Home » Modeling » GMF (Graphical Modeling Framework) » Problem in the taipan example,"diagramLabel not been set"
Problem in the taipan example,"diagramLabel not been set" [message #27076] Wed, 23 August 2006 09:29 Go to next message
Hello, everyone
I follow the step of tutorial to implement an example. I choose the ecore
of the example taipan (taipan.ecore). When I try to "create generator
model..", it cast mistakes.
Diagnosis of
org.eclipse.gmf.mappings.impl.MappingImpl@16f0858 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#/}
The required feature 'diagramLabel' of
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@97974f {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@nodes.0/@ownedChild/@labelMappings.0}'
must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@4ef200 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@nodes.1/@ownedChild/@labelMappings.0}'
must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@5e5a7e {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@nodes.2/@ownedChild/@labelMappings.0}'
must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@870769 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@links.0/@labelMappings.0}'
must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@f77ec4 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@links.1/@labelMappings.0}'
must be set
'org.eclipse.gmf.mappings.impl.LabelMappingImpl@a386c4 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfmap#//@links.2/@labelMappings.0}'
must be set
when creating the GMFGraph Simple Model and GMFTool Simle Model, I do not
change anything the system given(all the elements in list are chosen).
Does anyone the reason and possible solution for the problem?
Thanks!
Re: Problem in the taipan example,"diagramLabel not been set" [message #27197 is a reply to message #27076] Wed, 23 August 2006 09:50 Go to previous messageGo to next message
------------rtN7gZPCGybAwdWfapCaOv
Content-Type: text/plain; format=flowed; delsp=yes; charset=iso-8859-15
Navigate to the Label Mapping in taipan.gmfmap and select appropriate
DiagramLabel from the properties view (RightClick on Label Mapping -> Show
properties View).
for selecting diagram labels, you can refer to taipan.gmfgraph.
see the snapshot if you still have troubles.
On Wed, 23 Aug 2006 15:29:48 +0200, lei <lxu@tssg.org> wrote:
> Hello, everyone
> ecore of the example taipan (taipan.ecore). When I try to "create
> generator model..", it cast mistakes.
> Diagnosis of
> must be set
> must be set
