| 3.1 M4 & JSSE [message #278800] |
Fri, 07 January 2005 08:12  |
I have an application that uses SSL. It runs fine from the command line.
When I run it in eclipse, it bombs with the trace below. I'm using JDK
1.5.0_01.
Clearly, some library isn't being found. Anyone have any idea what it might
be?
Thanks much.
Steve Buroff
javax.net.ssl.SSLKeyException: RSA premaster secret error
at
com.sun.net.ssl.internal.ssl.PreMasterSecret.<init>(PreMasterSecret.java:86)
at
com.sun.net.ssl.internal.ssl.ClientHandshaker.serverHelloDon e(ClientHandshaker.java:514)
at
com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage (ClientHandshaker.java:160)
at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Handshak er.java:495)
at
com.sun.net.ssl.internal.ssl.Handshaker.process_record(Hands haker.java:433)
at
com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSoc ketImpl.java:815)
at
com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHan dshake(SSLSocketImpl.java:1025)
at
com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SS LSocketImpl.java:1038)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsCli ent.java:405)
at
sun.net.www.protocol.https.AbstractDelegateHttpsURLConnectio n.connect(AbstractDelegateHttpsURLConnection.java:170)
at
sun.net.www.protocol.http.HttpURLConnection.getOutputStream( HttpURLConnection.java:828)
at
sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputS tream(HttpsURLConnectionImpl.java:230)
at
com.omni.tradesports.comm.TradeSportsServer.sendRequest(Trad eSportsServer.java:445)
at
com.omni.tradesports.comm.TradeSportsServer.getLogin(TradeSp ortsServer.java:219)
at com.omni.tradesports.user.UserManager.login(UserManager.java :136)
at com.omni.tradesports.OmniTrade.<init>(OmniTrade.java:121)
at com.omni.tradesports.OmniTrade.main(OmniTrade.java:62)
Caused by: java.security.NoSuchAlgorithmException: Cannot find any provider
supporting RSA/ECB/PKCS1Padding
at javax.crypto.Cipher.getInstance(DashoA12275)
at com.sun.net.ssl.internal.ssl.JsseJce.getCipher(JsseJce.java: 90)
at com.sun.net.ssl.internal.ssl.RSACipher.<init>(RSACipher.java:35)
at com.sun.net.ssl.internal.ssl.RSACipher.getInstance(RSACipher .java:69)
at
com.sun.net.ssl.internal.ssl.PreMasterSecret.<init>(PreMasterSecret.java:82)
.... 16 more
| Re: 3.1 M4 & JSSE [message #278864 is a reply to message #278850] |
Sun, 09 January 2005 09:49  |
That worked. Thank you very much for the help.
Steve
"xiangya" <ya_xiang@hotmail.com> wrote in message
news:crpkmp$4sp$1@www.eclipse.org...
> 1, set a new JRE to your jre home not jdk home.
> 2,configure your java application laucher item and set bootstrap entries
> to
> null(remove default entries) and
> 3, run it, and you will see jre/bin/javaw.exe without bootstrap option and
> just with only classpath option.
> Addition, from stack trace message there should be an another message
> class
> already in class path.
> Regards.
> xiangya
> "Steven Buroff" <sburoff@optonline.net> д
FUDForum. Page generated in 0.04477 seconds
