change sets and create patch problem [message #27080] |
Wed, 30 July 2008 18:49  |
Originally posted by: noah.roberts.eng-software.com
With subclipse I can right click, chose "Create patch..." and put it on
the clipboard. Then I can attach it to a mylyn task in bugzilla.
With subversive this menu item does not appear. When I first start
eclipse I see a Local->Create Patch... menu item. It makes a patch on
the filesystem. Then I never see this menu item again nor the "Local"
tree item where it resides. I therefore have no Branch menu item either.
I have hunted around in google, I'm about the only person that shows in
there mentioning this problem...I posted to "newcomer".
The menu items appear just fine in the Team menu off the project. I
want to integrate this with mylyn and have a sort of code review thing
going on. Developer attaches patch, another looks it over and labels
the bug fix as reviewed. To make sure changes are related to the task
it would be benificial to have the change-set menu working as well.
The documentation says I should see it...I don't. I ran into a few
clues I tried...I upgraded svn, used the 1.2.0 version of subversive,
and installed the JavaHL thingy....1.5 Behavior hasn't changed.
Ideas?
FUDForum. Page generated in 0.18106 seconds
