Home » Eclipse Projects » DSDP - Target Management » Re: info on rse project
Re: info on rse project [message #26965] |
Tue, 23 September 2008 14:16  |
Hello Kar,
the right newsgroup for RSE is actually
news:eclipse.dsdp.tm
Regarding your question, what you need to do is actually
implement the IFileService interface for your kind of
communication layer, as well as extend IConnectorService.
The rest is a bit of syntactic sugar, so it shouldn't be
too bad.
You can look at existing RSE source code to see how it has
been done for the FTP or SSH connections. Feel free to ask
if you have more questions.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Kar wrote:
> Hi all,
> hope this is the right place where I can ask this question ...
> I have got an rcp application that deal with a server via corba and use
> a few views to display information present in a db (a tree view for the
> foders and table view for the file contents).
> I just got to see the RSE project ...
> I was wandering how difficult would to implement the
> "logic/communication" layer ... so that all the other operation like
> move copy delete and above all opening editor on files.
> any help or something to read would be appreciated.
> Kar
Re: info on rse project [message #27123 is a reply to message #26965] |
Wed, 24 September 2008 03:41   |
Thanks Martin ... I was already reading the code in the ftp example ...
thanks a lot
Kar
"Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
news:48D93281.60809@windriver.com...
> Hello Kar,
> too bad.
> Cheers,
> Kar wrote:
>> Hi all,
>> I have got an rcp application that deal with a server via corba and use a
>> "logic/communication" layer ... so that all the other operation like move
>> Kar
Re: info on rse project [message #27778 is a reply to message #27123] |
Tue, 30 September 2008 06:22   |
Hi all,
I manage following the Martin's hint to recreate a
FileService/ConnectorService plug-ins (based on the ftp example).
I was wondering now hot to go ahead.
what I would love to achieve is a new view which will help me to display the
content of my db (files/folders) and from there stick actions like:
- open and editor on a file
- import export file
I cannot use the rse connection view because I want to create a new view to
use in my rcp application.
I did play few weeks ago with the eclipse file system
(org.eclipse.core.filesystem) and I manage to create a quick example. What I
had to do with the efs was just
EFS.getFileSystem("schema").getStore(uris)
and build a treeviewer based on the IFileStore input ...
What shall I do now, what is the correct way to interact/initialize my rse
service?
I believe I just should
MyService . new ()
- set user/ pass/ hot
- connect
- getFile (root)
and move from there?
is that correct ...
The second bit will be to see how the RSE (I believe is the SystemViewPart)
deals with opening editors on a file.
Kar
"Kar" <carmeloscala@hotmail.com> wrote in message
news:gbcqvh$ab6$1@build.eclipse.org...
> thanks a lot
> Kar
>> Hello Kar,
>> too bad.
>> Cheers,
>> Kar wrote:
>>> Hi all,
>>> Kar
Re: info on rse project [message #27813 is a reply to message #27778] |
Tue, 30 September 2008 07:07   |
Hello Kar,
I'm a little confused. Your original question said that you wanted
to use RSE infrastructure for move, copy, delete, drag&drop,
copy&paste...
Now if you don't want to use the RSE SystemView but have your own
TreeViewer instead, how do you think should RSE infrastructure be
leveraged? If you also don't want the RSE login screen, I'm wondering
what benefit you see in using RSE?
If you think that EFS fits your neeeds, why don't you just
implement IFileSystem / IFileStore directly? It's just two interfaces
to implement, and there's quite some example code available.
The "open editor" and "import/export file" actions should be
pretty straightforward to implement based on EFS since you'll
have a Stream available. Just read the Platform Javadocs, or
look at some existing source code to see how it's done...
Kar wrote:
> Hi all,
> the content of my db (files/folders) and from there stick actions like:
> to use in my rcp application.
> What I had to do with the efs was just
> rse service?
> MyService . new ()
> - connect
> - getFile (root)
> is that correct ...