> must be set
> must be set
> must be set
> must be set
> not change anything the system given(all the elements in list are
> chosen).
> Thanks!
Content-Disposition: attachment; filename=ScreenHunter_39.gif
Content-Type: image/gif; name=ScreenHunter_39.gif
Content-Transfer-Encoding: Base64
R0lGODlhjQHtAfcAAAAAAFksZUBAQAhQiQxQiQxViRhZjTBQeW00fRxdkSxZ hXE4
hSBhkShhlShllX08kUBhjURhjTBpmYVAmYlEoThxnTxxnZFIqlltiV1tiXFt aUR5
oZlMsmFxjUh5tp1Qtkx9pWV1kcZQUIF1TKFVtlCBpWl5lYV5TG19laFdulmF qo19
SJF9SG2BmXGBmV2Fvl2JrpWBRIGBgVCNxnGFnaVlvnWFoZ2FRHmJoaGJQGmR snmN
oaWJQH2NpYGNpW2VskDCQMKBQK6NQIGRpYGRqrKNPHGVxoWRpaV50nWZtrJ5 xoWV
qraRPImVqomVromZro2Zqo2Zro2drpWdpZGdsp2dnZGhsp2hnZWhtpmltp2q uqqq
mbKukb6d3qWyvqWywsad1rqyjaqywnnSpb62icLCQKq2xtayaa62xq66yrq6 rrK6
ytqyjY3ajaXSebK+yra+ztq+fbbCzrrC0sLCwr7CzrrG0rbG4r7G0sbGxtbK ncLK
1uLKjdLOrsLO2sbO2sbO3sbS3trG7srS3trajdba4tba5sbu2truxuLm7s7u +t7q
8t7q+uLq+urq5urq6ubu+t7y/+ru+ury+u7y+u72+vL2+vb2//b6+vb6//r6 ////
/wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAA
AAAAAAAAAAAAAAAAACwAAAAAjQHtAQAI/wA3CRxIcGCdgwgRFlwokI4COgwj SpxI
saLFixgzatzIsaPHjyBDihxJEmOdRShTLqpjUYEMBRQBABgok+PMkjhz6tzJ s6fP
n0AjnlSJkiXFGTKQzphYU2DToFCjSp1KtarVjkOJGo3oMCkdpA8jzhy76aZM s2ed
pi1bdm3bp1fjyp1Lt27Jk2dlrtzkha9fgQpczqBDGCzMhWTJElTM9mZjtk4h S7ZL
ubLly3OzqtzKsOtgsBAZmo38lrHpx5EdO8bMurXr1yE1p+QcUWlSpqRPq5ac mCZv
2MCDCx8uUHbRli9jFtTtezdz0sSjS59+NaF1iw5DS1wNOW9ptU1Pf/+nTr68 +cqH
Q3LnXpH9+ffw47tef9Gt/Pv48+vfz7+///8ABijgTn0NaOCBCCao4IIMllRg gxBG
KCFDIkxo4YWsWZcQdiJod5V7GsEVHYgW0Yehf8btVZEIMlTIlHcYPUUidKLZ txxw
JKIlomiL9QgjbidGlyJtDFUhg5FVtLeRjMpt5xuPVc0IJZS7AUmjeE4+GeRr Q05E
B4tV0GFkh1a+BR59o5l5Jng3QrfWm+F1F55bcOaoo2pxjjUnljqmpmZ3brL5 GJ1S
bpnZInkBsFdfjA4kApiEidmii1M6pyVqz6E2WZWWBhqnn6AGutxqnTaW5qZa 6nZq
bp42typNhRr/alWXEn15pKRkZvlblaxmqqd9PybKm3d4plVqaSb2GCqfvMJY qol3
tkpjm7JSRutESB6ppLSoDtrct1Re+puyk+1Kbo3k+jrquKmyy2q5z6JbbWXX TsQi
pVbGm6q6vI6rr6bxkiourNxiCS68B0M77b9qzXuZhgpV9KWHuqr5o5t9rvnn lYKS
+mnHT9apXLAft/XnqxYvlma/IBNcrsPn4dtRrPvR3KRHKMMs34NR2Zyfz2WG OLDO
RBdt9NFIJ620SDxf1PTSUEct9dRUE/R0RVdXrfXWFQXB9dcAZr0QxAdhFwTF IAE9
nNpgW1ivREHI4PWLQ5+LGJ42qWfjlKnt/41Y22Ff9DZDbMhQOBt0T/v3dnhL ZTDf
AN/8MuADDk4QHXGzQUfhZ4sF6Mki+4jpntGaKqPfJvubZ8qqj/ary5THJ3ZB eOW1
qF8PBpF5pJzPfaPrCbvbG5rBq7tuu86teqqqiqcee4CWD4S54ZvLjXav5vYN 7LvE
Fp89wqN+bHDpDFP7PHmzExQ9QYcbDmRvy07+Ob/flu88+JGHTO3jDZ8P4PoE iZvv
PNewgF2KePGzlP36l6zxLSx4KtPIo/yHmfQZhGxmu166MjYeG0HLWHUCXm5Q FypY
KY9/b4qg/Oz1KJlR8D8DpEuy6rMTtn2khS18YWUseJ8ZvsiGJYoKDv9zqMMi GmiI
ODSiXXioxJAgcYJNrAsTQTLFizjiiljMoha3yMUuevGLYPTiVJ7owig6LIxo TKMa
