Combo / Table header and Forms "flat"-look [message #279371] |
Mon, 17 January 2005 10:46  |
Originally posted by: opendev.gmail.com
I'd like to inquiry whether the "flat" look in Eclipse Forms is
already supported for the combo widget and the header part of a table
(I'm using 3.1M4 on win32).
I was unable to change the regular laf of both these widgets into one
more appropriate for a forms environment. Are there additional steps
beyond
Combo combo =3D new Combo(composite, SWT.NONE);
toolkit.adapt(combo, true, true);
combo.add("foo");
combo.add("bar");
combo.select(0);
I should consider? Thanks in advance,
j.
Re: Combo / Table header and Forms "flat"-look [message #279632 is a reply to message #279429] |
Thu, 20 January 2005 17:43  |
On Tue, 18 Jan 2005 09:52:35 -0500, Grant Gayed <grant_gayed@ca.ibm.com>=
wrote:
> I don't know about the Eclipse Forms support, but you can create a
> flat-looking combo at the swt level if instead you create a CCombo wit=
h
> SWT.FLAT style. There is not support for tables with flat headers =
> though.
Thank you very much for your hint. CCombo indeed honors the SWT.FLAT
stylebit which yields convenient looking results using forms.
j.
FUDForum. Page generated in 0.05604 seconds