> SystemViewPart) deals with opening editors on a file.
> Regards
> Kar
>> thanks a lot
>> Kar
>>> Hello Kar,
>>> too bad.
>>> Cheers,
>>> Kar wrote:
>>>> Hi all,
>>>> use a few views to display information present in a db (a tree view
>>>> for the foders and table view for the file contents).
>>>> Kar
Re: info on rse project [message #27853 is a reply to message #27813] |
Tue, 30 September 2008 08:14   |
That would have been step 3 ...
I mean give normal users an RCP application ... and to developer the direct
access to the db via rse using the eclipse ide.
Kar
news:48E2087F.7020100@windriver.com...
> Hello Kar,
> copy&paste...
> leveraged? If you also don't want the RSE login screen, I'm wondering what
> Cheers,
> Kar wrote:
>> Hi all,
>> rse service?
>> MyService . new ()
>> - connect
>> - getFile (root)
>> is that correct ...
>> Regards
>> Kar
>>> thanks a lot
>>> Kar
>>>> Hello Kar,
>>>> too bad.
>>>> Cheers,
>>>> Kar wrote:
>>>>> Hi all,
>>>>> Kar
Re: info on rse project [message #27893 is a reply to message #27853] |
Tue, 30 September 2008 13:33   |
So well,
if you want RSE for your developers, you'll need to implement
IFileService / IConnectorService. Looks like you've basically
got that working, so your developers should be good.
Next, for your RCP, you want to have some connection status
lifecycle (programmatic connect). I'd think that you'll want
to drive your IConnectorService programmatically to get some
connected session.
Finally, for the RCP, you want your own TreeViewer, so I'd think
that you need to simply write a TreeContentProvider which
translates the getChildren() / getLabel() etc into calls of
your IFileService.
That is, in terms of RSE interfaces you'd stay on the "Service"
level and not use any of the Subsystem functionality (because
pulling in Subsystem functionality requires dependency on
org.eclipse.rse.ui which seems like you want to avoid).
> direct access to the db via rse using the eclipse ide.
> Kar
>> Hello Kar,
>> copy&paste...
>> Cheers,
>> Kar wrote:
>>> Hi all,
>>> display the content of my db (files/folders) and from there stick
>>> actions like:
>>> view to use in my rcp application.
>>> my rse service?
>>> MyService . new ()
>>> - connect
>>> - getFile (root)
>>> is that correct ...
>>> Regards
>>> Kar
>>>> thanks a lot
>>>> Kar
>>>>> Hello Kar,
>>>>> too bad.
>>>>> Cheers,
>>>>> Kar wrote:
>>>>>> Hi all,
>>>>>> and use a few views to display information present in a db (a tree
>>>>>> view for the foders and table view for the file contents).
>>>>>> like move copy delete and above all opening editor on files.
>>>>>> Kar
Re: info on rse project [message #27933 is a reply to message #27893] |
Wed, 01 October 2008 09:15   |
Still thanks Martin for ur help and hope I can ask more without bothering
too much.
I have almost copied everything about the two plugins (ftp services /
subsystems) and adapted them to what I need ...
The subsystem plugin has got the "same" extension point of the ftp ...
<extension point="org.eclipse.rse.core.systemTypes">
<systemType
label="%EomSystemLabel"
description="%EomSystemDescription"
icon="icons/full/obj16/systemfiles_obj.gif"
iconLive="icons/full/obj16/systemfileslive_obj.gif"
id="com.eid.rse.systemtype.eom"
name="EOM Only"/>
</extension>
<extension point="org.eclipse.rse.core.subsystemConfigurations">
<configuration
systemTypeIds="org.eclipse.rse.systemtype.windows"
name="%Files"
description="%FilesDescription"
iconlive="icons/full/obj16/systemfileslive_obj.gif"
category="files"
class=" com.eid.rse.subsystems.files.eom.EOMFileSubSystemConfigurati on "
vendor="%providerName"
priority="100"
id="eom.files"
serviceType="_eom._corba">
</configuration>
</extension>
But I cannot see it appearing in the connection dialog. I have checked the
runtime folder for any logs or error ... but nothing ... the plugins state
from about dialog are in:
com.eid.rse.sevices.files.eom (1.0.0) "pluginName" [Starting]
com.eid.rse.subsystems.files.eom (1.0.0) "pluginName" [Active]
where shall I check for errors? What am I doing wrong?