16hFoJBxiGZcIlCqaBE22vGOeHRET95IxDhuCQgTyaMgBylGnPARiX7c4Rw1 Qgcg
aHATaAQAGCVJSEKS5JCITOQfZQDIiFyRkl0EZSizKBMsltKOokzjDTHZR01W cJEY
aYMMZNkGTzoilVrEZS5JCcpTVhKMHWFlK125pUbOkg6ydORCPpnLU+bFlM4k 5S2n
ScmzfNKat8SmJJ95TV9i0SLChCMxgUPHjjTqnH/ZBBCAcEzCJLOTA2EmF7dp ymky
U5T0pKc0e2n/T2r2U5/9/CZFwgnFcerMmG1AJifRJk9olpKfiQpoNeX5TIjW E6AY
3eKK+GhQ6pTzJ7ScpS3xedGSSrOe9syoRe/5z5a2caNP7GjU2AnPZUrUpP5k KUpx
qtKSrjSgV5TpgD76k0Y+spvVtCY3sznRnVJUqdrUpkuXKlCh6rCmNv3lGlOp yy/i
0qoBImpctMpGrqYRmy8FayLJylY7qvU/Yr1KW+eqyrf2J652zate92ogvPL1 r3Ep
I2AHqxGyEakzuYoLEGGn2JlBjoBDW6xaAeioFsXkYu1h2eLEQkLJ4sSHkO2e 3Q64
JtASlrKbyFaSJFcfzZpvsyDyLM42m5FX/9FMYKZ97FsBaKswjemRmyLd70ZY LA6K
ymJ7AlUITSgoeZnJWeN5rrige7GVhc91wJKtDmt3lts1SiCPuhVhxiRYdjlQ hJHr
F6cgaKqCdetlcBGYn47lseXl73Os89bCtOs/3kLqt/liL6D4VV1CGcuENSlu ppD1
Wucp0FWRNVezFMcc1/L3eahV7ba+J1/4pZeALAvxdA+2wvsVsH77mlyF2wVf CU/3
whgmynFWZNkNMwxvBuTYu+7Lp++5S4XeU6+KXSwq9qwYY3s1LIeAe0DhbrC5 zhJR
h0uWQua2rrmeq/KgQicn8ZluvRpTIJ0IG0z1bElKPjNy84JGZoH4Nf9vQSqU zRoo
tDbb+c54zjN8yvlmPfv5z4CmCJ8DTeioxLDQVmWikiXWOZLAOChz1i2i6SVj FVFE
gJetm6YdzDbZilbT0crtpHWi6EoftiDtQxzjNl3i002FMWvmkagbPOqg8HZ3 nNOg
YjgYZeLt2snUNXBsbZvCYO03T9mt9UhKnSjvplN31CNM72SdQAEPb7jVtp+U vSye
YrUqxI9WtlBM7SVcWw/EH9ZefLl34GwLuNVExm+QIyxucwqO3BRJ9fvSrak2 oZd+
2o5tvFF2ZHiFu960w/el5XazBHtPxw//8AJNLHH9YVu/w9pJQfOsaAwymsmN EzaW
wUes5eYPs7//03JiVK7yL7N6lRtHuEcOLZdZS3pJtGbzHodp5z6vLed346/N aesT
ccp80pnk+NELElM/+3wiT28bGZce6KkDOuoRwfrUOEr1qmCVa2+ctNYXQkej fgTN
Egp7173OSdYC/UqNq7NwMFnrsRekiiGtZcWITltX7+eQa78KQhWqTMiZPL/e yliv
sXu6HVWF7gi3u9VwR/kHrbOdhP+6/OiHYgRWPH5UIWjMAz+VwSdT19fd1afn V9p5
gx4joo+90Zcu+YHgfZYirViOSTvgiHuYfyyUfexJfxmaSm73sPY8wN89UOGH k/hu
hiVGzP7DUBsY4sT9FflaBzTnWx36sNF8/2NH63bwX6X20SfP0Edu/va7n4rS f7//
0J9O+dv//luiP/3xL1M38B9pdrdoFEEHbsBkurV+x6N+s3VhCEhtBoVam+AG MuB/
meVwonMuKPdyOIJgMWI6JRZEIUNCf/M6Bxc4O5EVijJjE4EIMsCCiMBa7jFD rvWB
PQFjOaMk1nV2Fyg0OThbVIOCs+ElEogIdMCCBQhZHDg664Yxirc6yNV47Ac7 ofNr
yfVjIGRlu9YxyQWF3BM+nCZCTdgnXEhxJqgT3KUXLIFOAuEGQxgpRkiBDfZg QrZj
PcZtJKZZSziC9kVfn2JbmHJcWdhvdNiHDxSIE2ZdwxY1QKiCndGGRv+IevuD cfWl
YMPSbgzGhx5EdJ+2exe4MgfWg8KCiAqDbZ7ocKAoWti1d/4RgCmRgpYmES7Y gmwm
h7wnYg90i/02I3nIYRHXie6GX6MYdwTHeg8GjP6GZECmNBAogXC4d7QIcXuI PNJY
QjNIZey1YODyb39oXqzHYmqGiChmjMoFjSUIGwHocQN4hBV4ZNWlLFqGeC33 hE2y
XJMIZWHGbqaIXC3DeBbXQfg4PHOyj9qjgc/TjPMicJRxgy+kf1wjguWIc7H2 fxI5
Ifs3kYDDkBaZkRoJV/G3kYFmkB4ZJOcIMdihjrVleEvykFChkjREfne2jBNY IpZY
QsHleBEpHAr/GSIWeJIkdnY7qTOsiBKueGoEEYsvGDQxaD7VaBU2eJM8qTa4 5WhO
yXdTs4ivuBAE2IJFOIGQqDJO2I5MqIVg6GTyyFlY+JVT+GJjWYVdJpb304Mg Qz5M
