Re: extending my own extension point [message #279900 is a reply to message #279894] |
Tue, 25 January 2005 10:11  |
Originally posted by: kim_horne.ca.ibm.com
Kevin wrote:
I've replied to your question in the newcomer group.
> Hello,
> I have used the following references to learn how to create extension
> points. Faq#85 from the online version of eclipsefaq.org
> http://docs.codehaus.org/display/UDIG/Creating+and+Using+Ext ension+Points
> http://help.eclipse.org/help21/index.jsp?topic=/org.eclipse. pde.doc.user/guide/pde_schema_editor.htm
> I created an extension point in the plugin I am developing. Then I go to
> Run run-time workbench.
> In the run-time workbench I create a New Plugin Project. However when I
> go to plugin.xml -> extensions page on the wizzard I cannot find the
> extension point I previously created.
> Also in the run-time workbench if I go to Help->About->Plugin Details, I
> can see that my plugin (that I declared the extension in) is loaded.
> Is there something else I must do to see the extension point I made?
> Maybe somebody has a suggestion here, as there was no response from the
> newcomer group.
> Any help is appreciated. Thanks,
> Kevin
FUDForum. Page generated in 0.07275 seconds
