Home » Eclipse Projects » Eclipse Platform » How can I set the Caret in a text editor.
How can I set the Caret in a text editor. [message #280101] Fri, 28 January 2005 15:30 Go to next message
When the popup menu is displayed I would like to set the
caret where the mouse is. I.e. clicking on the right button
should do the same as the left button dose.
I have implemented following and I don't know what the
simplest solution is to be able to set the caret/cursor
in run....
public class Action implements IObjectActionDelegate, IEditorActionDelegate {
public void run(IAction action) {
Shell shell = new Shell();
...... <- need help
Re: How can I set the Caret in a text editor. [message #280144 is a reply to message #280101] Mon, 31 January 2005 02:04 Go to previous message
See ITextEditor.getSelectionProvider to set the selection / caret on a
text editor.
If you don't have the active editor already, have a look at
IWorkbenchPage.getActiveEditor.
Get the workbench page from the workbench[window] you get from the
AbstractUIPlugin.getWorkbench.
HTH
-tom
> in run....
> ...... <- need help
Previous Topic:Renamed a resource, setPartName changes title bar but not folder tab
Next Topic:Highlight line in TextEditor
Current Time: Wed Nov 05 16:51:16 EST 2025
Powered by FUDForum. Page generated in 0.03513 seconds