UpZXyFgIworNloaUt4ZtSBhv+FjP+F7R6CmDmYsDs4s+UpjA1168KI7bCGYC Z4dd
KC3EVjVWSZSbkJVE+IhI+G3CI2ymsYmbWJNSpomWiHypd4jQVYkWaF/y9h2q WWWU
CJcEmR9BiShBSBFGOYudV4sjhot0Jl9myXs81pjuRZOOOZndeJyCmJzL2T9V qXAT
wYwb5plzaIyHOI2GuWbW+HrGw5zdBojL/wmX/xKe3HiKDDKSGlKSBgib4QiW xAV3
J+SaXAZiwlWPJxNmM9lrWiiQ40mPXhmGDESIrxlHICkrCAlnJZGT1Sk1GKk1 DqmT
jzaDl8WSIXmhUVGRGDo1D7qhHvqh5tiRINpmBzqi6ckTAiiE7UlrDWiX0mGh MEho
MFmiqXlx8pkj53EnkcZZNsk32rejNdKj+YeirZibK9iCsoiUKMliVAlpnzWV Tfpj
ukeDN0ehb6eIRcqIWOmIXNmZ/lg6gFiFxSaW3rYxCZiWcumazAVsO9ltXqac bMKm
xhOPZHggeGk7evldEdiXW8mGgNmb0AieqcOJeCicKedexdWF5emP2P9jcaup jbFJ
n/AFowdymUKolZz5p/P1mY3XpqJ5mqQJWusBqtV2i5Dqi955jCRXquOYql46 VEQq
lEYKi0h6lF4amB32m/gTnC4JnYJ5nu8GjtSInUwKp8R4h8R6XMkYnTKGmQNB nTG6
qdepmNfoY9WoPNVaPsIqiNnZqMa6rbAGrN5ap32FouioojLZpkpoqIrnlfJZ ZGxp
n6EWoPZ4ib1CKPvChZCJYIYYXXPpr29KqUZDo3H2qqrYqy0JNLoYNR1KNRHa kgYL
sQqrcyZasXKhoRZrNA2bsRzbsT+xsR6bV2UQsgsCsl5SBisKNuFqsWUgAyO7 jjoh
WUYWdzyZNiL/eHEZuFcmGxGEIAM9Swjlt6Bpczcu+hMrG0QMKndrRwctSwh0 0LMo
+6oiQ5ZjCkJ6cpbxem1PuH0kY5Ml81xl6mHuuq5YJqTPw5DopKdl0LSRArUv G4fZ
+Hp9U2SsurJa63v8NrNe+JyJhxuSaXBdx7Q++7Qu25XTqI3uSbdfho3dOJrF eF8R
2a/uebSjKbe1uTU7yxA/67O82aqc5y80eSyKirffWbSP6WJqlqrgRnot+7bO GLd5
y429x6ojhpqlu6ynW4y8Cp4CO6Qfy0hRC7Osw3iJ6jGNG7CG2mXad4+cEqGP mn0A
A6BJOGbm57pP2hotSqVRIlOZ+2rzcaVW/5aQZkuy5Bsc3Vu+EnK+6Lu+7Ht3 Itq+
HWW98Msf6ns5wTu/59O66RpuMku0vtqBQ+toN5to7ysRmwu0FCuVOnimvXu0 jqXA
VCe4Tgu1hou1g3p9W0aCYVufWmtywdapwzmqa9muQadcHNy7F4K2lZdOazu4 hOG2
mpq7tSupsfuN3MqLt/uWWUatC/u3o3p0Eky49wu3nst9sku8jJuDjhuOkNti 9Bqp
lEuqTQylVYOxFnHAnSvDdeuou+rEp/qLU7yLiyqq2fpiXae/0arFsTu6tFuI pGuc
xyOcddiPgtosKGwhVowdQ8w4YnqvIGy8Soy8dmN9wGbETrJ4pFm20v+rn1aK cPIL
wZiRvfwrtMSUx+PHGgg4wBI6EpqMv54sFZb8yScqyqRcyiQRyqZcLWOQyg6T orUy
Bil7sKyMHxA4BjKwymWSlP5Lrgk8y1WBWocgA8F8CL3cPH7ny9PBW7Z8CHQQ zLCM
hMsrbx0sp8SbhMgMFGeoKHmaTmOwzJHizLislPEmrTg7cFJ6zSconVjpzc5s uMyj
qvMKxouJzjgBzMIszLk8zse6xTlMzzlRy7d8fNmTvJ/7e+fsz3dxrq8Mcp9Y re5o
tVwbguOL0FYRztuLsDdH0Q7ycxgdvvcxehpdNEkU0kgz0v83aFE0eyTtME13 0huB
ygEifKwsfgj/4n2AZ5EoPX2F98Cy/Hg27X2+bHy9jHZS2GnB9NPO55E5bRF5 N9TH
R7M/gdQtHdKmt1CdeXjvOM1pWs0aQyEE9cmDlrbpdHkJ5U6cpHmR2Yt3y89w vNJA
UdU7/VqOu3qBrK6PO88hXXtNPaVtnKs1zMR47dY8IdR8/de1+8YTR9LoR318 TMhh
O8il5cGGLNhSQdNMCb6Y7c8wfdkdHYWU/dlFs9mg7VGjXdoWK9qm3R8WDTg8 l5Gu
zBXPHMBb8n0bCdCr3XcHCNUQG9XlJRI37ZGWShHDjM89HVm6bRcmXRKQF5LB DdvC
3My37M6MGpVUyMhcHV0gkdwEIdW0DdyI/4KnKywQ3fzchAHOPqrPa/3XiZ0R Rsfd
3Y2hzd0Z7Bzd0Kx6i1OKy2e5R+3eXGei8R0Rw03MU/q4bKzezMcR/K12Fmvb At0p
BI3DgH3Q7P18s/za8s3Q+eiqEh3N1LXh2f3bqV0Qt+04mX25Xq3Sec3RBNnJ wafd
