PersistenceException when importing devices [message #27949] |
Sun, 15 March 2009 19:16  |
I installed from scratch ganimede and MTJ 0.9.1.
It doesn't work!!!
I was not able to import WTK 2.5.2 devices
when I tried to import devices from WTK 2.5.2 it seems that the import is
ok, but when I back to the "device management" dialog no devices is
present and I see this exception:
org.eclipse.mtj.core.persistence.PersistenceException:
InstantiationException:
org.eclipse.mtj.toolkit.uei.internal.UEIDeviceInternal
If I try to import Microemulator devices it works, but with WTK 2.5.2.
I was not able to use MTJ 0.9.1!!!
I had to back to EclipseME 1.7.9!!!!
Let me know...
Ugo Chirico
http://www.cryptware.it
http://www.ugosweb.com
Re: PersistenceException when importing devices [message #28108 is a reply to message #28069] |
Fri, 20 March 2009 14:56  |
hi ugo,
we are working on some migration classes to migrate a workspace from
eclipseme to mtj. probably thats whay it worked. but this code is not
stable so it is still better to use 0.9.1
the better way to use 0.9.1 is:
- use a clean workspace
- import the sdks there
- import the eclipseme projects to this new workspace
(file->import>javame->eclipseme)
after that you will have a workspace with mtj project and the sdks you
want. we also received some reports mentioned that there were some WTK
installations without the bin/emulator.exe file and with a emulatorc.exe
(we dont' know why that happened). so please double check that also
if you still have problem please let us know. i just opened a bug to
evaluate the conversion issue that you raised
https://bugs.eclipse.org/bugs/show_bug.cgi?id=269564
feel free to follow up the issue there
thanks,
gep
Ugo Chirico wrote:
> Thanks for your reply.
> Unfortunately I cannot find the exception in the log file.
> I Installed MTJ 0.9.1 on a fresh Ganimede on Windows XP SP3 and I used
> eclipseme 1.6.x workspace.
> Now I solved installing the nightly build N20090310. now it works: I can
> import devices.
> With that nightly build, unfortunately I have another problem.
> I tried to convert an eclipseme 1.6.x project. I select the device for
> conversion but after the conversion dialog appears it hangs and I have to
> kill the project by task manager.
> I see in the log several exceptions:
> !ENTRY org.eclipse.ui 4 0 2009-03-20 12:33:18.771
> !MESSAGE Unhandled event loop exception
> !STACK 0
> at
> org.eclipse.mtj.internal.core.project.midp.MidletSuiteProjec t. <init>(Unknown
> Source)
> at
org.eclipse.mtj.internal.core.project.midp.MidletSuiteFactor y.getMidletSuiteProject(Unknown
> Source)
> at
org.eclipse.mtj.internal.core.project.midp.MidletSuiteFactor y$MidletSuiteCreationRunnable.run(Unknown
> Source)
> at
org.eclipse.mtj.internal.core.project.midp.MTJProjectConvert er.convertJavaProject(Unknown
> Source)
> at
org.eclipse.mtj.internal.ui.actions.ConvertToMidletProjectAc tion$1.run(Unknown
> Source)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
> at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1782)
> at
org.eclipse.mtj.internal.ui.actions.ConvertToMidletProjectAc tion.convertSelectedProjects(Unknown
> Source)
> at
> org.eclipse.mtj.internal.ui.actions.ConvertToMidletProjectAc tion.run(Unknown
> Source)
> at
> org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
> at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
> at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
> at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> !SESSION 2009-03-20 12:34:00.052
> eclipse.buildId=M20090211-1700
> java.version=1.5.0_09
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
> Command-line arguments: -os win32 -ws win32 -arch x86
> !ENTRY org.eclipse.core.resources 2 10035 2009-03-20 12:34:07.255
> !MESSAGE The workspace exited with unsaved changes in the previous
> session; refreshing workspace to recover changes.
> !ENTRY org.eclipse.ui.workbench.texteditor 4 0 2009-03-20 12:34:17.615
> !MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.JSPJa vaHyperlinkDetector'
> extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the
> 'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
> will be ignored because it contains invalid attributes.
> !MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.event .JSPJavaHyperlinkDetector'
> !ENTRY org.eclipse.jst.jsf.core 4 0 2009-03-20 12:34:24.927
> !MESSAGE Error acquiring editor input
> !STACK 1
> org.eclipse.ui.PartInitException: No input factory ID found for editor
> id=eclipseme.ui.editor.JadEditor name=secureotp.jad
> at
org.eclipse.ui.internal.EditorReference.getRestoredInput(Edi torReference.java:349)
> at
org.eclipse.ui.internal.EditorReference.getEditorInput(Edito rReference.java:328)
> at
org.eclipse.jst.jsf.designtime.internal.jsp.StartupHandler$J SPEditorListener.getIFile(StartupHandler.java:199)
> at
org.eclipse.jst.jsf.designtime.internal.jsp.StartupHandler$J SPEditorListener.isValidJSPEditor(StartupHandler.java:154)
> at
org.eclipse.jst.jsf.designtime.internal.jsp.StartupHandler$1 .run(StartupHandler.java:64)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
> at
> at
> at
> at
> at
> at
> at
> at
> !SUBENTRY 1 org.eclipse.ui 4 0 2009-03-20 12:34:25.099
> !MESSAGE No input factory ID found for editor
Re: PersistenceException when importing devices [message #571958 is a reply to message #27949] |
Tue, 17 March 2009 23:35  |
hi,
can you attach the exception here? you can probably see it on the eclipse
log (view error log on the about dialog). we had issues in the device
importing because of the javadoc automatic discovery that was introduced
on mtj, but it was on version 0.9 . version 0.9.1 already have that fix
and we didn't heard of this issue before.
besides that, can you inform which OS you used? other question, are you
using a fresh workspace or reusing an eclipsene ou mtj 0.9 workspace?
thanks
gep
Ugo Chirico wrote:
> It doesn't work!!!
> Let me know...
> Ugo Chirico
Re: PersistenceException when importing devices [message #572002 is a reply to message #27989] |
Fri, 20 March 2009 07:37  |
import devices.
!STACK 0
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
!MESSAGE The
!MESSAGE The
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: PersistenceException when importing devices [message #572034 is a reply to message #28069] |
hi ugo,
thanks,
gep
> import devices.
> !STACK 0
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE The
> !MESSAGE The
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.07650 seconds
