already
> > > > one.
algorithm...
> > elements of
> > > > the
> > contents
> > > > of
iterator.next();
code, I
> > get
> > > > a
> > elements
> > > > from
> > Sometimes the
type
> > There
when
> > > > objects
> > > > > > > > were moved over.
> > > > > > > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #577260 is a reply to message #28174] Thu, 04 September 2003 14:32 Go to previous message
Hayden,
namespace = "";
return "xsd";
int count = 1;
++count;
else
return null;
> were moved over.
> Thanks
<html>
Hayden,
!= null)</tt>
"xsd"))</tt>
namespace);
one.
<br>&nbsp;
of
a
from
the
There
</html>
Re: Weird namespaces when moving objects between XSD schemas [message #577314 is a reply to message #28216] Sat, 06 September 2003 15:36 Go to previous message
Ed,
"xsd"))
return "xsd";
as opposed to :
"xsd"))
return "xsd";
Ed Merks wrote:
> Hayden,
> namespace = "";
"xsd"))
> return "xsd";
> int count = 1;
> ++count;
> else
> return null;
> > were moved over.
> > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #577341 is a reply to message #28293] Sun, 07 September 2003 09:46 Go to previous message
Hayden,
> Ed,
> "xsd"))
> return "xsd";
> as opposed to :
> "xsd"))
> return "xsd";
> Ed Merks wrote:
> > Hayden,
> > namespace = "";
> "xsd"))
> > return "xsd";
> > int count = 1;
> > ++count;
> > else
> > return null;
> > > were moved over.
> > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #577366 is a reply to message #28293] Sun, 07 September 2003 10:03 Go to previous message
Hayden,
String uriList)
namespace itself.
was constructed...
> Ed,
> "xsd"))
> return "xsd";
> as opposed to :
> "xsd"))
> return "xsd";
> Ed Merks wrote:
> > Hayden,
> > namespace = "";
> "xsd"))
> > return "xsd";
> > int count = 1;
> > ++count;
> > else
> > return null;
> > > were moved over.
> > > Thanks
<html>
Hayden,
<br>&nbsp; {
namespace itself.
else...
<br>&nbsp;
<br>"xsd"))
<p>as opposed to :
<br>"xsd"))
does
it
of the
to
XSD
be
name
<p>Ed Merks wrote:
<p>> Hayden,
<br>>&nbsp;&nbsp; {
!= null)
<br>"xsd"))
"xsd";
"xmlns:" +
<br>>&nbsp;&nbsp; }
null)
one.
of the
of
<br>> >
<br>> >
<br>> >
<br>> >
I get a
<br>> >
<br>> >
from
the
<br>> >
There
objects
<br>> >
<br>> >
</html>
Re: Weird namespaces when moving objects between XSD schemas [message #578566 is a reply to message #28368] Mon, 29 September 2003 13:18 Go to previous message
<xsd:simpleContent>
<xsd:simpleType>
</xsd:restriction>
</xsd:simpleType>
</xsd:attribute>
</xsd:extension>
</xsd:complexType>
<xsd:complexType>
<xsd:simpleContent>
</xsd:extension>
</xsd:complexType>
</xsd:element>
</xsd:schema>
unresolved.
Ed Merks wrote:
> Hayden,
> String uriList)
used.
created
> namespace itself.
"xsd"
introduced in
the
the DOM
> was constructed...
> > Ed,
> > "xsd"))
> > return "xsd";
> > as opposed to :
> > "xsd"))
> > return "xsd";
> > Ed Merks wrote:
> > > Hayden,
> > > namespace = "";
> > "xsd"))
> > > return "xsd";
> > > int count = 1;
> > > ++count;
> > > else
> > > return null;
namespace);
one.
the
of
a
from
objects
> > > > were moved over.
> > > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #578617 is a reply to message #30389] Mon, 29 September 2003 14:30 Go to previous message
Hayden,
> <xsd:simpleContent>
> <xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:attribute>
> </xsd:extension>
> </xsd:complexType>
> <xsd:complexType>
> <xsd:simpleContent>
> </xsd:extension>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> unresolved.
> Thanks
> Ed Merks wrote:
> > Hayden,
> > String uriList)
> used.
> created
> > namespace itself.
> "xsd"
> introduced in
> the
> the DOM
> > was constructed...
> > > Ed,
> > > "xsd"))
> > > return "xsd";
> > > as opposed to :
> > > "xsd"))
> > > return "xsd";
> > > Ed Merks wrote:
> > > > Hayden,
> > > > namespace = "";
> > > "xsd"))
> > > > return "xsd";
> > > > int count = 1;
> > > > ++count;
> > > > else
> > > > return null;
> namespace);
> one.
> the
> of
> a
> from
> objects
> > > > > were moved over.
> > > > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #578818 is a reply to message #30461] Tue, 30 September 2003 00:42 Go to previous message
after that anyway.
Ed Merks wrote:
> Hayden,
schema, the
"root"
rebuild
method on
> > <xsd:simpleContent>
> > <xsd:simpleType>
> > </xsd:restriction>
> > </xsd:simpleType>
> > </xsd:attribute>
> > </xsd:extension>
> > </xsd:complexType>
> > <xsd:complexType>
> > <xsd:simpleContent>
> > </xsd:extension>
> > </xsd:complexType>
> > </xsd:element>
> > </xsd:schema>
> > unresolved.