IT4h7/3iEBLj9Iza0UHjMr4gOD7LNj4dSZfjI/4eIA1T/mzh6xzLERtYrW3a DJ7P
VHnMNbsRKJ7a/80QAV7MKnbcGjfVIV7llzPfsY3bzwuoHlxsIsd0Sb3S2exs DzLe
zFzetzziUbmpohOu+T3FSB3SXi49YC7dyXPf0GtAC+TedTHkpLfnBP9x5QPO xAV+
58AHR4Q+Ri5OfE2+6K3qxmw96DvO306k4OZn5AVBB2HOowY9YQ+dYJLdvI7X 3xKR
4AlesUG+kiXePKwOU66e5vfX47utvSS04+B068KU4/IR6cJe7Odn7MiOf7qe 7OQh
AMx+V4wkAEj+7PwhADLg7MIbs1oetMxeRV0gA9/eBdy+oNtO7TtBB9beBXTw 7dIu
tYUcn2WrX2WObCAs7GKtpwKQ7pHC7tj+drdLuRiX6Qdu7pmp7+xewa3nrSUH 6MoL
4ett7uEO7lkcnmq6hF/8eVNM8ARh7f3+uhp+nQhju22t8ZfT7sJbuYmciafO 4WMK
vSQfER3/GpL//PLmkckTTfM4n/M677FM0PM+3/M73x9MoAlEX/RnwARBvx9F gAlM
3/RxcPRJn8xlExF6gAkB0PSYwAdPLwQgmDiy7b0xu5Iseced/eRJPhxaOhAk 8AEf
sABsTwKWEPeWwANdny6QTOJhr5IwmmbFPe4Hm9ZnTxlpLxAcAAZKQAGGzwFy bwk5
UPfF+vV4nxMWuvdRfve7zp3a6xqDvwkXoAQ1gACefwGUMPqUcANBWopx2sca 7I1t
6ZZExmWPDabh29BdG4Uld7Vmml8C+u4YbMEuR6YS/YXT24fE3661j92zr/qe LRZs
vgkBsAAUgAAIQAEUsAABMAnYHwOVEvJM/4r7ShyC3ILD2Kqc3q+rycdvVgi7 AD+u
RXzXm0dtIravs2vg7gj/hw2cv/qmFrH5E2D4iK8EADEB0kBILDYdRLgJAMKF CxUC
gKiQ4cSDDSk6dJgQI0OIESNWnJjRIkiOHUmKlEgyZUmPGiWi/PjQpEuQG18m ZImS
ZcqNMGV6zEizosmRPIlePFkzZMiOFmPy1HhUZ9OVQX8WrVqVKk6uCBctqtN1 0wMl
NSiUfUAQ0oquPn2qfAt1JVKVUbPGDWpV7k24OK3m5at1rt+lUPUO7qvU8NLD T7Mq
xfvYZs/CgeFOpngzss7MdSOLBb3pa9iuKR48WHA6RSPWjU60ZVyZc/9RzJIz A97c
eWrf2UkVQ9Zt+25SwLZt8qUM3LPv4bl9Y3ZuuXZz2cLjDk8cGmEd7qDVMArA SPx4
RiPazsSIHit6utPzfpwpc+f79Mflz90qMqbUn0P1zz5qsdvguyjAnti7Lz79 /HNK
wQADq81B+AhEcCgGX5KQtsv+888zx7QDMUQQZSCxRBNPRDFFFVdksUUXX4Qx Rhln
pLFGG2/EMUcdd+RxRRF/FEsGR4Ykskgjj0QySSKFVLLJJZ2E8kgmo6SyyCmr xDJL
LbdE8kouvwQzTDG/BLLMhLwcU0k0s1wTzDbHfDNNOec0Mk4678QzTyLN5NPO Of10
ElAsBd2SUD3/D43SUEQXZdTJzvgMTVE3w5Q0UCwBMBJTNRvN9EtN5ayUU1EZ fRS2
ukYssikxP32SSFZZHRJWR65sSlYqaVX1SFhtbTXWXNPE9FNefYUIyWG5DHVU ZfMs
lavDQqTV1TBljbZJanWdtNMkd20SzWPBFFbJb7/VMtllz5Vzsv2AGkk9x6p1 RNOO
Yo2XWGLlLbbXeqWNt9h59aWXXnyFzRfgfe3tN9+B68RWYIQT1lbeeuf9NeBM FT44
WH8HJphVc9EFGUzNKsMOwjNT5VdajB1m2UqUVX7ZZW37tTjYlGdtuNNwbbYY 55lX
nvhmiYMOt2dZd854X4mRljJkp0VtqVb8/6rjbBNcC1a1Y39hZlhomnse0tuU a024
YJ9jLjtpjf8NO2et1zbbZrmTNtrtoFleWuVrn+YbUZKn/k1DhOCtme6xD9b3 VVd5
ljnmom9u/PCW5+7SbrB5nZtywxEvnHGe867Z475HZ9YpkqMLinC1D2c6csW5 jrzw
zm8We3aHHz9b8tUv59dzyLm9nWvQEReddOPTPWnd9Iw6LnW07yUeaHxdpxhi X2Pf
nG2225457VwXxh537c2WfXrcobeeY6Unt97g49/XEtIyPx6UUjrp3xR+RvHX f3T5
geRfouz3Jz0FsH/5O2ACofS/HxnQUtkCVQEVKMEJVhBJDISWqD7mQP8HYs+C Yurg
BznVoxWNaoP3o6AI0xRCFS4Kgy+EYQxlOEMa1tCGN8RhDnW4Qx720Ic/BGIQ hTjE
HJLQiEdEYhKVuEQmNtGJT1xiC6U4RSpW0YpXxGIWtbhFLnbRi1/sGxTFOEYy ltGM
Z0RjGll0LhZWqY0EdFoeSBQBOtbRjnfEYx71uEc+9tGPdSxRHsCILDaG7I0R DJkc
