Home » Eclipse Projects » Eclipse Platform » Import Confusion
Import Confusion [message #279218] Thu, 13 January 2005 13:04 Go to next message
Originally posted by: xixhub.na.direcway.com
Trying to Import Projects from 2.1 on D drive to new 3.0.1 on C drive. When
done I going to reformat D drive, so I must be certian they are in 3.0.1 on
C drive.
Followed Help Import Instructions. Imported Project A. It is now in 3.0.1
dev studio. I can edit it and run it, but is it really there? Looked in
Explorer under C:\Eclipse_3_0_1\eclipse\workspace\ and it is not there.
What is there are a couple test projects that I just created and ran, but no
Project A.
So I went to the D drive and copied the file for Project B from 2.1 into
workspace of 3.0.1. Project B now shows up in explorer as living in 3.0.1's
workspace, but when opening the development studio it is not there. I'm
very confused.
Project A, imported into 3.0.1 shows up within 3.0.1 but it's folder or any
evidence of it is not in the Explorer.
Project B, copied into 3.0.1 from the explorer is there in 3.0.1 workspace
in the explorer but not there in the dev studio.
I've got to get this straightened out before I start blowing away Eclipse
2.1 and the D drive.
Thanks, Sam
Re: Import Confusion [message #279220 is a reply to message #279218] Thu, 13 January 2005 13:26 Go to previous messageGo to next message
When
on
> C drive.
no
> Project A.
3.0.1's
> very confused.
any
> Thanks, Sam
If you "Import exist project into workspace" the actual project files are
not copied to your workspace. Eclipse only creates some metadata to tell it
where on the file system the project actually exists. If you want to move
them to your C: drive, you will have to use the "Import file system"
function. Simply copying the files in to you workspace does not put them in
an Eclipse project.
Chris
Re: Import Confusion [message #279265 is a reply to message #279220] Fri, 14 January 2005 10:43 Go to previous message
> an Eclipse project.
I recommend deleting the Project (in 3.0) that you tried to import (do
not delete contents if it offers - those contents are still on your old
2.1 directory if I understand you correctly).
Then copy the Project directory from the 2.1 location into your 3.0
workspace directory (using Windoze file explorer or whatever). Then back
in Eclipse 3.0, start the process of creating a new project
(File > New > Project). Use the same name as the Project you just copied
over; the dialog should show a message at the bottom that it detected an
existing project contents in that location. Go ahead and finish the
dialog and it should set up the project from there.
Eclipse recognizes that the location already exists on disk and that it
contains an Eclipse Project.
HTH,
Eric
Previous Topic:How to change the font side for Java editor in Solaris
Next Topic:Still Import Confusion
Current Time: Tue Jul 22 03:26:05 EDT 2025
Powered by FUDForum. Page generated in 0.04267 seconds