About the rcp ... In the test I did yesterday I was using as input for the
tree object of type IHostFile (I used a IWorkbenchAdapter to get information
for the tree but this should be the same as creating my own label/content
provider). U said to use the IFileService that, for what I have seen in the
ftp example is the FTPService ... mine EOMService ... that I thought would
have dealt with connection/create/copy/retrieve files ...
If I'm not asking too much could u please correct me.
Thanks again
Kar
news:48E262F4.10302@windriver.com...
> So well,
> connected session.
> your IFileService.
> Cheers,
>> Kar
>>> Hello Kar,
>>> copy&paste...
>>> Cheers,
>>> Kar wrote:
>>>> Hi all,
>>>> actions like:
>>>> rse service?
>>>> MyService . new ()
>>>> - connect
>>>> - getFile (root)
>>>> is that correct ...
>>>> Regards
>>>> Kar
>>>>> thanks a lot
>>>>> Kar
>>>>>> Hello Kar,
>>>>>> too bad.
>>>>>> Cheers,
>>>>>> Kar wrote:
>>>>>>> Hi all,
>>>>>>> Kar
Re: info on rse project [message #28130 is a reply to message #27933] |
Wed, 08 October 2008 12:00  |
Kar,
your subsystem is registered against "systemtype.windows".
Therefore, your "EOM" systemtype has no subsystem registered
against it. And therefore, it is not visible in the wizard.
> bothering too much.
> <systemType
> name="EOM Only"/>
> </extension>
> <configuration
> name="%Files"
> category="files"
> priority="100"
> id="eom.files"
> </configuration>
> </extension>
> the runtime folder for any logs or error ... but nothing ... the plugins
> state from about dialog are in:
> the tree object of type IHostFile (I used a IWorkbenchAdapter to get
> information for the tree but this should be the same as creating my own
> label/content provider). U said to use the IFileService that, for what I
> have seen in the ftp example is the FTPService ... mine EOMService ...
> that I thought would have dealt with connection/create/copy/retrieve
> files ...
> Thanks again
> Kar
>> So well,
>> connected session.
>> your IFileService.
>> Cheers,
>>> Kar
>>>> Hello Kar,
>>>> copy&paste...
>>>> wondering what benefit you see in using RSE?
>>>> Cheers,
>>>> Kar wrote:
>>>>> Hi all,
>>>>> actions like:
>>>>> example. What I had to do with the efs was just
>>>>> my rse service?
>>>>> MyService . new ()
>>>>> - connect
>>>>> - getFile (root)
>>>>> is that correct ...
>>>>> Regards
>>>>> Kar
>>>>>> example ...
>>>>>> thanks a lot
>>>>>> Kar
>>>>>> message news:48D93281.60809@windriver.com...
>>>>>>> Hello Kar,
>>>>>>> too bad.
>>>>>>> Cheers,
>>>>>>> Kar wrote:
>>>>>>>> Hi all,
>>>>>>>> tree view for the foders and table view for the file contents).
>>>>>>>> Kar
Re: info on rse project [message #577190 is a reply to message #26965] |
thanks a lot
Kar
> Hello Kar,
> too bad.
> Cheers,
> Kar wrote:
>> Hi all,
>> Kar
Re: info on rse project [message #577318 is a reply to message #27123] |
Hi all,
service?
MyService . new ()
- connect
- getFile (root)
is that correct ...