/7hIRjbSkX0M5CDrt6xDQqmScEqkDB65SU520o8kEqQkLVlIkF0ShCBTpCdV uUpV
yiCUokSgCQ2ZQFMmKZWsxGUuFwlKWCapll1D1y+/JMwi3ZKOGMhABzoQAhOg oAU0
sMEOekAEXVb/05Ou7GXTKDnLAxKTSMaMgBUC4Yc9iGEOcEgDGszwhS9Q05rv 1EA8
7RhPDegRm9l0H/nIN0A6kct9VfInJvV0LHBiwAc+OMISmhAFKVABC1nQgjvf WU0N
HKSeEajoJi6ax3saD3jT8qA+A3qri410W25M1faslaXzPTCl+9QSQTVpxycg ZBBd
ecId77DTO+iyp3T86SMzqtGhbpSjr4RS1ghWtlepVFzd81RId2XSUeaMSyOF lz+p
SlWAcXWlSgLnE/4wVrL+ARBkzakdgxrUVbK1k0NFiFHtidSnpnRxnNPdVyF3 VZd9
z6/oI9v4zLYm8BVNsOBrX+5eJ1ilYayw/1tLn0pVh7Bf/cuyDxsSOJeAkD10 ZQk6
rWNPRQvUnZK2tKYFagREW9qf8jS0p90jXOW6x46eVGdEs23AGOtXrPUWdBWT gcI0
dr2NEXd6NIMpYW/Lu9YxznUoax3nhrvcu1W3eGDbXXVXhztwDgEPdvguHsQ7 XjwM
AbSpPe1aVRva9aK3texVr1tjm5DZ0pauUMUt3F7HXMdll1vSs5Jwv1bcWk1X wBXL
Xe8uqzX/4lWx0M3ayyK8OMhad3OTbe7XtlsxcOIAIXboCg506tr2lni07nWt elHM
WvniEa4WZWRtIwbZ4XVPfViDne+8l9fgms/HGr7egNWXT7p9LsfZff8u7OqW YfYx
mXvYdXKFNWckcLpgDW9Ygx3WsGUur8EF52VvatELXzDHN4+wdXFcixrj+y5Z tw4m
nuGk3OAoB/jHyJ3uXYVsVyI/zs90rpzkouu7P2cYd176qI6bvDlwmgAhcuiK CcAs
ZhNX2syUPnGJNX3HjF60042UMeuo+zPZLdrUFu6ZkHgrYKbuGc/kuxqFxWdZ WneM
enHzbWMrnDbkUpZ2uqp153KtayrPtI4YQHaylZ3sSWuaxDxda3rVeuJno9nF 8qwj
PR0Zauj9d1vbU+rQJsbYbr/0urIsJS3RBc6JUrrdE+V2Fr2ZYGXNm03rNva7 3a1v
a/Kyi/O295P/9WdvdvPb4PBusxUBzs3+ETzfB4f4O/0tb1IGU93nKnjENY7L SF5x
4enuJr43PnJ4T1yKakR5ylV+IpK3XOIrx5HLZT5zmtfc5jfHec51vnOe99zn Psdn
0IU+dKIX3ehHR3rSlb50pjfd6U+HetSlPnWqV93qV8d61rW+da533etfB3vY xT52
spfd7GdHe9rVvna2t93tb4d73OU+d7rX3e53x3ve9b53vvfd738HfOAFP3jC F97w
h6cUzBW/eMY33vGPh3zkJT95yleeR0TEfOY1v3nOd97zm0B86EW/RTqAfvSn T2Dp
Ub96/amer6x/n1fH7npj7RXOsH/9mGQv/3baWw6/uI/q54Q7bLnNue29J3X6 igxT
4J8UwIYWd0vRjvxRB499zadSofVWPTe7nfrQlbWFyYb9KGm/ZaXW7tq/LzyY RZf8
5Rf1qT96fNPXdbtHfr+Tmjpk5ev59mdfP6HhPt7KP3DJPe+rvwLsG9nbPa4L QAWE
wDF5wAikwArsHzrAwAzUwA3kwA70wA8EwRAUwREkwRI0wRNEwRRUwRVkwRZ0 wReE
wRhMQcujwRq0wRtsPOx7BAvkwTHZwR4EQi75wSAcunE5uiE0EgGYICO8u8o6 lGNh
wqJDQiKhAwGgA3HRnifUq9ziNb3aPenrJTDspy2sPaObwiERABlQwv/cakCA IkOr
EkP0Y6mkUxzEirDHyrPLGT5b+z9YOsMqkAFArAIuFD4GK0R70aeSQp/+Kx/H gpip
4sNgw8M2VKA6pK48xJu6qT1DO8IiqcJApANAtEI4lC61OZr1ibNNPLL9IrTo 6y/M
ATTs0iJL3LHzmzBxky7uGzddJLohFIA0rIIMFMU19JobU7Jb1MTw25kJAyz8 S8X0
Y0ZCs70sskROtB1cZEUk60NRQsJPDEZRvEIbEz9nNLJnjEWvecW8GrRVdMYu Mqxz
ZBpsTMdT68UjEcRAZEP5kzNU3C94NMcGS0bnskZU8yIn5DVmrEVsrDW4oTBZ xKcz
dIQ0JEZgw7H/g+RFZIyePezCy9orjjSu4WtIiyS2zUE6Suw6iKzCcAQWItwS p4I7
iIxIYGE+liQ8mKTJL3mEnNTJneTJnvTJnwTKoBTKoSTKojTKo0TKpFTKpWTK pnTK
p4TKqJRKpfy8qrTK0HiEq9TKreTKrvTKHsrKrxTLsSTLsjTLg8hKMlDLtWRL tuyD
s4TLuASSZ5HLuszKMFCEvNTLvdzLuvTLs5Qal8CKCzEVxPjLIbpLvlRMvTzM xvxK
