mtj create package but without html [message #27870] |
Thu, 12 March 2009 08:35  |
eclipse 3.4, mtj 1.0m5
mtj can't copy html file from /res to build/ ..?
when i renmae the exmple.html to exmple.txt its copy automation, but
..html doesn't work..?
Re: mtj create package but without html [message #28185 is a reply to message #28146] |
Fri, 27 March 2009 10:26  |
Originally posted by: craigjunk.setera.org
You may also want to make sure that another application on your computer
does not have the file open as well. This might cause an operating
system lock that could cause this type of issue.
Craig
ArLi Weng wrote:
> hi thank for your reply.
> but not rules in project, and refresh\restart\clean\rebuild the
> workspace.. but not effect..
> maybe conflict with some plug-in(jdt/cdt/svn/ve/wdt installed from
> download.eclipse.org),
> sorry for this, now i known its my problem, let me more test..
> arli
Re: mtj create package but without html [message #571927 is a reply to message #27870] |
Thu, 12 March 2009 08:43  |
update:
can't copy html file from /res to bin/
Re: mtj create package but without html [message #571978 is a reply to message #27910] |
Wed, 18 March 2009 13:33  |
I've created a MIDlet project using MTJ 1.0 M5 on a Eclipse SDK 3.4, with
two files on the /res foder (a.txt and a.html) and both were correctly
copied to the final jar package.
Could you check if your /res folder is configured as a source folder in
the "Java Build Path" property page? You can also checked in the
included/excluded rules also available in that page.
You could also try to refresh your workspace, it may be out of sync with
the file system.
Re: mtj create package but without html [message #572062 is a reply to message #28029] |
Mon, 23 March 2009 06:27  |
arli
Diego Madruga Sandin wrote:
> with two files on the /res foder (a.txt and a.html) and both were
> correctly copied to the final jar package.
> the file system.
Re: mtj create package but without html [message #572093 is a reply to message #28146] |
Craig
> arli
FUDForum. Page generated in 0.09314 seconds