> > Thanks
> > Ed Merks wrote:
> > > Hayden,
attribute,
> > > String uriList)
namespace);
be
> > used.
> > created
schema
> > > namespace itself.
using
> > "xsd"
> > introduced in
in
> > the
existing
how
> > the DOM
> > > was constructed...
> > > > Ed,
> > > > "xsd"))
> > > > return "xsd";
> > > > as opposed to :
> > > > "xsd"))
> > > > return "xsd";
the
to
name
> > > > Ed Merks wrote:
> > > > > Hayden,
> > > > > namespace = "";
> > > > > if
> > > > "xsd"))
> > > > > return "xsd";
> > > > > int count = 1;
> > > > > while
> > > > > ++count;
"xmlns:"
> > > > > else
> > > > > return null;
> > namespace);
already
> > one.
elements of
> > the
contents
> > of
get
> > a
elements
> > from
Sometimes the
There
> > objects
> > > > > > were moved over.
> > > > > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #578885 is a reply to message #30635] Tue, 30 September 2003 08:00 Go to previous message
Hayden,
it.
> after that anyway.
> Ed Merks wrote:
> > Hayden,
> schema, the
> "root"
> rebuild
> method on
> > > <xsd:simpleContent>
> > > <xsd:simpleType>
> > > </xsd:restriction>
> > > </xsd:simpleType>
> > > </xsd:attribute>
> > > </xsd:extension>
> > > </xsd:complexType>
> > > <xsd:complexType>
> > > <xsd:simpleContent>
> > > </xsd:extension>
> > > </xsd:complexType>
> > > </xsd:element>
> > > </xsd:schema>
> > > unresolved.
> > > Thanks
> > > Ed Merks wrote:
> > > > Hayden,
> attribute,
> > > > String uriList)
> namespace);
> be
> > > used.
> > > created
> schema
> > > > namespace itself.
> using
> > > "xsd"
> > > introduced in
> in
> > > the
> existing
> how
> > > the DOM
> > > > was constructed...
> > > > > Ed,
> > > > > "xsd"))
> > > > > return "xsd";
> > > > > as opposed to :
> > > > > "xsd"))
> > > > > return "xsd";
> the
> to
> name
> > > > > Ed Merks wrote:
> > > > > > Hayden,
> > > > > > namespace = "";
> > > > > > if
> > > > > "xsd"))
> > > > > > return "xsd";
> > > > > > int count = 1;
> > > > > > while
> > > > > > ++count;
> "xmlns:"
> > > > > > else
> > > > > > return null;
> > > namespace);
> already
> > > one.
> elements of
> > > the
> contents
> > > of
> get
> > > a
> elements
> > > from
> Sometimes the
> There
> > > objects
> > > > > > > were moved over.
> > > > > > > Thanks
Re: Weird namespaces when moving objects between XSD schemas [message #578965 is a reply to message #30705] Tue, 30 September 2003 08:54 Go to previous message
Ed,
Ed Merks wrote:
> Hayden,
the
statement in
editing
> it.
> > after that anyway.
> > Thanks,
> > Ed Merks wrote:
> > > Hayden,
don't
> > schema, the
the
> > "root"
to
> > rebuild
> > method on
> > > > <xsd:simpleContent>
> > > > <xsd:simpleType>
> > > > </xsd:restriction>
> > > > </xsd:simpleType>
> > > > </xsd:attribute>
> > > > </xsd:extension>
> > > > </xsd:complexType>
> > > > <xsd:complexType>
> > > > <xsd:simpleContent>
use="required"/>
> > > > </xsd:extension>
> > > > </xsd:complexType>
> > > > </xsd:element>
> > > > </xsd:schema>
I
happen).
diagnostic:
is
> > > > unresolved.
across
> > > > Thanks
> > > > Ed Merks wrote:
> > > > > Hayden,
guard:
> > attribute,
> > > > > String uriList)
> > namespace);
should
> > be
> > > > used.
were
> > > > created
> > schema
> > > > > namespace itself.
> > using
> > > > "xsd"
> > > > introduced in
used or
> > in
> > > > the
> > existing
in
> > how
> > > > the DOM
> > > > > was constructed...
> > > > > > Ed,
> > > > > > if
> > > > > > "xsd"))
> > > > > > return "xsd";
> > > > > > as opposed to :
> > > > > > if
> > > > > > "xsd"))
> > > > > > return "xsd";
does
it
copy of
> > the
get
> > to
the XSD
it be
the
> > name
method.
> > > > > > Ed Merks wrote:
> > > > > > > Hayden,
> > > > > > > namespace = "";
> > > > > > > if
> > > > > > "xsd"))
> > > > > > > return "xsd";
> > > > > > > int count = 1;
> > > > > > > while
> > > > > > > ++count;
> > "xmlns:"
> > > > > > > else
> > > > > > > return null;
> > > > namespace);
> > already
> > > > one.
algorithm...
> > elements of
> > > > the
> > contents
> > > > of
iterator.next();
code, I
> > get
> > > > a
> > elements
> > > > from
> > Sometimes the
type
> > There
when
> > > > objects
> > > > > > > > were moved over.
> > > > > > > > Thanks
Previous Topic:Help with XSDAnnotation
Next Topic:Help with XSDAnnotation
Current Time: Thu Sep 25 06:46:22 EDT 2025
Powered by FUDForum. Page generated in 0.20473 seconds