uqya7BAKunRMsNwELlCEBmiARpiEJNABFdgACZCABCCARqjM07xKvaCKhniK qZgQ
1qwPyIgP1HyhrNyCzGwASaiE3eTN3qTN/9/kvPyIDcI4FcG5i+YBTgzKyivA zUq4
hCT4ARgAgQqoAAcwgAFIzuwcor8YzqhQHuOUmt7QTkjJyinAzUzQhPRUz/Uc z/bs
Ie5UDqHgjdsgzsdwTyDJSihQhEzgT03wzBKwAAZggALgz/s00BuCz5Gpz/nM DvA8
0B/JSieQUAkthAq1UAtNhAfV0BgKzNW0kFLJj+VJEPrcUO0IS5zwTNAUTdIs 0RZ1
Ue080YRI0dAcTQJ40RvFUceM0Rzl0R49zR310SBFiKkk0iI10iNF0iRV0iVl 0iZN
UiEtSyCF0imlUq6U0irF0izdvCvV0i71Uh+6UiTYIcoUETL90hoKTP/tMNMz FREp
pQMkKD2xSNP9aJbBdBYQWdP6zFM2bZbQ2FM+BQ0pRQIZEFM5PQ8SLUxDVVMz +VNA
BVHl6RC36JBJZVMgFQQZuFRBUFSaiE3+gE3kdBfilJBJNZDXbFQoDc9HcVAC +Q1A
jdE3xVQ6uFQ4dRYFYY4FMZnPmJrrEEyq6VMv/YsQbQkGvYqHcNRNOFEkGFRB yMBZ
LVQQvVX6RJ2tCJzB8NBqjUw2TVBi1VW74NNXXVZZJdQ4lc+rcFBsrQ7YuA7U sU9A
TVAN6Q3xPBUvtVRMxdRNXQ55hdd03dXT8dVqPVbV/M4PvVZS/RB67YpBfdZa fRCj
sBCYyBCCdYz/2DTYCWEeyTzWjNUhN6VVjfXYj02IMAXZkf1YLiVZ1HTSlFXZ lWXZ
lnXZl4XZoDzZIDLZmbXZM63Zm9XZLE3LtvRZtXzLnb3RUz3VHE3MxVSESFDa vPTW
BRVarqTWuWRY0ChaHD3axVTaSGDaef3Vp/28bMVTPcVXhMVMzWwN1pgEIzCC A5gE
0+Tat/Xarx0QDiHM4uwPk+HZTbhNzZQEgqiEtT0AI9jNkiDVio3b4KQLa21X 7pRU
uPXR5WzOv70EI4AAtZ3cA6hT6ejaw33PDKkP41Tct7DTKS3P8zyAwA1cD/CA tTUC
3ZCK/zhYzv0h5JzMxSUM0TVMKM3P/eTP/0x4gQN4AU1Q28DVBESljdGVXSHa DXS1
22gFW9LdhAmdUEM4gAodXiPI0AbtV8dNXh0qjoi9W++U1s193NAA3E0IXNeN Gkjt
Xves2hY12fNN3/bF0vctUZPFXITIX/rlX5Tt37iM2QAW4AEm4AI24JT9X+VM 4AW+
z5xl4Af+y5792bYMWgi24LG8WqRlzAtOzb8Jkait3W/dBLzU4L7kYKt83rDl 2hTG
0qws283szM+kUdJ02xOWW8VAEPtwzU59TdmM3fvVW9zUzd4kYhtGYQFBjuWw W301
1nZ9UcjVTOeETumkTuvETiOW2wPxVPyIWAB5EBZ+0NLVTPRczzLG4s8sbtWR KY7x
xVh5vdHd7V3/1AEAFVACzYQzvmG8jcx3tU9dtV/ajFDpvdBBzl48RtzkcWPE CFGJ
pd3c3VApndEVtVFDpmTMg2QZluRK1mQhcuBN9mQg6uRPzqEDJuVSNuVTRmUC FmW0
XOVWtmRXhmWajeVZtkxatmUcCuVb1mX83OVejqFc9uVg7gpgFuZiZmVjRuY2 TeZl
NlFmduZhfuZoHlJplmZipuZZtuZrRstU5uZu9uZvBmejbOVs1uZxLmdmJudz /uR0
VudNZmdpDggAOw==
------------rtN7gZPCGybAwdWfapCaOv--
Re: Problem in the taipan example,"diagramLabel not been set" [message #27360 is a reply to message #27197] Wed, 23 August 2006 10:53 Go to previous messageGo to next message
Hi, thank you for your reply.I have followed your advice to set diagram
lable for every lable mapping. When I try to "Create generator Model..",
it still gave the mistakes
Diagnosis of
org.eclipse.gmf.codegen.gmfgen.impl.GenEditorGeneratorImpl@1e09588 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfgen#/}
The required feature 'targetMetaFeature' of
'org.eclipse.gmf.codegen.gmfgen.impl.TypeLinkModelFacetImpl@1d67a9f {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfgen#//@diagram/@links.0/@modelFacet}'