Kar
> thanks a lot
> Kar
>> Hello Kar,
>> too bad.
>> Cheers,
>> Kar wrote:
>>> Hi all,
>>> Kar
Re: info on rse project [message #577340 is a reply to message #27778] |
Hello Kar,
copy&paste...
Kar wrote:
> Hi all,
> rse service?
> MyService . new ()
> - connect
> - getFile (root)
> is that correct ...
> Regards
> Kar
>> thanks a lot
>> Kar
>>> Hello Kar,
>>> too bad.
>>> Cheers,
>>> Kar wrote:
>>>> Hi all,
>>>> Kar
Re: info on rse project [message #577367 is a reply to message #27813] |
Kar
> Hello Kar,
> copy&paste...
> Cheers,
> Kar wrote:
>> Hi all,
>> rse service?
>> MyService . new ()
>> - connect
>> - getFile (root)
>> is that correct ...
>> Regards
>> Kar
>>> thanks a lot
>>> Kar
>>>> Hello Kar,
>>>> too bad.
>>>> Cheers,
>>>> Kar wrote:
>>>>> Hi all,
>>>>> Kar
Re: info on rse project [message #577388 is a reply to message #27853] |
So well,
connected session.
your IFileService.
> Kar
>> Hello Kar,
>> copy&paste...
>> Cheers,
>> Kar wrote:
>>> Hi all,
>>> actions like:
>>> my rse service?
>>> MyService . new ()
>>> - connect
>>> - getFile (root)
>>> is that correct ...
>>> Regards
>>> Kar
>>>> thanks a lot
>>>> Kar
>>>>> Hello Kar,
>>>>> too bad.
>>>>> Cheers,
>>>>> Kar wrote:
>>>>>> Hi all,
>>>>>> Kar
Re: info on rse project [message #577408 is a reply to message #27893] |
too much.
<systemType
name="EOM Only"/>
</extension>
<configuration
name="%Files"
category="files"
priority="100"
id="eom.files"
</configuration>
</extension>
Thanks again
Kar
> So well,
> connected session.
> your IFileService.
> Cheers,
>> Kar
>>> Hello Kar,
>>> copy&paste...
>>> Cheers,
>>> Kar wrote:
>>>> Hi all,
>>>> actions like:
>>>> rse service?
>>>> MyService . new ()
>>>> - connect
>>>> - getFile (root)
>>>> is that correct ...
>>>> Regards
>>>> Kar
>>>>> thanks a lot
>>>>> Kar
>>>>>> Hello Kar,
>>>>>> too bad.
>>>>>> Cheers,
>>>>>> Kar wrote:
>>>>>>> Hi all,
>>>>>>> Kar
Re: info on rse project [message #577515 is a reply to message #27933] |
Kar,
> bothering too much.
> <systemType
> name="EOM Only"/>
> </extension>
> <configuration
> name="%Files"
> category="files"
> priority="100"
> id="eom.files"
> </configuration>
> </extension>
> files ...
> Thanks again
> Kar
>> So well,
>> connected session.
>> your IFileService.
>> Cheers,
>>> Kar
>>>> Hello Kar,
>>>> copy&paste...
>>>> Cheers,
>>>> Kar wrote:
>>>>> Hi all,
>>>>> actions like:
>>>>> my rse service?
>>>>> MyService . new ()
>>>>> - connect
>>>>> - getFile (root)
>>>>> is that correct ...
>>>>> Regards
>>>>> Kar
>>>>>> example ...
>>>>>> thanks a lot
>>>>>> Kar
>>>>>>> Hello Kar,
>>>>>>> too bad.
>>>>>>> Cheers,
>>>>>>> Kar wrote:
>>>>>>>> Hi all,
>>>>>>>> Kar
Current Time: Wed Jul 23 12:38:50 EDT 2025
Powered by FUDForum. Page generated in 0.30844 seconds
