Home » Archived » EPF » Process tailoring by projects
Process tailoring by projects [message #28196] Thu, 01 February 2007 20:03 Go to next message
I'm building a tailorable organizational process definition in EPF, and am
looking for tips on how to implement tailoring by individual projects.
I'm currently thinking that projects will need to create a plug-in that
references the standard process, and create Contributes, Extends, Replaces
method elements where needed, then either add a Configuration view for the
project or publish to a separate Web site.
Anyone have thoughts on this?
Rob Robason
Software Process Manager
Wind River Systems
Re: Process tailoring by projects [message #28388 is a reply to message #28196] Fri, 02 February 2007 08:19 Go to previous message
hi Rob,
we start process modeling processes in our organization on two levels:
1. one Method Plugin -
company processes (as finance, pr, hr and so on) with generally
defined life-cycle model (lcm)
separated in 3 content packages (strategy, support, lcm)
2. project tailored lcm (each one Method Plugin) with connection to first
level
this mean that Method Plugins from second level has a connection to 1st
level
and use variability connections to Method Element from there.
question is, if one Method Plugin for 1st level is a good idea,
but for now it looks ok and as a simplest solution.
use one method configuration per project sounds good.
of course this really depends on a way how you model
(team, responsibilities, qa in company) ....
all the best,
jan
ps: question is how to model/connect knowledge base elements. :-)
On Fri, 02 Feb 2007 02:03:57 +0100, Rob Robason
> am
> Replaces
> the
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Process tailoring by projects [message #575771 is a reply to message #28196] Fri, 02 February 2007 08:19 Go to previous message
hi Rob,
level
level
all the best,
jan
> am
> Replaces
> the
Previous Topic:inline insertion
Next Topic:compiling epf composer plugin
Current Time: Wed Jul 23 07:24:51 EDT 2025
Powered by FUDForum. Page generated in 0.04889 seconds