must be set
'org.eclipse.gmf.codegen.gmfgen.impl.TypeLinkModelFacetImpl@c9615 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfgen#//@diagram/@links.1/@modelFacet}'
must be set
'org.eclipse.gmf.codegen.gmfgen.impl.TypeLinkModelFacetImpl@517317 {platform:/resource/org.eclipse.gmf.examples.taipan/model/ta ipan.gmfgen#//@diagram/@links.2/@modelFacet}'
must be set
It seems some diagram lables have not been set. But I can not find them.I
can not attach the screen snapshot to here. I think I have set all the
label diagrams in the Hi, I have followed your advice to set diagram lable
for every lable mapping. When I try to "Create generator Model..", it
Diagnosis of
must be set
must be set
must be set
It seems some diagram lables have not been set. But I can not find them. I
can not attch the screen snapshot to here. I think I have set all the
label mapping in
platform:/resource/org.eclipse.gmf.examples.taipan/model.tai pan.gmfmap.
> properties View).
>> Hello, everyone
>> Diagnosis of
>> must be set
>> must be set
>> must be set
>> must be set
>> must be set
>> must be set
>> chosen).
>> Thanks!
Re: Problem in the taipan example,"diagramLabel not been set" [message #27931 is a reply to message #27360] Wed, 23 August 2006 16:00 Go to previous messageGo to next message
Hello lei,
Looks like this time you should set "Target Feature" properties for all LinkMappings.
Alex Shatalin
Re: Problem in the taipan example,"diagramLabel not been set" [message #28204 is a reply to message #27931] Thu, 24 August 2006 04:11 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Hello!
I'd also advice you to compare gmf models you create with gmf models
provided by TaiPan diagram editor plugin in CVS; differences may give
you important clues on what you've missed.
Alex Shatalin wrote:
> Hello lei,
> LinkMappings.
> Alex Shatalin
Re: Problem in the taipan example,"diagramLabel not been set" [message #29076 is a reply to message #27931] Thu, 24 August 2006 11:21 Go to previous message
After setting "Target Feature", I generate the *.gmfgen file. After that I
try to generate diagram code. It shows errors "InvocationTargetException",
how can i deal with it ?
Also can anyone tell where can I find a detail GMF example. I means it
gives lots of details of every step. How to set ? how those setting effect
the result? Thanks a lot
Previous Topic:custom image
Next Topic:Overlaped compartments
Current Time: Sun May 04 03:52:25 EDT 2025
Powered by FUDForum. Page generated in 0.03904 seconds
